The Tire Rack
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Whats my Build Date??
      09-18-2007, 11:26 AM   #1
rambino
M Master
rambino's Avatar
74
Drives: M6 / X6M
Im trying to see if i can order a Quaife LSD but i read that cars with build date March 07 and after have welded diffs and therefore makes the Quaife LSD basically impossible to add...
Where can i find on my car the Build Date so i can checkk
thanks!
      09-18-2007, 11:36 AM   #2
achien
AC
95
Drives: E90 Post Members Crazy
look at the body panel on the driver's side...
Your Supreme Leader
      09-18-2007, 11:41 AM   #3
rambino
M Master
rambino's Avatar
74
Drives: M6 / X6M
you mean inside the door?
      09-18-2007, 11:42 AM   #4
achien
AC
95
it's on the body panel (hidden once the door closes), not on the door...
Your Supreme Leader
      09-18-2007, 04:12 PM   #5
rambino
M Master
rambino's Avatar
74
Drives: M6 / X6M
Nothing listed.. I live in germany and have a german 335.. heres a pic of the inside.. maybe you can decode it??
      09-18-2007, 04:30 PM   #6
musv
Drives: 2008 e90 335i
DEFINATELY off topic, but why are your cats SO BIG!!!!!!
      09-18-2007, 04:34 PM   #7
rambino
M Master
rambino's Avatar
74
Drives: M6 / X6M
what cats.. and dont hijack my thread.. im trying to find out what my build date is since it doesnt list it.. maybe it coded in the VIN.. please keep ontopic.. thanks
      09-18-2007, 06:08 PM   #8
flush01
46
Drives: 33m@%#ing5
ahahaha man I almost died from laughing anyways, can you make that picture bigger ? I can't see anything
      09-18-2007, 07:23 PM   #9
achien
AC
95
no flash please, it should be there on the "flash" part.
The date should read mm/yy (01/07 for mine).
Your Supreme Leader
      09-18-2007, 09:22 PM   #10
Turbomatic
Drives: E36 M3, 335xic, Rav4
What do you mean by "welded diffs"? You mean the diff cover is welded on? If BMW did that after March 07 to avoid allowing for aftermarket LSDs to be installed that is just gay.
      09-19-2007, 07:12 AM   #11
voerman
Member
Drives: '19 530e
If you go to realoem.com and plug in the last seven digits of your VIN, it will tell you the build date - in your case 8/2006.
http://www.realoem.com/bmw/select.do
Note - your car needs to be old enough to be listed there - the current cut off date is 11/06.
Lou
