06-08-2013, 12:25 PM | #1 |
Usofstance
78
Rep 671
Megan Racing Camber Kit
They finally came out with it, and its 250 dollars... What if we did a group buy?
2013 328i 6MT Bagged
IG Stu_UnitedStatesOfStance United States Of Stance |
06-08-2013, 01:02 PM | #2 |
133
Rep 1,245
more info? I would have interest if its compatible with EDC equipped cars
03' 525iT stick, 22' 530i
Previous: 20' X3 M40i, 19' 740i Msport, 17' 430i GC, 15' Msport X3 28i, 15' Sportline X1 28i, 13' Msport 328i, 09' Msport 335i, 07' Msport 335i |
06-08-2013, 02:50 PM | #3 | |
Usofstance
78
Rep 671
Part Number: MRS-BM-0311 *NOTE* As of April 2013 Megan Racing changed the color of ALL their suspension arms from Blue to Pink, we can not guarantee which color you will receive once you place your order, but we'll do the best we can to update our listings regarding which ones are available at this time in Pink since the Blue colorway will be discontinued once they sell out. For more information about this visit http://www.meganracing.com/products/...?special_id=16 2012-Current BMW 3 Series F30 Wheel alignment is absolutely crucial when modifying your car. Alignment can effect every aspect of your driving experience, from straight line stability, under-steer, over-steer, acceleration, braking and tire wear. Although stock components allow slight alignments from the stock suspension settings, they often are not able to properly align the car after the suspension has been modified. From the factory, most cars are set to have under-steer and for optimum tire wear at stock height; under-steer is often undesired from a performance standpoint but is always dependent on driver style, therefore the adjust-ability of the alignment of a vehicle is critical when tuning for speed. The clock does not lie and having the vehicle alignment can make seconds of a difference. Megan Racing Inc. has developed reinforced and adjustable control arms to accommodate the needs of the aggressive and performance oriented tuner. Being constructed of a Lightweight Steel-Alloy which is able to withstand the stresses of extreme competition, these arms are powder-coated with a 3-Stage process to ensure durability and protection against the elements. Megan Racing has now developed camber arms for the B.M.W crowd that will help attain a higher level of control and performance. Constructed of a Reinforced Rubber Bushing , these control arms remain light weight while being able to take the punishment of competition and extreme conditions. A 3-Stage powder coating process the control arms will easily combat the elements for years of performance. SPECIFICATIONS & FEATURES: - Made with high-strength and anti-cranking rubber material - Rubber viscosity is around 2000KGS - Direct replacement/ no modifications needed
06-08-2013, 09:45 PM | #5 |
Usofstance
78
Rep 671
Yes! We need front camber.
06-09-2013, 12:08 PM | #7 |
99
Rep 1,050
True and they are a god option but the F30 needs a separate camber plate option so we can choose our coilovers/suspension.
I really just wanted to make sure people knew this was a rear kit before they spent the time sifting through the the not-so-great Megan Website. |
06-10-2013, 05:15 AM | #9 |
B0$$
54
Rep 131
our cars does not have adjustable front and rear cambers? or is this kit for people who go for a stance layout and need more adjustments?
Prev:
2013 AW/Coral Red 328i Sportline- Mperf. Black Grills, Mperf. exhaust, Prem. pkg, Tech pkg, Lighting pkg, Heated seats, Sports 8spd w/paddles 2016 CWP STi FBO E85 |
06-10-2013, 06:59 AM | #10 | |
Usofstance
78
Rep 671
We can adjust the rear but only so much, with this camber kit we can do more.
06-29-2013, 02:27 AM | #13 |
*Bimmerpost Plasti Dip Guru*
81
Rep 1,174
Drives: E53, E46-M3, E70, F25-X3
A Real Man would choose the color Pink!
Just sayin~
06-30-2013, 08:58 PM | #14 |
33
Rep 944
K-Mac suspension has 3 versions of camber plate for the F30. With the AUD slumping against the USD they are a pretty reasonable option. You can order from their website
2013 Alpine White 328I M Sport ARRIVED
