06-05-2013, 09:53 AM | #1 |
41
Rep 405
Spacers
I put 12mm H&R spacer on the rear, nothing on the front. The car is lowered on H&R. I did about 125mph and i felt shimmying on the rear. Like the car wanted to lose control. Is this because theres a wider stance on the rear when the front is suppose to be wider(factory)?. Should I put a 12mm on the front so it can be like the car is back at factory specs or just take the spacer off on rear
06-05-2013, 10:02 AM | #2 |
357
Rep 1,377
Check the spacers. I have a similar setup and have never experienced what you're describing. Are you 100% sure they're for the M5 and have the correct specs?
Current: 2015 X5 M - Donington Grey/Mugello Red - DINANTRONICS Stage 2 + Free Flow Exhaust - Bimmerpost Featured!
Past: Bimmerpost Featured 2014 X5 xDrive50i · 2014 Jeep SRT · 2013 Tesla Model S P85+ · Bimmerpost Featured 2013 F10 M5 · 2012 550 xDrive · 2011 M3 ZCP |
06-16-2013, 12:42 PM | #3 |
85
Rep 1,489
+1...make sure you have quality spacers on the vehicle. #2, be sure that you keep a close eye on the track width of the car. Pushing the rears out 12mm and nothing on the front is definitely going to change handling. After running spacers with the stockies (12mm F/10mm R) If I were to do it again I'd run 10mm on all corners, max.
Current: '16 GT4
Past ///Ms: '13 F10 M5, Alpine Weiss III/Sakhir Orange Full '10 E60 M5, Space Gray/Black |
06-17-2013, 10:47 PM | #4 | |
704
Rep 1,917
Matt
