Home made tool to open fuel tank
05-27-2013, 09:45 AM | #1 |
34
Rep 715
I started off trying with wooden materials , too week.
Had some square profile of aluminum laying around so I cut it to 15 cm and marked 1 cm in on each end and drilled a hole to fit M6 bolt or M8 , dont remember , anyway too thin and it will get bent. Distance between center to center of the holes should be 13 cm. I connected the bolt and tightened the nut. Tool ready. To get momentum on the tool I used a arm for sockets to give the force I need. Works like a charm...
Vargas S2 turbos|VAC S3 Cylinder head|RR DPs|RR MPs|Supersprint X pipe|Remus Quad Sport mufflers|aFe Stage 2 Si with scoops|Forge DVs|ER CP|BMS meth elbow|Aquamist HFS-4|Walbro 450 E85 LPFP|AA FMIC|BMS OCC|MHD|P3 Boost Gauge|Ohlins Road & Track + camberplates|M3 sways F/R+ Ground control endlinks|Vorsteiner v303 19"|Michelin PS2 sport|Quaife LSD|Vorsteiner V35 CF hood|CF CLS trunk|Duke Dynamics quad diffusor
