BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > Instrument cluster swap - possible?
      05-29-2013, 08:58 PM   #1
flipper325
12
Drives: '08 328xiT
I want to replace the instrument cluster in my '08 328xiT with one from an '09 335xi, and would like to know if it's possible, and what's involved.
The reason -- I hate the instantaneous MPG gauge at the bottom of the tach, while the 335 has an oil temp. gauge (I know it's not super accurate, but still much more useful).
The 335 cluster comes from a lower mileage car, so whatever odometer mileage is stored in it (if at all), should revert to my actual higher mileage -- as I understand, this data is stored in several locations, to prevent easy tampering.
I suspect there is no fit issue, but am not sure if any coding is required, or erasure of the 335i cluster EPROMs, etc. to bring it to the new/virgin condition. Any help would be appreciated.
Thanks,
Alex
      05-30-2013, 06:47 AM   #2
makkan00
makkan00's Avatar
886
Drives: F83 and F36
There are companies in Europe who can do all of this but on a premium rate. 500-700 euros.
F36 Xdrive for her - HUD, park assist, heated steering wheel, rear camera, Apple car play
F36 RWD for him - HK, M sports pack, GTS tail light, Apple car play
      05-30-2013, 04:16 PM   #3
BMW..
Guest
n/a
Drives:
Thanks,
Alex
You have to reprogram a computer chip and replace it on the board
      05-31-2013, 03:10 AM   #4
pweber
pweber's Avatar
Germany
37
Drives: M57 330D
Replace EEPROM in CAS and new INSTRUMENT CLUSTER.
These both must match.
      05-31-2013, 06:48 AM   #5
makkan00
makkan00's Avatar
886
Drives: F83 and F36
I have been told that using a blank eprom and programming it on the used Odomter with your car's vin and current mileage should do the job.
Never heard of changing anything on CAS.
      05-31-2013, 09:14 AM   #6
pweber
pweber's Avatar
Germany
37
Drives: M57 330D
Ok, right, I'm sorry, I was thinking about different situation .
In e90 only in IHK and CAS mileage is saved.
      05-31-2013, 10:16 AM   #7
flipper325
12
Drives: '08 328xiT
Got it. Assuming I install a new EEPROM in the instrument cluster, it will still need to be programmed, right? I.e., not a DIY job? A friend of mine is a wiz at soldering, but programming is a different matter.
Just curious, if a BMW dealership needs to replace a cluster to repair the car, they must have a way to program at least a brand new cluster, right? Will soldering a blank chip make the used cluster appear 'brand new'? Or is the EEPROM pre-programmed before it's installed in the cluster?
Alex
      05-31-2013, 11:09 AM   #8
pweber
pweber's Avatar
Germany
37
Drives: M57 330D
Alex
Yes, new EEPROM has to be programmed, not in car, it has to be done using programmer.
I think the EEPROM is pre-programmed, they just write in VIN there and code.
      05-31-2013, 11:48 AM   #9
makkan00
makkan00's Avatar
886
Drives: F83 and F36
You can do what ****** said or
You can solder a blank chip onto odometer and replace it in ista p.
Remember to check what part numbers it ask you to buy before soldering the chip onto any odometer. As it allows only certain part numbers.
      05-31-2013, 11:49 AM   #10
makkan00
makkan00's Avatar
886
Drives: F83 and F36
Its kombi and cas as far as I know.
      05-31-2013, 11:52 AM   #11
pweber
pweber's Avatar
Germany
37
Drives: M57 330D
Exactly, kombi (Instrument cluster).
      05-31-2013, 12:46 PM   #12
makkan00
makkan00's Avatar
886
Drives: F83 and F36
You made me confused by writing IHK above. Its a different module and I was like WTF....
      05-31-2013, 12:51 PM   #13
pweber
pweber's Avatar
Germany
37
Drives: M57 330D
Yes, IHK is the air conditioning
      10-18-2019, 03:26 PM   #14
OldIrishE90
Drives: Bmw e90 320d
Automatic vs Manual cluster swap
I bought a 2nd hand cluster for my 320d. Although it has transpired that it came from and automatic and mine is manual so it's showing a transmission fault even though it's not an automatic. When I get this codes with my vin will the cluster know that my car is manual and stop with the warning light? Thanks in advance
      10-19-2019, 07:10 PM   #15
LMB335IS
Sua Sponte
LMB335IS's Avatar
1299
Drives: 2013 LMB 335is
2013 BMW 335is  [8.84]
It will show the error(s) until you have the old VIN erased and default code the cluster to write your VIN and code it according to your VO
335is/DCT-M3 GTS software-M3 drivetrain-M3 GWS-KOMBI-DSC-SZL/MHD/BQ Tuning IG@ClustersandCoding
      10-21-2019, 10:22 AM   #16
OldIrishE90
Thank you very much for the info!
