05-28-2013, 01:20 PM | #1 |
27
Rep 285
Winter Wheel ?
Will the type 158s from the e90 fit on my 335xi sport line? Here are the specs on the 158s:
Type 158 (17x8 ET34 225/45 R17) These were my winter wheels for my e90, and I was hoping to use them as winter wheels for my f30. |
05-28-2013, 03:28 PM | #2 |
12
Rep 189
Yes they will and here is the proof. I have the same wheels for winter. The only thing is that your speedo will be slightly "slower"
2016 F26 Alpine White M40i
2014 F25 Alpine White 35i Sport - Retired 2012 F30 Melbourne Red 335i Sport Line - Retired 2007 E92 Space Grey - Retired |
05-28-2013, 09:25 PM | #3 |
27
Rep 285
05-29-2013, 08:16 AM | #5 |
120
Rep 1,053
+1...I was under the impression you would need at least a spacer in the front to prevent break rubbing. I am looking to use some style 193s for my winters. I would think the 193s should have a little more clearance due to the extra inch in diameter but I am not sue if they have the same offset as the 158s
Current: 2021 340xi
Retired: 2018 330xi | 2016 340i 6MT | 2013 335i 6MT | 2011 328i 6MT (N52) | 2008 335xi (N54) |
05-29-2013, 12:45 PM | #6 |
12
Rep 189
Nope, they work just great, no rubbing either externally (tire on body) or internally (brake and such). The 158s have the same offset and width as F30 (non-staggered) wheels, minus the diameter 17 vs 18.
My wheels were transferred from my E92 to the F30 by my dealer when I took delivery and the master tech knew they would fit. Which pissed off the parts guy who was more than ready to sell me a BMW OEM winter package for a few Ks.
2014 F25 Alpine White 35i Sport - Retired 2012 F30 Melbourne Red 335i Sport Line - Retired 2007 E92 Space Grey - Retired Last edited by Buzzman; 05-29-2013 at 12:51 PM.. |
05-29-2013, 12:54 PM | #7 | |
12
Rep 189
Here is a good place to check specs for BMW OEM Wheels. http://www.bmwstylewheels.com/3
05-29-2013, 02:27 PM | #8 | |
120
Rep 1,053
Current: 2021 340xi
05-29-2013, 03:08 PM | #9 |
1469
Rep 3,554
the opposite actually,the speedometer and odometer will read higher than actual with E90 sized tires.
Present: 2023 G07 40i ZDH/ZDU/ZMP/ZMQ/2NH/ZPK/ZPP/ZRC/300/3AC
Past: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508 Past: 2016 F34 335i xDrive ZCW/ZDA/ZDH/ZTP/ZMP/2V5/5DL Past: 2019 G01 M40i ZDA/2VF/ZPP/ZPX/688/3AC |
05-29-2013, 07:25 PM | #10 |
12
Rep 189
A typo, I meant speed will be slower (then the speedometer reading) but you are correct.
06-24-2013, 12:06 AM | #12 |
327
Rep 967
Guys, I thought the bolt dimension was different, i.e. M12 in E9x and M14 on F3x?
But perhaps the new wheel nuts will work well through the old rim, if the holes are wide enough ... /n |
06-24-2013, 02:03 PM | #13 |
1569
Rep 29,202
Yes, correct on the bolt size, but the hole is large enough to fit M14 bolts.
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals | |
06-24-2013, 03:09 PM | #14 |
327
Rep 967
