F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > BMS Stage 1 Mapping Software
ARMA SPEED
      05-19-2013, 02:04 AM   #1
DXL XLR8
47
Drives: F30
I looked all over and unable to find an answer. How do I change map on a BMS stage 1 to up it to +4 psi.
      05-19-2013, 10:23 AM   #2
Jamesons Viggen
194
Drives: '98 M Roadster stg 2+ S/C
You need the cable and the software.
Cable is like $35, software is free. You just go into the boost and change 3.00 to 4.00 and save the file.
'98 Dinan/RMS stage 2+(VAC cams, CES Cutring etc)
'15 Buick Regal "T"(wife)
'06 Saab 9-5 Combi 5mt (full suspension, LSD, clipped turbo etc)
      05-19-2013, 12:03 PM   #3
DXL XLR8
47
Drives: F30
Where can I download the software from. I was told I could download the software at n54tech but could not find a download link.
      05-19-2013, 03:21 PM   #4
David328M-Sport
Australia
101
Drives: F30 M-Sport 328i Estoril Blue
http://www.n54tech.com/forums/showthread.php?t=15536
Don't just go changing the boost to +4 if you use 91 fuel without expecting some probable 'resistance' from your car's engine. It has been reported that +4 works best with at least 93(AKI) gas.
Read the thread thoroughly before making any moves and coming back to this thread blaming S1 for your car's woes.
Cheers
328i M-Sport, Estoril Blue, Carbon XP 35 Tint, front heated seats, black Dakota, Sports Suspension, Anthracite Headliner, HUD, Pro Nav, Sunroof, hk 600w, Bi-Xenon, 19" 403M wheels, Reversing Camera, DAB+, Xenon, BT Ext Connect, MST turbo intake pipe, MST Cold Air Intake, JB4 on Map 2 with Catless DP produces awesome performance in Sport.
      05-20-2013, 08:40 AM   #5
DXL XLR8
47
Drives: F30
Cheers
Thanks for the heads up. What do you mean AKI. I run 93 with 10% ethanol. Will this be a problem? Also would you know if later version of the F30 can run E85 without running into any problems down the road? I have heard mixed stories.
      05-20-2013, 09:59 AM   #6
Jamesons Viggen
194
You are fine with 93, I would not do 91 on +4.
      05-20-2013, 03:22 PM   #7
David328M-Sport
Australia
101
http://en.wikipedia.org/wiki/Octane_rating
      09-08-2013, 08:42 PM   #8
gtman
Iron man
gtman's Avatar
24
Drives: 2013 328i M-Sport/2013 C63AMG
did you feel a deference after changing it to +4psi?
2013 328i M-sport Totaled|2013 c63AMG|2014 G63AMG|2015 S65AMG|2015 S63AMG COUPE|2009 GL450|2015 fiat 500 abarth|2011 porsche boxster|2012 Lamborghini Gallardo gone but not forgotten|
      09-08-2013, 10:37 PM   #9
JN1
JN1's Avatar
301
Drives: S211 AMG E63
AKI = anti-knock index
-JustinNApproved
      09-10-2013, 08:47 AM   #10
algabr
Drives: f30 N20 320i
help with JB1
Hey guys im from brazil and the gasoline here really sucks, where I live they said the only gas we can have here is 87 RON, is there any problems to use the JB1?
I'm using it's standart version, and don't know how many psi of the boost is on..
EDit:
Here it's 87 IAD or AKI, i guess
Tks
      09-10-2013, 09:04 AM   #11
Jamesons Viggen
194
EDit:
Tks
I would not use ANY tune if the highest grade gas you have is 87. That is barely adequate for a bone stock car at stock boost levels.
      09-10-2013, 09:23 AM   #12
algabr
That sucks
So, if the AKI/IAD is 87 whats the RON?
Is the same thing?
I wish there was better gas, here we produce so much oil that could serve the whole country but we export everything and still mix more than 20% of etanol in our gas
Thanks for answering anyway
      09-10-2013, 10:36 AM   #13
Jamesons Viggen
194
That sucks
Is the same thing?
Wait wait, my bad, 87 AKI is about 91 RON. In that case, thats about the octane BMW recommends for stock. I would keep it stock. BMS stage 1 @+3 psi is the most I would push it to, as they test their cars in California and run on 91 RON. I would not do anything more aggressive as that calls for 93 RON.
      09-10-2013, 05:42 PM   #14
RSXDC5
RSXDC5's Avatar
707
Drives: M3
Well if he can source E85, then that opens a few more doors
2015 M3 - AW 6Spd w/ CCB
MCS 2WR Dampers, Spec Twin Disk Clutch, MaxPSI CH, F80Paul Ethanol Tune, 3.5in DPs
      09-10-2013, 06:21 PM   #15
Jamesons Viggen
194
From what I remember, JB1 is not for E85, but JB4 is.
      09-12-2013, 12:07 PM   #16
algabr
Yeah, mine is plus 3 psi, so can I use it with this poor gas?
      09-12-2013, 12:43 PM   #17
RSXDC5
RSXDC5's Avatar
707
Drives: M3
Good point!
      09-13-2013, 04:34 PM   #18
Jamesons Viggen
194
+3 is fine.
      09-15-2013, 12:34 PM   #19
aspang86
aspang86's Avatar
Drives: 2012 BMW 320i
I defiently feel the difference runnibg +3 & +4 boost. running at +3 the car feels a lot more responsive at higher speeds, where as with the +4 setting, I think the engine hesitates a bit...i think that maybe its running a little to lean at +4psi. iam suggesting this because my gas mileage is amazing when running at this setting whereas with the +3 setting I loose almost 100km in mileage. I have a 2012 320i. Has anyone tried running +5psi? I would like to try this since I have 94 octane fuel available here in Canada.
      09-15-2013, 07:36 PM   #20
gtman
Iron man
gtman's Avatar
24
+5psi with 100 octane would be interesting
      09-16-2013, 12:01 PM   #21
joedimarzio
Drives: 2014 BMW 328i, Sport Line
Cheers
Hey guys! I have a 2013 320i, and here in Chile I use a 97 Octane fuel. Do you think changing from +3psi to +4psi should be a lot different using this fuel?
Thanks
      09-17-2013, 08:11 PM   #22
David328M-Sport
Australia
101
Thanks
I'm running 98RON (Shell V-Power) with standard +3psi boost with S1. I intend on keeping it this way until S2 is upgraded to non beta. Plenty of extra boost for me at this time.
f30post
