BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Photo/Video/Media Gallery > Dual Stage Brake lights
      05-25-2005, 08:03 AM   #1
Broken1
Addict
Broken1's Avatar
203
Drives: 2024 X5 40i M-Sport
Does any one have a pic of the dual stage brake lights working?
I wanna see "how much the driver behind would intuitively know what's happening"
      05-25-2005, 08:41 AM   #2
E90Fleet
South Africa
1312
Drives: BMW
The brake light is just divided into 2 sections
Whit heavy braking both sections turn on, so you got a big red light
With normal braking only the outer section tuns on, and you have a normal size red light
Other drivers wont really know there is anything different, they will just see more red light
      05-25-2005, 08:53 AM   #3
Broken1
Addict
Broken1's Avatar
203
Wouldn't it be more beneficial to just have more red light always then? Then drives behind would always see it, would always have this intuition to brake harder and then i wouldn't be here asking stupid questions?
      05-25-2005, 09:09 AM   #4
E90Fleet
South Africa
1312
Drives: BMW
I think it has to do with regulations for normal brake lights and the amount of light they give off, and according to the USA manual it also engages the rear foglight bulb
      05-25-2005, 09:24 AM   #5
Tierfreund
Tierfreund's Avatar
21
Drives: E90 330i
Are you really asking?
Then if it would always have the big bright lights on, you´d always asume the car in front of you is braking normally since you´d seen it light up bright so many times before.
Hence you´d be back to normal braking lights, just bright ones.
Just like the boy that called "Wulf" once to often...
      05-25-2005, 09:45 AM   #6
abdulh
abdulh's Avatar
Drives: E90 320iSE
are these standard on all e90's? how can i test it? can i park up against a window and lightly press the brake, and then press it hard and see the difference or is it related to speed?
      05-25-2005, 09:48 AM   #7
Tierfreund
Tierfreund's Avatar
21
Drives: E90 330i
Yes, it´s standard on all markets where the authorities allow it. (Otherwise it´s diabled via Software). Late E46 had it as well.
Have someone drive behind you AT DISTANCE and brake normally. Then go back to spped and brake hard.
Then he should be able to tell you.
      05-25-2005, 11:26 AM   #8
Broken1
Addict
Broken1's Avatar
203
Here is a picture of it in the "hard breaking stage"
I think in the normal breaking stage only the outer one lights up...
