2010 2011 BMW 5 Series Forum F10 F10 Technical Topics DIY Guides & Discussions F10 rear bumper removal
      05-01-2013, 07:56 PM   #1
M535
PinOyBIMER
M535's Avatar
Pitcairn Islands
21
Drives: 535
I had a shop intall my diffuser and it cost me $200. Im not happy with the fitting and they said its a vendor molding problem. I cant afford another $200 to uninstall it.. So im looking for any help on how to remove the reAr bumper..
Any help will be much appreciated.
      05-02-2013, 03:17 AM   #2
grimlock
716
Drives: F10 N52B30@255PS
Easy. Take off plastic cover piece inside trunk that slips under the seal, take off trim partial inside trunk partial over rear lights. Remove 3 8mm nuts holding outer lights. You should be able to see the actual pins/bolts holding the bumper, in several places directly under, by wheel well, under lights etc. Straight forward
Tools: 8mm (hex) socket, pry for pins
      05-02-2013, 08:08 AM   #3
M535
PinOyBIMER
M535's Avatar
Pitcairn Islands
21
Drives: 535
Thanks.. I dont wanna miss anything.. Any pics or video.. Im a visual kinda guy on learning..
      05-02-2013, 08:47 PM   #4
grimlock
716
Nope but if you really need it, you can search google for rear bumper removal and there are some manuals online for e60, e90 etc. to give a visual idea.
      05-02-2013, 10:04 PM   #5
MELLOWYELLOW06
MELLOWYELLOW06's Avatar
331
Drives: 2020 M8 & 2022 X& M50i
does this have to be done to install m5 diffuser?
      05-03-2013, 12:02 AM   #6
M535
PinOyBIMER
M535's Avatar
Pitcairn Islands
21
Drives: 535
Im not sure about an M5 but im placing a vorstainer replica diffuser and you need to remove bumper to install it..
      05-03-2013, 12:06 AM   #7
M535
PinOyBIMER
M535's Avatar
Pitcairn Islands
21
Drives: 535
I've already removed the bumper.. Thinking about doing a diy with pics for everyone here...that would cover everthing from the tail lights removal to rear bumper reflectors..
      05-03-2013, 12:07 AM   #8
happymeal
Drives: F10 550i
bump for rear bumper DIY???
      05-31-2013, 01:13 PM   #9
Bobby_Drake
Bobby_Drake's Avatar
390
Drives: '16 X5M
Finally got the Vorsteiner style diffuser installed. Fitment is about 95%.
Notice that on the left side, fitment is perfect. However, on the right side, it appears that there is a small gap. Noticeable, but for a price difference of $700, I'm not complaining. Fitment is stable and not loose. You cannot just remove it. It's secure. Bumper needed to come off for proper installation. I tried to install myself but you really cannot get the metal fasteners to properly clip on unless you get the bumper removed. very manageable if you have help but if you are by yourself, then just get a shop to do it. I got a good deal on a shop in SD. Cost me $130 total after everything, including a car wash. To those SD people interested, PM me and I'll give you the contact info.
Thanks to George (Shihwei) as well for the hook up!
Excuse my droid, lens has some spot so you can see the spot on the images. I took a close up of the remus muffler as well.
      05-31-2013, 01:56 PM   #10
STOOF
Sunburned
STOOF's Avatar
238
Drives: '16 F83 M4 Convertible 6MT
2013 BMW 535i  [0.00]
Nice Bobby!
I just installed mine today too. Did it myself. And i have the same gaps as you but on both sides. Oh well. Id say its like 85% fitment.
Now i just gotta get my exhaust done.
Thanks for this DIY M535, it helped a lot!
2016 M4 Convertible 6MT - SO/SO
2013 535i 6MT MSport - Retired
2011 Z4 SDrive35i 6MT- Retired
      05-31-2013, 02:54 PM   #11
M535
PinOyBIMER
M535's Avatar
Pitcairn Islands
21
Drives: 535
Originally Posted by STOOF View Post
Nice Bobby!
You pm'ed me bro but you never replied to my pm.. I could have shown you away to close that gap near the tow huk.. If you get a chance to remove it again, you just need to gently force into those three little tabs attached to the bumper.. Gently with force lift and push up the bottom part of the diffuser.. You should hear it click in place and will sit there properly..
Note: it will seat there but might come off so you need to secure somehow..
GL.
      05-31-2013, 03:03 PM   #12
M535
PinOyBIMER
M535's Avatar
Pitcairn Islands
21
Drives: 535
Paint looks like a perfect match... And that pipes is looking sexxxxxxy!!
      05-31-2013, 06:43 PM   #13
Bobby_Drake
390
Drives: '16 X5M
M535, do you have a pic of your fitment? maybe I can get the shop to re-do it if I can show them that...
      05-31-2013, 07:00 PM   #14
STOOF
Sunburned
STOOF's Avatar
238
GL.
What do you mean, we had a little convo lol
I could push it in, but it doesnt click in. Maybe from when i was bending the tabs when i tried to install it with the bumper on? idk.
Its on there good. I bent all the metal tabs down after i put it on, so i dont think it could fly off. I also drilled a couple holes on the bottom where the oem clips held the diffuser so its attached there also.
      05-31-2013, 10:54 PM   #15
M535
PinOyBIMER
M535's Avatar
Pitcairn Islands
21
Drives: 535
Ahhh ok.. If your happy with it, then its all good..
      05-31-2013, 11:20 PM   #16
shihwei
20
Drives: F10 520d
Hi guys,
It seems like a lot of people have the same issue and our curstomers' problem is our problem. So I will try my best to see if we can resolve this together. Since I am unable to see the exact problem, except through pictures and talk to a few of you guys over the phone, it sounds like the imperfection happens right around where the tow hook cover is on the right side and and the respective position on the left. I believe member M535 had the diffuser on the bumper when it was off the car and it looked perfect; however, when the bumper was installed back on the car, the metal tab was pushing against something inside, causing this gap that most people are seeing. The following is a blow-up diagram of the F10 M-Sport rear bumper and it looks like the metal tabs are pushing against part 7 Bottom Center Guide.
If possible, please have this part removed as the purpose of this part is to push against the bumper from the inside to make it firm; however this causes the bumper to lose some of its flexibility. After doing so, it should create some room for the metal tabs and allow the bumper cover to move a little bit in order to make the fitment better.
STOOF, since your diffuser seems to have issues on both sides and you still need work done on your exhaust, would you mind helping all of us out by trying this?
The diffuser was sold without the metal inserts in Asia; it was only added with the intention of easier and more secure installation for our U.S. customers; however, it seems to be causing more problems. As all of you can see that the diffuser fits perfectly to the bumper when it is not on the car, I really think the problem can be solved with different installation techniques.
I am glad that we are having a good discussion on this forum; and hopefully with proper adjustments, all of these can look perfect!! Please feel free to PM me to discuss. Thank you all.
      05-31-2013, 11:38 PM   #17
M535
PinOyBIMER
M535's Avatar
Pitcairn Islands
21
Drives: 535
I had exactly the same fitment with stoof.. But here it is after i did my own installation: took some force to push in to those 3 tabs under the tow hook..
      05-31-2013, 11:51 PM   #18
STOOF
Sunburned
STOOF's Avatar
238
Ill mess with it more this weekend and see if I can get it to click in.
      06-01-2013, 12:31 AM   #19
M535
PinOyBIMER
M535's Avatar
Pitcairn Islands
21
Drives: 535
Gl.. I hope it turn out good..👍🙏🙏👍👍
      06-01-2013, 08:02 PM   #20
Bobby_Drake
390
Drives: '16 X5M
M535, did you remove the piece #7 frm the diagram to make the diffuser snap into place?
      06-01-2013, 11:05 PM   #21
M535
PinOyBIMER
M535's Avatar
Pitcairn Islands
21
Drives: 535
No sir... Just pushed it up to snap on.. I secured it tho cuz is seems like it might pop off..
      06-02-2013, 12:12 AM   #22
Bobby_Drake
390
Drives: '16 X5M
now that I know it can be done to make it fit perfectly, it is bothering me. Did you have to take the whole bumper off again? I am thinking of taking it back to the shop...
5post
