TireRack
Go Back   XBimmers.com | BMW X6 Forum X5 Forum > BMW X5 Forums > X5 Vendors Classifieds
      05-17-2013, 03:25 PM   #1
ECSTuning
New Lifetime Replacement Policy
ECSTuning's Avatar
811
Drives: Independent Tuning Specialists
:: ECS Tuning :: PIERBURG Water Pump|Keep Your Cool
Don't settle for a new water pump for your N52; demand a "wasserpumpe" from Germany, by Pierburg. The N52 coolant pump is not belt-driven. Electrically operated, it allows faster engine warm ups and saves horsepower. Problem is, when it quits, your engine overheats--right now. Prevent overheating. If your N52 water pump is making warning sounds, head off trouble. Install a premium Pierburg "wasserpumpe" and avoid the inconvenience and substantial expense of an overheated engine.
Aluminum mounting bolts are one-time-use and should be replaced when installing a new water pump.
Click HERE for E60 5-Series (2005-2010) non-turbo 6 cylinder PIERBURG Water Pump with Mounting Hardware
Click HERE for E9X 3-Series (2006+) non-turbo 6 cylinder PIERBURG Water Pump with Mounting Hardware
Click HERE for E8X 128i (2008+) PIERBURG Water Pump with Mounting Hardware
Click HERE for Z4 (2006+) 3.0si 3.0i sDrive30i PIERBURG Water Pump with Mounting Hardware
Click HERE for E83 X3 (2007+) 3.0i 3.0Si PIERBURG Water Pump with Mounting Hardware
Click HERE for E70 X5 (2007+) xDrive30i PIERBURG Water Pump with Mounting Hardware
Pierburg is the manufacturer of the original pump for BMW.
Search this Thread:
Advanced Search
xbimmers
