Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > How to use NFS Emergency Flash
      06-05-2013, 12:36 PM   #1
pweber
pweber's Avatar
Germany
37
Drives: M57 330D
Hello Guys,
As I promised I made a video tutorial "How to use NFS Emergency flash".
Let me know if you have questions, I will try to help you.
Windows XP in Polish version.
Enjoy
      06-05-2013, 02:04 PM   #2
cn555ic
cn555ic's Avatar
441
Drives: 335i
Thanks for the video. It helped immensely. I just set my NFS emergency flash to flash FRM3 module. I will see how it goes when the situation arises. ******. If a module is bricked to the point of INPA, NCSexpert and Winkfp not even able to communicate with for argument sake the frm3 module. With this emergency flash, What's the chances using NFS to bring the module back to life in which communication is again restored. Have you ever used the NFS emergency flash, if so under what circumstances did you have to use it in first place?
      06-05-2013, 03:39 PM   #3
nate5ks
33
Drives: 2006 BMW 330xi
Can you use it to flash a used DME to work with a different car?
      06-05-2013, 04:45 PM   #4
MiamiTuning
Drives: 2015 F80 M3
Great info thanks for sharing.
      06-06-2013, 02:49 AM   #5
pweber
pweber's Avatar
Germany
37
Drives: M57 330D
So, basically if your FRM3 module is bricked and you can't connect it through OBD port , even with Tool32 there is a small chance that NFS emergency flash will help you.
There is a small chance that anything will help you, except physical interference with the hardware.
Usually it is very helpful when your flashing process has been interupted (voltage dropped down, cable has been disconnected, etc..) and you can't flash it again because of few errors in module) and also because the data table has been erased and Winkfp (very often gives you IFH-009 - no response from control unit) can't reflash it, but still has connection with module. I mean this first process with status bar which is reaching 100% very quick and then is trying to begin from 0%, if you have error at this moment you can use NFS and all should be fine. You can try with any module which is able to connect through OBD port. Very often when Winkfp can't flash sometnhing, NFS can do it.
I did it twice with DDE4.0 in older BMW e39 and it worked great, so if you have some bricked module you can try, maybe it will help.
      06-06-2013, 02:51 AM   #6
pweber
pweber's Avatar
Germany
37
Drives: M57 330D
No, you can't. Used DME can't be programmed through OBD port in different car. The chip has to be preapred first directly.
      06-18-2013, 09:35 AM   #7
MiamiTuning
Drives: 2015 F80 M3
Is the ecu address 64 for all ecu's or just the one you selected?
      06-18-2013, 09:56 AM   #8
cn555ic
cn555ic's Avatar
441
Drives: 335i
Each module has their own address # which you have to edit which has to correspond to the correct ZB number to flash.
      07-12-2013, 12:34 PM   #9
trentmw
Drives: 2011 M3 (e90)
How do you find the address? I tried bringing up the ZB number for my e46 330i (7571613) in WinKFP with hopes it would tell me the address. Instead it returns "XX - P-SGBD uses internal Address"
Edit:
I ran the ECU Identify job in ToolSet32 and got these results in the attached pic. The reason I am using Emergency Flash is because I lost connectivity somehow flashing with WinKFP. This is a new (to the car) ECU that I was trying to flash with the correct program for my car.
Is the ID_COD_INDEX of 00 the address to use for my ECU?
      07-12-2013, 01:35 PM   #10
cn555ic
cn555ic's Avatar
441
Drives: 335i
Use INPA or ask other members on e46 platform that code what the ecu address is
      09-08-2013, 02:27 AM   #11
makkan00
makkan00's Avatar
886
Drives: F83 and F36
Is hardware number under the inpa same as ECU number?
Trying to find out hardware number for JBBF.
F36 Xdrive for her - HUD, park assist, heated steering wheel, rear camera, Apple car play
F36 RWD for him - HK, M sports pack, GTS tail light, Apple car play
      09-08-2013, 06:20 AM   #12
cn555ic
cn555ic's Avatar
441
Drives: 335i
JBBF address is 00
      09-08-2013, 07:16 AM   #13
makkan00
makkan00's Avatar
886
Drives: F83 and F36
JBBF address is 00
Cheers bud.
      10-24-2013, 10:23 PM   #14
huqiubo
Drives: ford
Can I FRM module cannot communicate using NFS programming? Database with WINKFP database?
thank you
      03-17-2015, 06:11 AM   #15
hardr85
hardr85's Avatar
Drives: 2006 330i e90
Bump.
Please help, I am trying to use NFS emergency flash, but I keep getting a format error in line 32. I am sure I have the address and zusb# wrong for the dme and jbbf.
Can someone please tell me where I can find these numbers and how to get to them if they are in INPA or winkfp.
The error I get refernces the notfall dat file on my c drive if that makes any difference. Please help I have been without my car for close to 2 weeks!
      07-17-2015, 07:56 AM   #16
gmros
Drives: bmw 320d e90
Originally Posted by ****** View Post
Hello Guys,
Enjoy
How do you config nfs.ini to work with icom (using easyconnect)?
interface =REMOTE
interface1=
interface2=
interface3=
      03-22-2016, 12:23 PM   #17
pak1s0ul
Drives: 2011 BMW M3 E93
hello i think i have bricked my tcum telecom/bluetooth unit battery dropped while i was updating it with winkfp, however i was never able to connect to tcum using ncsexpert always got no respoce from ecu or not connected.now my Bluetooth for telephone is not working and Mic amusing they are working via most connection. btw im using DCAN cable however someone told me i need ICOM MOST connection to reprogram the unit is it true? my car is 2011 E93 M3 .
      09-06-2016, 08:34 PM   #18
Mdriv3r
Mdriv3r's Avatar
149
Drives: F13 M6
Nice video man. Where is the best place to pick up an ICOM A2 and ICOM B (MOST)?
Hello Guys,
Enjoy
      09-06-2016, 08:45 PM   #19
Mdriv3r
Mdriv3r's Avatar
149
Drives: F13 M6
What did you end up doing????
      05-31-2017, 09:11 AM   #20
herbie53guy
Drives: 2004 R53
Hello
Im trying to use NFS for a radio module in a MINI, i followed the steps. When i get to start emergency flash i get:
WinKFp data
Integrity check
ZB-No.9218837
ive loaded all the files into Winkfp, still same issue
any help would be great
      11-08-2020, 02:53 PM   #21
ZiMMie
26
Drives: S54/E36
Originally Posted by hardr85 View Post
Bump.
and old post but here is all the address for e8x
Code:
00:JBBF
01:MRSZ5_ACSM2
06:TRSVC1
12:DME_DDE
16:AFS90
17:EKP
18:EGS_SMG
19:VGSG90
1C:LDM90
1D:FFP90
20:RDC60
21:ACC
24:CTM
27:PGS2
29:DSC_DXC
2A:EMF89
30:EPS
31:MMC70
36:TCU
37:AMP60
39:EDCK
3B:NAVIL2
3C:CDCPL2
3F:CCC_ASK
40:CAS260
41:DWA_USIS
44:MDSD60
47:CCC_TUN
49:SEC_1
4B:VID
50:DWA_SINE
53:IBOC2
54:SDAR60
55:ISPEECH
56:FZD
5B:DAB
5E:GWSM
5F:FLA
60:KOMBL2
61:CBX61
62:MCGW
63:MMI
64:PDC
67:ZBEL2
6D:SM_FA
6E:SM_BF
71:AHM
72:FRMPL2
73:CID
78:IHK
7D:FDM
90:MASK_SAH
91:MASK_SP
92:VI_HW
98:MASK_LW
A0:CCC_APPL
A9:CDC270
AB:MMC270
@Mykekfz - Instagram
E36'S54 | E46ti'M54 | E85'M54 | E91'N52B25 | E60'S85 | MK8'GTE
F31B48278.00
