BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Cosmetic and Lighting Modifications (exterior/interior) > Extremely Cheap LCI Halogen Angel Eye LEDs?
      05-12-2013, 02:33 PM   #1
inline6ix
Drives: Deep Green E90 325i
So some people consider upgrading the LCI halogen angel eyes with a bigger, higher wattage bulb such as this one:
http://www.consumabulbs.com/files/bdet.php?id=72
So, with that, I can tell that the LCI Halogens use a "BA9S" type bulb. What if.. I bought an LED "BA9S" replacement bulb such as this one?
http://www.superbrightleds.com/morei...FYHe4Aodc1kA8g
I can assume I'll get bulb errors since I'm already dealing with them for my license plate lights, but if I can code out the bulb checks myself, shouldn't these bulbs work?
18" Staggered Style 189 - BMS 15mm - CF Grilles - LCI Headlights - BMW Performance CF Intake - 12" Blaupunkt Subwoofer
      05-12-2013, 06:15 PM   #2
wdeerfield
A family of bimmers
2747
Drives: '18 G01 X3M40i
you get what you pay for. inb4lux
2018 PB/Black G01 X3M40i | 699M | ZDA | ZPP | ZPX | Maxton front lip | X3M vents | 15mm Spacers | Diamond G20 style grills
      05-13-2013, 03:38 AM   #3
VTECaddict
Where'd my VTEC go?
VTECaddict's Avatar
481
Drives: 06 330i 6MT
That's not the angel eye bulb.
AW/Terra | ZSP | ZPP | ZCW | iDrive | CA
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit
M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear
      05-13-2013, 11:07 AM   #4
LuxAngelEyes
BimmerPost Supporting Vendor
LuxAngelEyes's Avatar
469
Drives: BMW
that will not work since the bulb is fixed into the stock reflector. As well that "LED" bulb will be be 2-3 times dimmer then the stock bulbs in all honesty. www.superbrightleds.com really should call themselves SuperDimLEDs since most of their products are not good
      05-13-2013, 12:09 PM   #5
BOBKUR
20
Drives: 2008 E 90
JUNK!
      05-13-2013, 02:22 PM   #6
raj55
Sweden
28
Drives: E91 2009, 320i
The 20W BA9S is not good since it will burn your bulb housing or reflector. Use 10W BA9s, same as the original.
Yes it is possible to remove the old bulb from the housing (with some difficulty) and mount a new 10W BA9s.
The LED BA9S that you have linked is a poor performer.
