Frm3 bulb check disabled, turns off rear outer lights
06-04-2013, 07:50 PM | #1 |
Rep 17
Do u guys know why disabling the bulb check for the
Rear lci also turns it off? If i leave the bulb check on i get errors and flickering but atleast it will turn on? I have an 07 e90 335i retrofitted frm3 |
06-04-2013, 10:02 PM | #2 |
23
Rep 265
I did the frm3 retrofit and just disable this to get the error out. Is this the line you disabled.
WARMUE_SL_1_M1_14_M2_41 nicht_aktiv WARMUE_SL_2_M1_16_M1_18 nicht_aktiv |
06-05-2013, 01:22 AM | #3 |
886
Rep 9,097
If you have frm3, you do not need to uncheck anything. Because frm3 comes on LCI cars with leds.
F36 Xdrive for her - HUD, park assist, heated steering wheel, rear camera, Apple car play
F36 RWD for him - HK, M sports pack, GTS tail light, Apple car play |
06-06-2013, 11:36 AM | #4 |
Rep 17
yes that is the code i disabled. sl1 if disabled, turns off the outer lights. leaving it aktiv, error code but atleast it will stay on.
06-06-2013, 01:00 PM | #5 |
Rep 17
you would think but not the case. coding the VO does not work either, i believe it was only meant for e92's since they have an official retrofit for it. Not so much with e90's
06-06-2013, 02:38 PM | #6 |
886
Rep 9,097
I have tried all VOs on e92 as well and none worked.
