Frm3 Xenon Or Not?
06-06-2013, 01:08 PM | #1 |
129
Rep 820
Frm3 Xenon Or Not?
Can someone help me out with a FRM3 Module.
Is it an Xenon module? adaptive or not? i cannot find the information nowhere please help me. the serial number is 6135 9224592 - 01 here is a pic of the module thanks |
06-06-2013, 02:32 PM | #4 |
886
Rep 9,097
This is basic one for halogen headlights.
For ordinary xenon, you need xe. For AHL xenon you need max version. Both of them are for sale in sale thread.
F36 Xdrive for her - HUD, park assist, heated steering wheel, rear camera, Apple car play
F36 RWD for him - HK, M sports pack, GTS tail light, Apple car play |
06-06-2013, 02:37 PM | #5 |
129
Rep 820
06-06-2013, 02:49 PM | #6 |
37
Rep 252
Are you sure about this? I found information that you can code xenon when you have basic FRM3, so now I'm confused :/
06-06-2013, 02:54 PM | #7 |
748
Rep 4,429
uhhh, Not really sure about whats being said about the FRM3 Module but I can tell you that I own a early 07 335i E92 and upgraded from FRM2 to FRM3 for my LCI taillights and I still have the AHL option.
ModeCarbon V1 CF lip/PF AG CF SS ext./ARKYM CF Diffuser/OSS AE's/B&G Springs/CF Performance Spoiler/V2 Led Performance SW/Meisterschaft GT exhaust
06-07-2013, 06:51 AM | #8 | |
886
Rep 9,097
Also the ballast will be getting wrong pwm, unless coded and corrected. Whats the point of buying expensive xenons if you cannot afford proper frm especially if two of them are for sale on the forum.
06-07-2013, 07:49 AM | #10 |
129
Rep 820
Actually not me but my brother bought it, he have a 06/05 built e90 325 xenon
with the frm1 he wanted to retrofit the frm2/3 and he had a good deal with the frm3. the add said FRM3 for xenon... ( viva allegro.pl.....) so he jump on it, and after he received it he realize that. |
06-07-2013, 09:33 AM | #11 |
Rep 106
Drives: E90 06 320D
06-07-2013, 11:11 AM | #12 | |
886
Rep 9,097
You have more flexibility so even if you do not change the frm3 basic with xenon vo, it will work. However technically thats not correct. I see what ****** said. Since op's brother car is pre-lci so I assume he can get away with it.
06-07-2013, 08:52 PM | #13 |
23
Rep 265
i think you can have any frm and add xenon with vo would work but if its lci headlight then need frm3 for the highbeam shutter to work. I had the frm2 and lci headlight shutter didn't work but after changing to frm3 ahl highbeam shutter work but still in the process of figuring out the taillight as its throwing malfunction error and self leveling.
06-08-2013, 01:03 AM | #14 | |
886
Rep 9,097
I have pre-lci and I found frm2 more flexible. As it can be tweaked to fire bi-xenon and lights with halogen H7. Whereas frm3 can fire only bi-xenon and I guess pin number for shutter is different. I have non-AHL and it could not work with frm3 and hence I am on Frm2.
08-18-2013, 09:29 AM | #15 | |
16
Rep 228
There is the Max Brose option also shown as AHL on the label then there is the Basis version also shown as LED Basis. Max Brose /AHL is what is needed for adaptive headlights if you want that option to work. Basis version/LED Basis will work fine with xenon or halogen. If Xenon it can be done with coding and a little rewiring. I do not believe there is any way to make the adaptive functions work though, that'll be a future experiment I'm working a DIY for US spec LCI Halogen to LCI Xenon non adaptive, once done i'll post it. There doesn't seem to be one with that specific info, all the threads out there are variants. |
08-18-2013, 02:33 PM | #17 | ||
886
Rep 9,097
I have fitted Lci xenon on pre-lci car and on lci. On Lci car I have even fitted simple frm (basic) and coded it for xenon. Worked like a charm but its not the oem method.
08-18-2013, 04:34 PM | #18 | |
16
Rep 228
Currently in the process of finalizing everything for the manual aim method, all seems to work fine so far. in the future i may buy the leveling sensors and try retrofitting them in along with the wires needed to aim the headlights, worst case i'll need to buy the a new FRM 3 with AHL |
08-19-2013, 04:40 AM | #19 | |
16
Rep 228
I appreciate any info on these, not sure what to do with them yet. oem wiring looks like it would have wires going from the headlight pin 7's to footwell module X14261 pin 50 for left hand and X14260 pin 8 for right hand |
08-19-2013, 06:16 AM | #20 | ||
886
Rep 9,097
I have wired them to parking lights.
