TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Cosmetic and Lighting Modifications (exterior/interior) > TiAg 335xi - Plasti-Dip Window Trim. Pic inside.
      05-26-2013, 02:11 PM   #1
stashtrey
294
Drives: 08 E90 335xi TiAg
Well... after months of pondering and putting it off I finally got rid of that ugly chrome window trim.
I elected to remove the top trim piece... came of very easily but not sure how many times you can pull that thing off as a few tiny bits of the plastic adapters cracked.
The bottom side I used blue 3M tape and ran a 1/4" gap on the bottom/door side and ran the tap onto the rubber window seal on the top. Wrapped the side mirrors in small plastic bags and tape. Used paper and blocked off the rest of the side/roof of the car.
I got too wrapped up in the project to take pics but here's the final product. I think it looks so much better having stared at that chrome every day with disgust! Particularly looks good on the titanium silver paint.
There are a few spots that it lifted on the bottom window trim and I'll likely redo a couple doors but for now it's fine. I'm going to get the non-aerosol plasti dip and touch-up those spots to see how it works.
Anyways... let me know if you have any questions. Not a challenging job at all.
E90 2008 335xi - TiAg - AMS FMIC - BMW PE - BMS OCC - ER CP - KW V3 - Vorshlag Camber Plates - AG M359 18" PSS - Alpina Flash - RB PCV Valvle - AFE Intake - Walbro LPFP
      05-26-2013, 05:57 PM   #2
roccob1123
roccob1123's Avatar
15
Drives: 2007 BMW 328xi Coupe
looks good I just did mine as well. Looks 100 x better than chrome.
      05-27-2013, 09:22 PM   #3
stashtrey
294
Agreed! I have noticed some rough edges and a few spots i didn't lay it on thick enough but I'm going to get the original non aerosol and see if I can touch it up that way rather than redo sections. Either way... huge difference.
      05-28-2013, 09:34 AM   #4
roccob1123
roccob1123's Avatar
15
Good idea I have a few touch up spots as well and need to do that. It gets a lil messy and uneven if you keep respraying.
      05-28-2013, 10:59 PM   #5
stashtrey
294
Such an awesome product though... amazing when you pull that tape/edge off and it just pulls right off in a perfect line. Great stufff.
      05-29-2013, 02:17 AM   #6
bwco
Drives: 535i xDrive
Did you dip the entire trim, including the part that the Door comes into contact?
      05-31-2013, 10:14 AM   #7
stashtrey
294
I did all the chrome. The pieces that are on the top of the door(s) at the base of the windows stays on... tape it off and spray it.
Let this stuff dry between coats (20-30 minutes) and put on several heavy coats. Then... don't mess with it for 3-4 hours. Let it dry!!! You'll kick yourself if you pull at it and lift it off the chrome. I did.
