Cobb Stage 1 race gas maps?
05-14-2013, 02:01 PM | #1 |
104
Rep 919
I am currently running the Stage 1 aggressive map all I have is a dual cone intake and the Cobb AP. So if I go to the track and throw in 5 gallons of MS109 are there any maps to take advantage of the race fuel? Or should I just go pump 93 for consistent runs I imagine running more boost without intercooler and downpipes would just heatsoak the motor.. Any advice?
Little pic below it's a 2007 Sparkling Graphite 6MT saddle brown interior I miss my old 335i though.. |
05-14-2013, 02:13 PM | #2 |
456
Rep 6,478
I would strongly advise you to not use the race mapping with a dci as your only mod, the advance and boost characteristics will not play nice with your motor. As you speculated, the OE downpipes and intercooler aren't up to the task, an enormous amount of heat and backpressure will build up. The race map requires a FBO car to be in pretty good shape to run well, so a more or less stock motor won't fair well. You could easily nuke your primary cats, or worse.
Edit: Great call with SB as the interior though!
E88 N54 Alpinweiss/Coral Red/Motiv HTA 3586r Tial .82AR/Other stuff...652WHP
F30 N55 XDrive EBII |
05-14-2013, 02:27 PM | #4 |
456
Rep 6,478
That's a good point, but will the car be able to hit those timing targets on OE downpipes and intercooler? I'd imagine it will fall flat on its face quite quickly if the ambient temps aren't frosty.
05-14-2013, 02:39 PM | #5 |
196
Rep 6,136
Shouldn't be too much of a problem. You normally need to worry about that when you start playing with load targets (boost), as that will have an effect on IAT/backpressure. I'd say it's worth the OP giving it a shot, might as well take advantage of the octane
05-14-2013, 03:07 PM | #7 |
70
Rep 2,626
you can copy aggressive timing if you are running over 100 octane no problem.
With that said, at the track, you will quickly heat soak your intercooler and what happens is your DME will start pulling timing (based on IAT timing compensation tables), so basically you won't be hitting your timing targets anyway. If you are going for multiple laps, I suggest you run the race fuel anyway for consistency and to protect your engine. We tend to forget that one or two pulls on a highway are very different then the hell we put the engine through on a track.
'18 F80 M3 Comp 6MT - Stock
'07 E92 335i 6MT- HP650, inlets/outlets, ER FMIC, VRSF CP, LPFP stg2, CSF rad, 'is Aux rad, ER OC, Ohlins, M control arms, eibach front sway bar. '05 C55 AMG SOLD - '22 Tesla M3P | '10 E92 335i M, 6MT | '07 E90 335i, PTF COBB E50, FBO, HFS4 |
05-14-2013, 03:08 PM | #8 |
70
Rep 2,626
Wait a second are you going for a drag strip or a closed loop track?
05-14-2013, 03:10 PM | #9 | |
177
Rep 2,301
'07 335I w/ Mods
'13 X1 Stock '11 X3 K&N |
05-14-2013, 03:32 PM | #10 |
104
Rep 919
1/4 mile track, so from what I gather don't go beyond Stage 1 Aggressive. I live in FL so it will be hot out already. I will just save the money I would waste on race fuel and put that towards an intercooler. I just had my water pump and thermostat fail so there goes $1,200..
05-14-2013, 03:36 PM | #11 | |
70
Rep 2,626
05-14-2013, 04:24 PM | #12 |
Rep 66
if ur worried about heat soak just bring one of these with some cold water water/rubbing alcohol mix and spray down the IC before each run - super cheap haha.
AW E90 335i
05-14-2013, 09:36 PM | #13 |
177
Rep 2,301
kindda causes surface rust after awhile. Use pure cold water for the same effect- the rust.
'07 335I w/ Mods
