The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > FRM3R Retrofit on E91 2006
      05-16-2013, 04:29 AM   #1
ChrizLoud
F11 520D LCI - Stage I
ChrizLoud's Avatar
Sweden
43
Drives: F11 520D LCI - Stage I
Unhappy FRM3R Retrofit on E91 2006
Hi!
Just retrofitted the FRM3R in my E91 with LCI head and tail lights.
Flashed it and changed VIN.
Changed build date to 03/2010 to be sure that NCSExpert chooses the right coding options for FRM3.
Before coding it shows its using a FRM2 file but after coding ended it shows it used the FRM3 file anyways.
The problem i have is that i get fault codes on turn signals (and fast blinks) even after manually disabling "warm", "kalt" and "meld" for turnsignal?
I thought that was not even to need changing the checks since i have the FRM3 module now?
      05-16-2013, 05:36 PM   #2
alexwhittemore
111
Drives: 2009 Crimson 328i
I could probably just search this, but while you've already created a new thread: what was the point of retrofitting an FRM3? What'd it get you in terms of coding (I assume coding possibilities were the driving force...)?
      05-16-2013, 06:21 PM   #3
CasperSYTFU
SYTFU Crew
CasperSYTFU's Avatar
No_Country
36
Drives: 2010 Toyota FJ
Coming from FRM1:
AE as DRL
Welcome Lights
Follow Me Home Lights.
Coming from FRM2:
      05-16-2013, 07:18 PM   #4
alexwhittemore
111
What are follow me home lights? Is that not the same as pathway lighting (click the high beam stock with key out, headlights come on for a configurable time, ~40s)?
      05-17-2013, 02:01 AM   #5
ChrizLoud
ChrizLoud's Avatar
Sweden
43
The cause is that i went from Pre-LCI Xenon AHL lights to LCI-Xenon without AHL and i was told that the only way to get my automatic height level adjustment back was to change to a FRM3 or a FMR2 from a car that doesn't have AHL.
Here is my tracefile if it could be of any help: Here is my .trc-file. http://www.filedropper.com/fswpsw Thanks.
      05-17-2013, 03:04 AM   #6
alexwhittemore
111
Ahh, I see. I was going to say, I totally have pathway lighting in my frm2. Sorry I can't help with the actual problem
      05-17-2013, 03:46 PM   #7
makkan00
makkan00's Avatar
886
Drives: F83 and F36
Which file do you have?
FRM3_E89.C31
or 32?
F36 Xdrive for her - HUD, park assist, heated steering wheel, rear camera, Apple car play
F36 RWD for him - HK, M sports pack, GTS tail light, Apple car play
      05-17-2013, 04:28 PM   #8
ChrizLoud
ChrizLoud's Avatar
Sweden
43
I have them both. I Will try to check tomorrow if its 31 or 32 in the Frm.
I used comfort mode so i guess it choosed the right one?
Do you think it could be flashed with the wrong version?
      05-17-2013, 04:39 PM   #9
makkan00
makkan00's Avatar
886
Drives: F83 and F36
Don't know but when Ncsdummy try to read your file, none of the above accepts your file as valid.
      05-23-2013, 02:54 PM   #10
ChrizLoud
ChrizLoud's Avatar
Sweden
43
It was using .C32
I have with Winkfp flashed the FRM with the FRMPL2 instead of FRM3R. Now coding went ok. i had to change some lines manually, "LED Blinkers" and "LED Lichts" etc. to get rid of errors and hyper blinking.
The main problem still exist with the height adjustment not working. I can not access the frm with INPA since its expecting a FRM1. Is there a way to get a round this?
      05-23-2013, 03:11 PM   #11
pweber84
pweber84's Avatar
Germany
49
Drives: BMW 330d e91
It was using .C32
Do you have xenon headlights or halogen?
      05-23-2013, 03:15 PM   #12
ChrizLoud
ChrizLoud's Avatar
Sweden
43
I Have LCI Xenon Lights.
Before i had Pre-LCI AHL-Xenon
      05-23-2013, 03:18 PM   #13
pweber84
pweber84's Avatar
Germany
49
So self-levveling doesn't work?
      05-23-2013, 03:27 PM   #14
ChrizLoud
ChrizLoud's Avatar
Sweden
43
Exactly. It does not even go up and down when you start the engine/turn on the lights.
Auto_LWR active etc. cant find any faults in coding, removed the AHL from the VO etc.
      05-23-2013, 04:12 PM   #15
pweber84
pweber84's Avatar
Germany
49
Send me a part number of this FRM3 module, I will check something.
      05-23-2013, 04:26 PM   #16
ChrizLoud
ChrizLoud's Avatar
Sweden
43
BMW NR. 61359209008
      08-07-2013, 04:21 AM   #17
ChrizLoud
ChrizLoud's Avatar
Sweden
43
Still having problems with auto leveling. Sorted everything else out.
Is the problem maybe different wiring?
To clarify i went from PRE-LCI AHL ---> LCI Bi-Xenon without AHL.
      09-02-2013, 01:52 PM   #18
konstant
Drives: E90 330xD
Try to add +MUEG to FA and don't change manufacturing date.
I also have a problem with FRM3. I have preLCI e90 and changed headlights to LCI also FRM to FRM3.
After that I have some problems:
1) Taillights
Voltage on outer parklights lower than on inner. I think it is
PWM_SL_1_FKT_PARKL parameter, but didn't change it yet.
Brakelights shine bright like a diamond. Two sections works instead of one + one with emergency braking.
Dont know where is this parameter.
2) Additional turn indicators doesnt work. I found parameters only for BLK_H and BLK_V and where is side indicators I cant find.
      09-03-2013, 01:29 AM   #19
ChrizLoud
ChrizLoud's Avatar
Sweden
43
Smile
Since i have a FRM3, after som googleing around it looks like +MUH2 (or +MUEH) is the right way to go for me, +MUEG is for FRM2 (or +MUEB)
Thank you for this. I will try this out and get back ASAP.
Regarding you problem: Have you re-wired the cables to the tallights?
      09-03-2013, 07:43 AM   #20
konstant
Drives: E90 330xD
I still have preLCI taillights. As I know re-wiring needed for inner lights, they works properly. All troubles with outer lights.
+MUEB didnt take effect on my FRM3, turn indicators blinked fast first time and bixenon didnt blink.
I also will try your parameters.
Update:
Taillights
PWM_SL_1_FKT_PARKL
-Solved with changing of this parameter.
I dont understand why side turn indicators not works. Wiring in WDS the same on preLCI and LCI. With FRM1 they works.
I cant find it in DIS and in fsw_psw
I didnt rewire headligts after changing preLCI xenon non adaptive to LCI xenon non adaptive. Vertical leveling works good.
      09-09-2013, 09:33 PM   #21
Dinan335Turbo
Dinan335Turbo's Avatar
Drives: 335 Coupe Black/Black
I'm planning on doing a lci taillight retrofit on my '07 (production 10/2006) 328i e91 wagon and I need to know what part number FRM3 module I need ?? My car has factory xenons.
--2007 E91 Touring Wagon--Black on Black--DailyDriver
--2007 E92 335i Sport Coupe--Black on Black--Because Racecar
      09-10-2013, 02:22 AM   #22
ChrizLoud
ChrizLoud's Avatar
Sweden
43
Update:
Taillights
PWM_SL_1_FKT_PARKL
Thank you!
Nice it got solved with you taillights.
Can it be that my Side fender indicators are LED and the FRM3 thinks its a bulb out problem and shuts it off even if i coded the bulbchecks out? (maybe the FRM isn't that smart)
Auto leveleing Wiring is different between non and adaptive so i found the problem there,need to re-pin and add 2 wires to each head light from FRM
You dont need to change the FRM if you dont want to. Just code out the bulb errors on the old one and you good to go. If you want the welcome lights you will need to change to a FRM2 or FRM3 marked XE or XENON (AHL if you have adaptive headlights)
Tags
frm frm3r nfrm
