05-31-2013, 03:39 AM | #1 |
443
Rep 1,963
Drives: I20 IX M60 Oxide Grey
USB stick - playing music & playlists
Sorry if this is covered elsewhere - would appreciate a link coz I couldn't find it.
I put about 7GB of audio from my itunes onto a USB stick. Also exported playlists, edited the paths in each one so it matches the root path on the stick and plugged it in. Took a little while but the music seems to have been copied through. But only about 3 of about 10 playlists is showing, and then only about 1 track in each one. Also it complains that some folders have files that are basically non music e.g. xxx.mp3 will have another file called .xxx.mp3, which isn't the track. if i plug the usb back to my computer i can't see those files... Any suggestions? i have business nav and standard bluetooth (for what it's worth)
Running: G30 530d M Sport (B57) Mediterranean Blue
Running: I20 IX M60 Oxide Grey Gone: F15 X5 40d M Sport (N57) Glacier Silver, E61 520d SE Auto (N47D20) Titanium Silver, F31 330d M Sport (N57D30A) Estoril Blue, E87 120d SE Auto (M47TU2D20) Sparkling Graphite |
05-31-2013, 05:44 AM | #2 |
207
Rep 668
Make sure the m3u files are formatted to windows style paths. I also found that placing all my mp3s and aacs in a folder / sub folder, and putting the playlists in there helps. Finally, there's a great free tool called listfix that can repair problem m3u files.
http://listfix.sourceforge.net/ My structure is like this: \Music\playist.m3u \Music\Artist\Album\track.mp3 |
05-31-2013, 09:43 AM | #4 | |
443
Rep 1,963
ITM/... So I've got the following at the start of each path: '/ITM/...' Are you saying I need to do the windows backslashes only to repair?
05-31-2013, 12:50 PM | #6 | |
443
Rep 1,963
05-31-2013, 04:56 PM | #7 |
951
Rep 1,643
There is in the options section on the iDrive isn't there? When you hit the options key when in the music menu you can randomise playback. Unless it only works when music is on the internal HDD...
05-31-2013, 06:35 PM | #8 |
443
Rep 1,963
06-01-2013, 04:20 AM | #9 | |
443
Rep 1,963
Next steps to try:
06-01-2013, 04:25 AM | #10 |
443
Rep 1,963
another question - does the BMW have issues with m4a or m4p files?
ah crap - is this all the stoopid digital rights crap?
06-01-2013, 06:28 AM | #11 |
443
Rep 1,963
Ok cool - so it's working now - thanks for the help.
Incidentally the windows path wasn't the problem (i.e. no probs with forward slashes) - it's working now with the forward slashes, but using relative paths. I used listfixer. Not sure exactly what the original problem was - certainly some references in the some playlists weren't coming up correctly in the fixer. Also I set it to the following parameters:
My structure is as follows: Root ITM <music> Playlists So each reference in the m3u file starts with:<m3u files> ../ITM/... Hope it helps someone else. Happy now coz the general search on the business media thing is crappy.
06-02-2013, 05:23 AM | #12 |
443
Rep 1,963
You think this will work to have the USB stick plugged in but then also charge my iphone off the USB? I really don't need the y cable if this works...
http://www.amazon.co.uk/Plugable-USB...rds=usb+double
06-02-2013, 05:50 PM | #13 | |
40
Rep 589
F36 435D M Sport + Glacier Silver
Gone F30 320D 8AT M Sport Mineral grey Gone E92 320D M Sport Sparkling Graphite Gone E46 320D M Sport Silver Grey |
06-03-2013, 06:43 AM | #14 |
443
Rep 1,963
Cool - have ordered one so will report back. Really don't want a y cable as I have a 4s (for a little while longer at least) and the wife has a 5...
06-03-2013, 03:59 PM | #16 | |
443
Rep 1,963
06-03-2013, 04:28 PM | #17 | |
139
Rep 699
06-03-2013, 05:19 PM | #18 |
443
Rep 1,963
Ah right - sounds like too much effort. What cradle did you get? And how 'reversible' is the setup? Need to hand the car back in 2 years... Although if I opt for this will need to find a black iphone cable
06-04-2013, 01:55 AM | #19 | |
139
Rep 699
Dashmount bracket iPhone 5 holders Black charging cable (if you choose a passive holder) I can take a picture later if it helps. Last edited by Mr NSB; 06-05-2013 at 04:08 PM.. |
06-05-2013, 03:41 PM | #20 |
443
Rep 1,963
So an update.
Seems like it works but with restrictions.
So not ideal, but workable I think. I'll keep a 12V cigarette lighter USB converter in the car just in case too
06-05-2013, 04:23 PM | #21 |
951
Rep 1,643
It'll because the iPhone is draining the power from the USB stick. Ideally you'll need to have a USB powered hub with an external power supply. E.g. Have a hub powered by the cigarette lighter (Is there one in the centre console?)
06-06-2013, 01:25 AM | #22 |
443
Rep 1,963
Hahaha. If there was one then I'd just plug the iPhone into that! Btw I don't get any functionality from plugging the iPhone to the USB slot - I don't have enhanced Bluetooth.
They should really sort this out in the lci. |
