Service Engine Soon light on, then went off
05-17-2013, 08:19 PM | #1 |
15
Rep 124
For the past few weeks ive noticed in lower rpms if I get on the gas on the highway it "jerks" kinda like shuttering. Well today I really got on the gas to pass a car in 4th running about 60 and it was jerking horribly then I got a SES light and I could not get on the gas without it sounding and feeling like I was in a aggressive massage chair. It was horrible. No matter what gear I was in. I down shifted and still shuttering and shaking. I almost felt like it was the transmission. Well about 2 min of just cruising without really getting on the gas the light goes away. Everythings fine and it clears up....drove the rest of the night with no problems. Anyone have a clue what it was or is? Bad gas? But its been for the past few weeks....just not this bad and I fill up every Friday. Kinda clueless here.
2007 BMW 335i 60,000 miles |
05-17-2013, 11:26 PM | #2 |
Rep 60
This can be described as a misfire.
I had the same symptoms and it turned out to be a bad fuel injector. The first episode was exactly as you described, sputtering, SES light on, then off. The second time around, it triggered the SES light to stay on but the car acted normal and drove fine. The dealership ended up replacing all 6 injectors under warranty. Misfires are mostly related to either spark plugs, ignition coils, or fuel injectors. A thorough diagnosis should be able to tell your where the problem lies. |
05-18-2013, 08:59 AM | #4 |
295
Rep 2,202
05-18-2013, 11:05 AM | #5 |
76
Rep 916
I had a not so similar introduction to the SES light. I was sitting in some parking lot traffic and got the code. I put the car in gear and let off the clutch and the car didn't move. Shut the car off the. On again and all was normal. The light went out and has t returned since. Need to pull codes and see what surprise I haven store. Anyone with a reader in queens ny area?
05-18-2013, 01:14 PM | #6 | |
295
Rep 2,202
Talk with them first though. |
05-18-2013, 04:37 PM | #7 |
15
Rep 124
If it is a injector, which im 99% sure it is, I'm covered under warranty, the only problem is my dealer has a 2 week waiting list, and I have nothing to drive until then. I live and work in a different city as relatives. How long can I wait until I HAVE to do this? Until I can find alternate transportation.
05-18-2013, 08:35 PM | #9 | |
Rep 60
The second issue I see is having to prove it to BMW in order to warrant warranty work. If the SES light is not on while servicing, it might be hard to convinence them there was a problem in the first place. Even with stored codes, it still might be far fetched and written off as an intermittent event that has no cause for concern. If this is the case, the better option in my opinion would be best to drive the car for the time being to somewhat drive to fault to reappear and set a consistent SES light. The third issue is dependant on your warranty. Is it a manufacturers warranty which should cover everything, a CPO warranty which is limited, or a third party warranty? If the fault is traced back to the spark plugs, the bill is coming out of your pocket along with the diagnosis fee if your under CPO. Ignition coils and fuel injectors are covered. I can't comment on the third party warranty but the manufacturers warranty should be good. Keep us posted.. |
05-19-2013, 03:56 PM | #10 |
15
Rep 124
It hasn't happened since then. About 3 days ago so its not a consistent issue. I have a GM warranty....its a major guard which is the most advanced warranty covering most everything. I bought the car from a Cadillac dealer
05-19-2013, 04:38 PM | #11 | |
1435
Rep 4,724
Current: 2021 M340i xDrive
Previous: '18 340i xDrive; '15 335 xDrive; '14 435i xDrive; '09 335 E92 xDrive |
06-05-2013, 04:48 PM | #12 |
15
Rep 124
Injector recall? Is there a such thing? Just looking into this. It happened again so I need to bite the bullet and thumb a ride everywhere lol
