M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > Mechanical Maintenance - Break-in, Oil, Fluids, Servicing, Etc.
      04-28-2013, 09:27 PM   #1
ufgtrs2007
dentite
ufgtrs2007's Avatar
339
Drives: 718 GT4, M2C, JLU392, e92 M3
2013 BMW M3  [0.00]
2013 BMW M5  [0.00]
DIY Oil Change?
Hi Guys,
I've been looking for a DIY for our M5s but I can't locate one. Has anyone done their own mid-interval oil change? And if so, are there any particular steps/differences I need to be aware of?
I've changed the oil on all my previous cars, but never an M engine. Thanks guys,
Haysam
      05-12-2013, 11:33 AM   #2
bm5bullit
bm5bullit's Avatar
237
Drives: 2021 BMW M340i
I have been asking them the same question. I have been changing the oil/filter on my cars for many years including my previous E60 M5. I guess I will take photos when I do the oil change on my M in the next few months.
2021 M340i
2020 X3 M40i - her car
2019 M5, AW, DP's, MSR CAI, BM3, SOLD
2020 Chev. ZR2 Bison truck, Daily Driver
      05-12-2013, 03:27 PM   #3
johnsama86
18
Drives: 19" G05 40i
2013 BMW M5  [10.00]
Don't BMW Canada/USA do the oil fills for freee for 4 years ?
      05-17-2013, 01:16 PM   #4
bm5bullit
bm5bullit's Avatar
237
Only at the BMW service intervals of 7500 miles. I like to do one in between these intervals.
2021 M340i
      09-23-2013, 02:52 PM   #5
bm5bullit
bm5bullit's Avatar
237
DIY LOF Change
I guess that no one has done this or that they just did not document the procedure. I will be a guinea pig.
2021 M340i
      09-24-2013, 11:29 PM   #6
bobafettt
bobafettt's Avatar
Drives: 2014 M5 CP
Isnt it 10k?
I also like to do more frequent changes.
Wonder if she'll have the clearance to make it up the Rhino ramps.
      09-25-2013, 05:11 PM   #7
greentrbo95gst
greentrbo95gst's Avatar
1217
Drives: 21 M5 Comp
Originally Posted by bobafettt View Post
Isnt it 10k?
Not with H&R springs
Current: 21 M5 Comp, 17 X5M, 06 M3, 14 Ferrari FF, Tesla Model S Performance.
      09-27-2013, 03:01 PM   #8
ufgtrs2007
dentite
ufgtrs2007's Avatar
339
2013 BMW M3  [0.00]
2013 BMW M5  [0.00]
I've purchased the filter and oil, I'm about 3k away from doing my mid cycle change. I now know that the filter kit is the same as the one for the X5M/X6M, which have a drain plug in the filter housing. Our M5 don't so we only have to remove one drain plug, remove and replace filter then fill to max. It should be a very simple procedure, I plan to post a DIY after I do the change.
      11-02-2013, 05:03 PM   #9
nynd
174
Drives: X7 M8 Convert
Anyone post a "How to" for this? Can you evac the oil or do you drain?
      11-02-2013, 05:40 PM   #10
bobblehead
bobblehead's Avatar
256
Drives: warp speed
drain
      11-04-2013, 02:42 PM   #11
nynd
174
Thanks Bobblehead!
      11-04-2013, 03:10 PM   #12
CFisher
Drives: F10 M5 Black Sapphire
Ha! Just to be obtuse...I've sucked (evac'd) the oil out of my previous cars...not sure how I'm gonna do that w/this one though. Kinda waiting for someone else to post the DIY too.
      11-17-2013, 03:46 AM   #13
Racer Louis
11
Drives: 2019 M5
DIY Oil Change
Me too! On my previous M5s I've used a vacuum pump through the dipstick tube. On each car the pickup tube went to the low point of the oil pan and removed all but the last couple of drops of oil. With the oil filter mounted on the inner fender an oil change was a 15 minute (and clean) job. I'm waiting for someone to find a way to do the same on the F10.
I've spoken to a couple of BMW techs and they say draining the oil from the drain plug isn't a problem (especially if you have a lift) but removing the oil filter is kind of messy because it was relocated to under the engine, reached from below. The E60 M5 had a drain plug on the filter cover, the F10 covers don't (or didn't-see below). One tech said after draining the oil pan he slightly loosens the oil filter and lets the oil drip off the housing for 10 or 15 minutes and then carefully unscrews the filter cover. He said it will still drip oil on the structural reinforcement panel (the metal panel under the engine) but not as much as trying to unscrew and remove the filter when you've drained the oil pan.
There may be an improvement for this last (oil filter removal) problem. The part number for the oil filter cover has been changed and the old part number supersedes to the new part number, which means they should be interchangeable. I've ordered a new one, I hope it has a drain plug! I'll be picking it up Monday.
      11-17-2013, 08:34 AM   #14
bobafettt
bobafettt's Avatar
Drives: 2014 M5 CP
Thanks for the info. Hope the new part is an improvement.
      11-19-2013, 07:48 PM   #15
Racer Louis
11
Drives: 2019 M5
Unhappy Follow-up on oil filter cover part number change
[QUOTE=Racer Louis;14987035]Me too! On my previous M5s I've used a vacuum pump through the dipstick tube. On each car the pickup tube went to the low point of the oil pan and removed all but the last couple of drops of oil. With the oil filter mounted on the inner fender an oil change was a 15 minute (and clean) job. I'm waiting for someone to find a way to do the same on the F10.
There may be an improvement for this last (oil filter removal) problem. The part number for the oil filter cover has been changed and the old part number supersedes to the new part number, which means they should be interchangeable. I've ordered a new one, I hope it has a drain plug! I'll be picking it up Monday.[/QUOTE
Follow-up:
I got the new oil filter cover, it doesn't have a drain plug! Drats!
Flying Ace4982.50
      11-19-2013, 08:13 PM   #16
CFisher
Originally Posted by Racer Louis View Post
Follow-up:
Well...thanks for the update. I've got a neighbor with a lift...guess I should stay friendly.
      12-29-2013, 09:02 AM   #17
GarbageMan
36
Drives: 2014 M5
So has anyone documented their experience yet? I just got my M5 last week, and will most definitely change the oil and filter at 500 miles, then take my oil (Mobil 1 0-40 European Formula) to the dealer and have them do the 1200 mile. I'll then do mine in between the dealer scheduled ones thereafter. Now I'm not being mean, BUT I both get a kick out of and get perturbed by the lack of DIY posts in this area on this forum. I own a Harley Davidson Street Glide and a Denali HD Duramax, and those forums can overwhelm a person with "how tos" and DIY threads/posts... Please don't post that "maintenance is included for 4 years/50k miles". Clearly, posts like that demonstrate a lack of understanding. I suppose I'm one of the few rednecks driving an M5... Just sayin...
      12-29-2013, 12:33 PM   #18
thebishman
495
Drives: ‘24 iX M60
Welcome.
I personally think that an oil/filter change at 500 miles when you'll be getting one at 1200 miles is overkill; YMMV. Also, at the 1200 mile service I think you'd be better off letting the dealership place the OEM M5 oil in the car; in fact they may refuse to use your Mobil 1. Regardless you could then do your own oil/filter change at 5K miles.
Take care,
Bish
      12-29-2013, 02:01 PM   #19
Racer Louis
11
Drives: 2019 M5
Originally Posted by thebishman View Post
Welcome.
Take care,
Bish
I too think the 500 mile change is overkill. You're also assuming that the breakin oil is the same as the regular oil and the same viscosity. I don't know if that's the case.
      12-29-2013, 02:46 PM   #20
GarbageMan
36
Drives: 2014 M5
Welcome.
Take care,
Bish
I've been doing this for 30+ years, and rebuilt a number of engines myself. Regardless of the sterility of BMW's engine build environs and process, there will be machining filament in the system. I want it out ASAP. As for the Mobil 1 0-40 synthetic, the dealer has no problem with it/it is acceptable. They have already agreed to use it when they do the scheduled changes; I just need to bring it to them. In short, what I am doing probably is overkill, but I am exponentially more anal-retentive than even the most partciular Americans. Just having to take the car to the dealer ticks me to no end. No tech can possibly excercise the care that I do with my own vehicle. I am simply relenting for warranty purposes.
      03-08-2014, 08:45 PM   #21
v3n0m
57
Drives: 2013 MCB M5
Just wondering if anyone's done this yet and if they have pics of the filter/drain plug locations. Thanks!
      05-07-2014, 05:03 PM   #22
ptt
11
Drives: M5
Bump. Has anyone changed their oil/filter? Sharing is caring...
Search this Thread:
Advanced Search
m5post
