BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > Disabling the Brake Pad Sensors DIY Guide
      06-06-2013, 04:49 PM   #1
thenewrick
26
Drives: 2007 E93 335i Black Sapphire
Hello fellow travelers.
This is a DIY guide on how to disable your brake pad sensors.
I did a burnout and it triggered the service warning that I needed to do a full brake job. I knew my brakes and pads were fine and that I had somehow goofed up a sensor doing the burnout.
Lo and behold the sensor had broken off from the pad and was dangling:
So here's what you'll need:
Scissors, wire stripper, duct tape, zip tie.
*There are only two sensors, Driver's front and passenger's rear.
1: Remove wheel
2: Locate sensor in between caliper and attached to the pad
3: Pull out the sensor from the pad and cut off the sensor head
4: Strip the 2 small wires carefully then twist the two wires together
5: Duct tape the wires and ziptie them in a safe spot. I ziptied mine in the spot the sensor wire normally sits so shouldn't be an issue. *careful not to do anything extreme like clamp your brake line closed*
6: Repeat the same process for the rear passenger side
Then put the wheels back on, disable the service warnings in the car, drive it around and make sure the warnings went away and everything works, tighten the wheel lug bolts again and you're done!
      06-08-2013, 04:29 PM   #2
S.TX335i
Drives: Coupe 335i
+1 . This works! I had recently replace my break pads so I knew that wasn't the problem. It appears these sensors can break when you push the car.
      06-09-2013, 12:18 AM   #3
oucheese
Drives: 335i Montego Blue
Been meaning to do this, hopefully I will get around to it tomorrow
      06-09-2013, 10:56 PM   #4
Zero_09
38
Drives: 07 E90, 2011 E90
Nice DIY with pictures.
      06-10-2013, 08:46 AM   #5
.fLip.
no more coupe :(
20
Drives: e90
yea I did this on my last brake pad change since they broke when removing them.
      06-16-2013, 02:59 AM   #6
oucheese
Thanks for the DIY, it works!
      06-16-2013, 02:38 PM   #7
thenewrick
26
I had a little quirk pop up. The other day I started up the car and the brake warning came back. So it may do a periodic check or something. It's like a zombie code; won't stay dead
      07-09-2013, 02:58 PM   #8
thenewrick
26
The zombie-code went away after one drive and hasn't shown up for a month now so I think it was just a quirk.
      07-10-2013, 07:31 AM   #9
Surly73
535
Drives: '11 535xi 8AT KWv3 MPE MHD xHP
I don't understand why this DIY is in demand.... If you broke your sensor during brake service, buy another. All the service guides say they really should be replaced anyways. They're $10-$15. I don't see how sensors can be damaged from "pushing the car" or "burnouts" unless perhaps the sensor cable was misrouted around the suspension during the last brake job and extreme suspension travel yanked them out of place.
And in the pic for step #5, your pad sensor connector is clearly shown as disconnected but you didn't mention doing this on purpose in your steps. If you didn't do that, then that's why your sensor light was on. Step #1 in your writeup should be a full inspection to see if you can tell why the light came on in the first place.
Then, if you insist on cutting off the head and twisting the wires together just do it within a couple inches of the connector instead of zip tying the cable all over the place near the wheels.
      07-10-2013, 11:19 AM   #10
thenewrick
26
The sensors are flimsy and just break due to vibration and sudden movement. I personally don't like having extra electronic bits that can go wrong when they don't serve a purpose. I know when to change brake pads more than a sensor does. I don't like unnecessary nannies.
It turns out you don't need to disconnect the sensor. I did it once then realized it wasn't necessary so I didn't mention it. This is a DIY on how to disable your brake sensors not how to inspect your brakes.
Zip tying them in their original location is fine. It was there like that from factory so good enough for me.
      08-21-2013, 10:50 PM   #11
Zero_09
38
I changed both my brake sensors with new OEM BMW ones like 4,000kms ago and I had a the code pop up because the sensor also broke off. Thanks for the DIY as this was exactly what I was looking for. I don't want to bother spending $50 every time my brake sensors brakes.
I'm pretty sure this guide is for people that know their brakes are good but don't want to deal with changing it every 4-5000 kms if the sensors brake off.
And yes I already got the brakes checked by Ivo the other day and he said I have plenty of meat left on the pads. He said they will probably last another 2-3 years.
Thank you thenewrick for the great write up.
      08-22-2013, 01:46 AM   #12
thenewrick
26
Np. Lots of people are just scared of things they don't understand.
      08-23-2013, 01:49 PM   #13
Zero_09
38
Just got it done while I had the vehicle up to change out the differential fluid. Everything looks good now. Thanks again
      08-27-2013, 03:31 PM   #14
subbie79
Drives: 2007 335i Sedan
You can bridge the connector by plugging a "u" shape wire. Sensor and wiring can be removed and you can always plug it back in if you wish down the load.
You must do front and rear together to avoid brake warning light. If you only do either front or rear, the warning light won't go away even after reset.
      08-27-2013, 03:43 PM   #15
thenewrick
26
You can but when you replace the sensors it comes with new wiring anyways so easier to cut n twist
      08-29-2013, 03:50 PM   #16
PHXE90
PHXE90's Avatar
12
Drives: 2007 BMW 328i
Very nice DIY, will be doing this very soon.
      08-29-2013, 10:19 PM   #17
LocDawgg
68
Drives: AW e90
when you find genuine brake pad sensors for 10-15 dollars, please share. ive been looking.
      09-14-2013, 02:14 PM   #18
Slow_335i
Daily Driven!
Slow_335i's Avatar
186
Drives: BMW 335i
2008 BMW 335I  [7.02]
Thanks for this!
      10-31-2013, 01:10 AM   #19
ptwol
Drives: E90 LCI
Thanks for your share!
      10-31-2013, 05:32 PM   #20
bula
Drives: 335xi
Here you go:
http://www.autohausaz.com/search/pro...7&cid=14@Brake %26 Wheel Hub&gid=1920@Brake Pad Wear Sensor
      08-20-2015, 09:26 PM   #21
vincentvega222
12
Drives: 335i
Screw the sensors. They break and it's annoying to swap them out, esp the rears. This DIY is awesome, I'll never go back to replacing sensors. Thank you
      12-18-2015, 11:33 AM   #22
MAZINGER
39
Drives: 2008 E92 335i
What will be the rear and front brake indicator showed in the on board computer in the cluster after this mod? Number or _ _ _ _ line?
