Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > Apex EC-7 18inch hankook Rs-3
      05-06-2013, 10:55 AM   #1
rodgerdodger
rodgerdodger's Avatar
48
Drives: e92 & F01
Does anyone have photos of Apex EC-7 in 18in wheels on a jet black E92 with with hankook rs-3???
      05-06-2013, 11:01 AM   #2
kaede
81
Drives: 2008 E90 M3
Your are asking for something rather specific here... check out the couple of threads regarding the launch and group buy for the EC-7. I don't remember specifically a black e92. Also, why specifically hankook rs-3? As long as the wheel spec and tire spec is good it doesn't make too big a difference in aesthetics. Wheel does come in three colors though, silver, gunmetal (anthracite), and black. Good Luck!
94' NSX - Garage Queen
97' Integra Type R - Track Warrior (Sold)
01' BMW E39 M5 (Sold), 2x 02' BMW E39 M5 (Sold & sold)
08' E90 M3 6MT - DD
13' W212 E63 AMG Wagon
      05-07-2013, 01:16 AM   #3
Expert@ApexWheels
BimmerPost Supporting Vendor
Expert@ApexWheels's Avatar
3546
Drives: M3
Not exactly what you requested, but pretty close. Jet Black e90 M3 with 18x10" ET25 squared Anthracite EC-7s wrapped in 275/35/18 Hankook R-S3s.
Hopefully that helped!
      05-07-2013, 02:07 AM   #4
rodgerdodger
48
Drives: e92 & F01
THANK YOU David! this does help. What do you recommend for a 2007 335i E92 off set? Whats the most aggressive setup I can run?
      05-07-2013, 06:14 PM   #5
Expert@ApexWheels
3546
Drives: M3
A customer just sent us some photos of his Jet Black e90 non-M with Race Silver EC-7s wrapped in Hankook R-S3s, which would give you an even better idea.
This customer is using the 18x9.0" ET31 front with a 245/40/18 R-S3, and the 18x10" ET43 rear with a 285/35/18 R-S3 and 5mm spacer, with a rolled rear fender.
If you are looking for the widest wheel combination that is most flush for your e92 335i, we would recommend the 18x9.0" ET31 fronts and 18x10" ET33 rears. You can run the 245/40/18 and 275/35/18 street tires, and you should not need a fender roll like you would have with the 285/35/18 that is pictured above. This would also sit more flush to the fender than the shown setup by 5mm as well. This would be the most wide functional setup that you can put on your e92 335i to get some nice rear traction with a 10" wide wheel.
      05-07-2013, 06:23 PM   #6
ASAP
ASAP's Avatar
10188
Drives: '23 X3 M40i
Very nice Dave... what offset and wheel width do you recommend in both the front and rear for a 335i coupe that wants the tires to sit even with the wheel well? I would be running PSS, RE-11 or Direzzas with a 235 front / 265 rear?
Thanks just noticed you answered above!
2 x N54 -> 1 x N55 -> 1 x S55-> 1 x B58
      05-08-2013, 12:50 AM   #7
rodgerdodger
48
Drives: e92 & F01
THanks Dave,
Also I will be tracking the car, so would going this aggressive be the best suited for the track? In the case that I decide to go with a BBK with the above set up you mentioned clear?
      05-08-2013, 10:11 AM   #8
skyguy
skyguy's Avatar
Drives: 2007 e90 335i 6MT
That 335i above is mine, and the 18x9et31 will clear stoptech, brembo, and apparently Forge 380mm setups by quite a bit (more than my 19" vmr vb3s did). The trackability of the setup will depend on rideheight and springrates you're running. With adjustable coilovers its definitely trackable with some camber in the front or especially if you're willing to adjust height for track day. I don't think Apex suggests the 245/40/18 because of sidewall height in most applications, but a 255/35/18 would be less sidewall and a little bigger contact patch depending what your priorities are...
      05-08-2013, 11:00 AM   #9
rodgerdodger
48
Drives: e92 & F01
Thanks for the input
      05-09-2013, 01:08 PM   #10
Expert@ApexWheels
3546
Drives: M3
Originally Posted by rodgerdodger View Post
THanks Dave,
If you have camber plates and are able to dial in at least -2.5 degrees of camber, you can actually run the 255/35/18 tire with the 18x9.0" ET31 front wheel. This is our recommended track setup for the fronts, with a 275/35/18 rear with a 18x10" rear.
Awesome feedback, thanks for your input!
      03-27-2014, 04:06 AM   #11
rodgerdodger
48
Drives: e92 & F01
For the 10 inch rear which offset do you recommend?
      03-27-2014, 11:25 AM   #12
Expert@ApexWheels
3546
Drives: M3
For a pre-LCI e9x non-M, you can fit the 18x10" ET33 EC-7, while the LCI models would use the 18x10" ET43 EC-7 due to the wider rear tract which results in less fender clearance.
      03-29-2014, 10:45 PM   #13
mustangivore
33
Drives: 2011 335i E90
What staggered 18" ARC-8 fitment would you recommend for an E90 LCI lowered on H&R Sport?
MHD Stage 2+ FBO
      03-31-2014, 05:23 PM   #14
Expert@ApexWheels
3546
Drives: M3
The recommended ARC-8 fitment for an e90 LCI would be the 18x8.5" ET38 and 18x9" ET42 with 235/40/18 and 255/35/18 sized tires if you are not willing to roll the rear fenders. With rear fenders rolled, you can fit the 18x9.5" ET35 rear wheel with the same 255/35/18 sized tire, which provides a concave rear wheel that many customers prefer. Without rolling the rear fenders, this fitment would cause the rear tires to rub onto the fenders.
      04-01-2014, 02:46 AM   #15
mustangivore
33
What a clear & comprehensive answer. Thanks! Would the 18x9" ET42 be noticeably more concave than my stock rear 18x8.5" ET39 style 287's?
I definitely want good concavity if I purchase them, but I don't know anyone who can roll the rear fenders. Any shops in MD/PA that anyone can recommend to roll fender?
MHD Stage 2+ FBO
      04-01-2014, 01:12 PM   #16
Expert@ApexWheels
3546
Drives: M3
This is the face that the 18x9" ET42 ARC-8 has:
It has a very slight concavity to it, but not a deep concavity like the 18x9.5" ET35 ARC-8. We do not know any shops in MD/PA in particular, but a good body shop should be able to successfully roll the fenders for you.
      04-02-2014, 09:43 PM   #17
mustangivore
33
...It [18x9" ET42 ARC-8] has a very slight concavity to it, but not a deep concavity like the 18x9.5" ET35 ARC-8. We do not know any shops in MD/PA in particular, but a good body shop should be able to successfully roll the fenders for you.
Sorry for late reply. Thanks again for the valuable info. For me, it's clear I would go for 9.5" et 35 over 9" et42. I also realize now that I want to get the rear fenders rolled and just need to make a better effort to find someone. Opens up so many more options. Didn't think about fitment issues when I lowered the car. Was concentrated on looks and suspension and ride. Live and learn
Could there be an even more aggressive offset depending on how much it's rolled or are you basing your recommendations on knowledge/experience for typical fender rolls? Thanks again for your help.
I think I'm finally starting to narrow down what I want. Still have not given up on deep dish style but probably 19" are no longer a possibility for me. So for concavity I think I found my solution
For deep dish I want to research some more...heard some disadvantages but I'm pretty ignorant about that type of wheel.
MHD Stage 2+ FBO
      04-03-2014, 06:08 PM   #18
Expert@ApexWheels
3546
Drives: M3
The 18x9.5" ET35 with a 255/35/18 street tire is about as aggressive as the LCI can take in the rear without pulling the fenders or modifying the rear fenders with fender flares. The lower offset 18x9.5" ET22 has the same concave face as the 18x9.5" ET35 so there isn't anything to gain by going with a lower offset, more aggressive wheel unless you wanted the wheels to poke past the fenders.
      04-04-2014, 12:07 PM   #19
mustangivore
33
The recommended ARC-8 fitment for an e90 LCI would be the 18x8.5" ET38 and 18x9" ET42 with 235/40/18 and 255/35/18 sized tires if you are not willing to roll the rear fenders. With rear fenders rolled, you can fit the 18x9.5" ET35 rear wheel with the same 255/35/18 sized tire...
Thanks for all that useful info. I'm going to get the rear fender rolled, so I'm considering ARC-8 with these specs: 18x8.5" et38 front, 18x9.5" et35 rear.
Q1: With 235/40/18 up front and 255/35/18 in rear, the tire diameter difference is 1.472%. Is that under acceptable limit? 225/40/18 would be almost identical to rear in diameter, but do you not recommend that because it might be stretched up front? If I wanted to do PSS which measure ~ 10mm wider than most tires, would you still suggest 235/40/18 or would you recommend 225/40/18? I was thinking 8.5" et38 ARC-8 with 225/40 PSS and 9.5" et35 ARC-8 with 255/35 PSS would look noticeably wider and more aggressive than my stock. What do you think? And thanks AGAIN.
Q2: Going from stock 8" to ARC-8 8.5" wheel up front gives "10mm LESS clearance on the strut side, and the outside edge of the wheel will EXTEND an extra 2mm". Since you recommend 8.5" up front I assume I have sufficient space on strut side to give up additional 10mm? Can you comment on that?
MHD Stage 2+ FBO
      04-04-2014, 01:42 PM   #20
Expert@ApexWheels
3546
Drives: M3
The 1.472% difference in diameter is acceptable, but the 225/40/18 can also be used if you would prefer a similar overall diameter. We usually recommend the widest tires that is able to fit on a car with the particular wheel size and offset, and the 235/40/18 happens to be the widest tire that would fit on the front of your e90 LCI. The 225/40/18 will be a little bit stretched, but if you are okay with not getting the widest tire on the front, it can work.
Yes, there is sufficient space on the strut side to fit the 18x8.5" ET38 ARC-8 wheel on your e90 LCI. There is adequate clearance from the wheels and tires to the OEM struts of your car.
      04-04-2014, 01:58 PM   #21
mustangivore
33
Would the little bit of stretch be almost negligible if it's a PSS? I like idea of having extra sidewall with 235/40 but worried that 235 PSS measure like a 245 and might rub. Do your wheel and tire recommendations take into account that I'm lowered on H&R Sport springs? I appreciate your time.
MHD Stage 2+ FBO
      04-04-2014, 02:24 PM   #22
Expert@ApexWheels
3546
Drives: M3
The little bit of stretch is still present with the PSS, though the wheel protector on the sidewall does allow for a little more wheel protection even when using a smaller tire. The PSS has a slightly larger sidewall, but that does not mean that it fits like a full tire size larger. Yes, this does take into account your H&R Sport lowering springs, as long as you are not at an extremely low ride height the fitment recommendation would still be the same for any e90 LCI car.
