06-06-2013, 06:12 PM | #1 |
Rep 21
Check Engine Light after Coding
Just successfully coded a lot of items from the F30 cheat sheet, but now my car is showing the Check Engine light. Has anyone experienced this before?
I checked iDrive and it says that everything is okay, but the light still remains. I coded the following:
06-06-2013, 06:46 PM | #2 |
Rep 21
Just did some digging, and I found a method from ShawnSheridan to read/erase the CEL.
Assuming the fault condition no longer exists, to clear the fault code. 1) Launch C:\EDIABAS\Bin\TOOL32.EXE 2) Hit F3 3) Load C:\EDIABAS\Ecu\F01.PRG 4) In the "Select Job: F01" window, select FS_LOESCHEN_FUNKTIONAL 5) Hit F5 6) "Results" window should show "JOB_STATUS = OKAY" Hopefully, Problem Solved. Note: fs_lesen_funktional only read fault codes, FS_LOESCHEN_FUNKTIONAL will delete it. I assume I should read the fault code first to see what it could be? And since CEL only pertains to emissions, I might take out the Sport+ mode and see if it goes away on its own in a couple days. In the meantime, any thoughts? |
06-06-2013, 09:28 PM | #3 | |
10340
Rep 40,300
Drives: 2018 Alpina B6 650ix GC
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
