Seatbelt chime disable on start
05-14-2013, 11:35 AM | #1 |
99
Rep 254
Drives: 2022 M3, 2023 X3
By Habit / muscle memory, I always start the car and then put on my seatbelt. So I coded a few things including disable of driver seat belt chime (ABG: SBR_FAHRER_1). That works if you remove it while driving but it still 'gongs' four times when starting the car. Is there any way to fix that?
MINE: 2022 M3Cx, Sky Grey, Driv/Exec/Park/Laser
1/26 Ordered, 4/26 Prod, 5/4 Assembly, 5/9 Port, 7/11 Transit, 8/3 Port, 8/18 Dealer, 8/25 Delivered WIFE: 2023 x3 m40i |
05-14-2013, 03:34 PM | #2 |
32
Rep 411
Are you sure it's the seat belt gong and not the key in ignition gong when doors are open?
Btw, did you also set CC_GURTWARNUNG_1 to nicht_aktiv? |
05-14-2013, 08:08 PM | #3 |
99
Rep 254
Yah forgot to mention I also coded the disable chime when key in but door is open (KOMBI: CC_ZUENDSCHLUESSEL). I didn't do anything for the one you mentioned. I'll see if that shows up in the ABG module. Thanks, hopefully thats it.
05-24-2013, 04:54 PM | #4 |
44
Rep 436
Yeah I just had coding done on my E92 where they coded out the seat belt chime. I like it. However, when I go to start the car, if my seatbelt is not fastened before I start the car I still get 3 'gongs' upon start-up. I don't think it use to be this way before I did the coding. I can't remember for certain.
05-24-2013, 06:05 PM | #5 | |
99
Rep 254
01-04-2015, 02:36 PM | #8 |
Rep 23
Hello. I have 2008 BMW 320 (e90). My problem is with seatbelt and airbag light when someone sit in passenger seat.. Dealer didnt go for a recall mat sensor so i found another solution, to buy a bypass emulator, to keep the computer to think that seat is always occupied. Everything worked fine, until someone was sitting there, in moment when noone was there - seatbelt light is on and that stupid noise to put on seatbelt.. I found a code to remove that seatbelt chime (SBR_BEIFAHRER_1 and set it to nicht_aktiv in ABG module with NCS Expert..) Okey, the sound is now gone, but the light is still on while noone is there. I dont want to always put in passenger seatbelt while im driving alone to get rid of the seatbelt light, so i wanted to ask is there some kind a code to disable that seatbelt light? Every help would be appreciated.
01-04-2015, 03:15 PM | #9 |
93
Rep 713
yes, there is, find aline with OC3 in it and set to nicht_aktiv, then disconnect a mat sensor, a connector under the passanger's seat. Next move it to clear a code using INPA. That's it, no more light on your dash.
01-06-2015, 12:57 AM | #10 |
Rep 23
I found a line OC3_1 and GK/OC3/POL but those lines are already set to nicht_aktiv by default...
01-06-2015, 01:06 AM | #11 | |
Rep 23
Is there another way to disable that light? |
01-06-2015, 04:07 AM | #12 |
93
Rep 713
Emulator is not necessary, are you sure you have a mat disconnected? There are two connectors under the seat, did you clear codes in INPA?
set this line to nicht_aktiv too SBE1_1_CD |
01-06-2015, 08:27 AM | #13 | |
Rep 23
Do i need to clear codes in INPA if car doesnt show any faults? Okey, i`ll set this line too to nicht_aktiv. |
