The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > DIY: Replacing E92 Windshield Reveal Molding
      04-28-2013, 09:25 PM   #1
UTEE24
19
Drives: Jet Black 335i
I am posting a picture-oriented DIY guide to replacing the windshield reveal molding on my E92 coupe. You do NOT have to remove the windshield.
I think it is absolutely ridiculous that dealerships will try to scam people out of $1000 when this is a ~$30 + tax part and at most 1 hour labor job. And the 1 hour labor is rounding up from 30 minutes.
I would like to first say thanks to the posters of these threads, which provided valuable information and great insight on what to expect:
www.e90post.com/forums/showthread.php?t=723121
www.e90post.com/forums/showthread.php?t=523429
www.e90post.com/forums/showthread.php?t=573281
I purchased my rubber reveal molding from getBMWparts.com, PN 51-31-7-119-711. Thanks to Jason for providing such a great service.
First, gather the tools. A wooden pick is all that is needed to pry out the old rubber. I would not recommend using a box cutter or screw driver.
Here is what my reveal molding looked like:
Up close:
I started peeling the old rubber out at the front passenger bottom corner. Gently pry up the bottom rubber cover piece to get access to the bottom of the cracked molding. This was my start point.
Continue prying from the bottom to top, try to keep the old molding all in one piece.
Slowly continue prying, and round the corner.
At the stubborn glue points, use a wooden pick to help pry the glue gum off the car
Once the old piece is removed, use the WD-40 to clean the old glue off the paint. Use the glass cleaner to clean the glue off the windshield. I ended up not using the isopropyl alcohol.
Press the new reveal molding back in, starting at the top corner edge of the driver's side. Do NOT pull the adhesive backing yet! Fit the entire reveal molding in to the groove (all 3 sides) before pulling the adhesive sticker backing. Make sure the reveal molding is aligned perfectly with the car lines. I used the blunt end of the wooden pick to gently push the rubber down into the groove. Be careful not to stab the rubber and puncture it.
Press the center piece of the molding in. The passenger top corner edge may require some massaging to get the alignment perfect.
Work the molding all the way down. Once you're happy with the alignment, pull all 3 of the sticker backing to make the position permanent.
The windshield reveal lining is brand new again! This was a very easy DIY, with the total time being about 45 minutes, but that was me being super careful along the way. Next one would easily be under 20 minutes. (Hopefully there will not be a next one.)
Happy rubber molding!
Sorry for the double pictures.
Appreciate 9
      05-04-2013, 03:16 AM   #2
Spun Crankhub
965
Drives: 15 F82 *SOLD*
Great write up!
      06-01-2013, 12:25 PM   #3
jmftexas
14
Drives: E92 335 / F30 335i
Just did this, thanks for the write up! I had a pretty hard time getting the trim back in along the top of the windshield. I found that using an old credit card or gift card helped quite a bit in getting the trim seated properly. Looks so much better now.
      04-24-2014, 10:54 AM   #4
IK6SPEED
4490
Drives: BMW M3 / AH3
Thanks!!! Will try this, i was told that the whole windshield needed to be replaced but this is awesome.
      07-31-2014, 04:52 PM   #5
GTiceman
Parrothead
GTiceman's Avatar
137
Drives: E90 M3
2020 BMW X3 M40i   [0.00]
2009 BMW M3  [0.00]
Took me 26min from start to finish and includes cleaning time. Dealer told me they would need to remove the windshield and that it usually cracks when they do and I would be responsible for that. This was super easy and helpful.
FYI I used a trim removal tool to help seat the molding so I didnt need to risk the punctures
|e46 M3 Stahlgrau/Red| - Sold
|E92 335i BSM/Saddle| - Sold
|e90 M3 Space Gray/Fox Red/6MT|
See Garage for Mods
      07-31-2014, 05:02 PM   #6
GoRomeo
GoRomeo's Avatar
964
Drives: 330i, 135i
2008 BMW 135i  [9.50]
2006 330i  [6.75]
I need to do this too. Is not that bad yet. Not sure if I can DIY it myself. Any videos available?
      12-05-2014, 09:57 PM   #7
Fortyb
M-GAM3
Fortyb's Avatar
240
Drives: 2016 SO M3
Great write up just got finished. And only paid $29.00 for the rubber molding.
      12-10-2014, 02:13 PM   #8
AU335
AU335's Avatar
193
Drives: 2007 e92 335i
2007 335i  [0.00]
Fantastic writeup! Thanks so much! Did this over the weekend. So fast... so cheap...so much better looking now.
      12-10-2014, 02:32 PM   #9
Wolf 335
Wolf 335's Avatar
2341
Drives: 2007 E92 335i
Can't believe how badly it was cracked.
Was that cracked one original molding or was it replaced at some point?
      04-11-2015, 02:22 PM   #10
1QuikWS6
No 55mph
1QuikWS6's Avatar
1622
Drives: F32 435ix MSport
Excellent writeup
Just did this today - literally did take me only about 35min
Mine wasn't quite as bad as OP, so cleanup was minimal...
Now I'm good for another 46K miles
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
      07-16-2015, 10:02 PM   #11
slawless
20
Drives: 2008 E92 M3
Thanks for the encouragement. I replaced mine today. It really was easy. However I am a bit OC and I spent about an hour trying to remove every bit of the old glue.
      07-19-2015, 12:29 PM   #12
wnathan57
Drives: 2008 335i coupe
Great write up! I've been looking to do this for awhile now and just ordered my molding.
      07-21-2015, 07:01 AM   #13
jtswole
42
Drives: 335i
Mine was going good until the last corner, I cracked the windshield. I used a piece of wood and hammer to bang in the top and the last corner, I guess the wood was on the glass and it cracked. Other than that, it was easy to do.
      02-29-2016, 06:51 PM   #14
DaleT
23
Drives: E92 AW LCI 335i
AWESOME. just ordered the part. Thanks!!
      03-01-2016, 09:54 PM   #15
xyaaeg234g234
happy.
xyaaeg234g234's Avatar
138
Drives: 2009 e90 335i
Glad to hear I'm not the only one! I have an '09 e90 and only had to replace the top portion. The passenger side went in without issues but I couldn't for the life of me get the driver side to seat properly. I was smacking it with the handle of my pry tool with 4-6 layers of shop towel/microfiber cloth below it, I must've slipped and caught the top area of the windshield and got a nice big spider crack.
Thankfully I had already filed a claim and had an appt set for a replacement since it had some damage to it when I purchased the car - I called my ins and let them know about the additional damage and they said it did not matter since they already approved the claim, phew!
Super happy to live in Florida and have my windshield replaced for free from road hazard damage! Saved me about $400 through safelite.
'09 Jet Black E90 335i | BMS DCI | Forge DV | VRSF CP, DP, 7" FMIC, Exhaust | MHD Stg 2 / 93 Oct | Koni Yellow / H&R Sport | Mooooarrrrrr
this list is getting too long.....
      03-19-2016, 05:42 PM   #16
b1mmr
b1mmr's Avatar
319
Drives: 2008 335XI E90
Awesome, thank you! I noticed last week that mine was "up" in a few spots.
Formerly Ian_N54 - @b1mmr
      03-19-2016, 06:05 PM   #17
Abax335
Abax335's Avatar
79
Drives: 2008 BMW 335xi 6spd
can't wait for someone to try this and crack the glass
      03-20-2016, 12:30 AM   #18
b1mmr
b1mmr's Avatar
319
Who used the restroom in your breakfast..
      04-12-2016, 05:56 PM   #19
lag
Drives: 1993 e36 325i: 2008 e92 335i
Noticed mine cracking at the top a few years ago. I just was cleaning the car and noticed it's basically falling apart at the base of the windshield now. Was thinking "of course this is going to be a $$$ fix.". Glad it's not, ordering the replacement surround now.
      05-24-2016, 04:44 PM   #20
J. Dub
Bob Saget
J. Dub's Avatar
355
Drives: 2010 335i e92 N54 A/T
Well done OP.
In memory of Robert E. Flynn (AR)
      10-22-2016, 01:27 PM   #21
foxman7
foxman7's Avatar
11
Drives: 330i
great write up just bought an e93 and it needed this. I spent about 2 hours doing it mainly because of the cleaning. The easiest part is the removal the longest the cleaning and the most difficult putting in because of the corners. And it turned out fabulous. great DIY.
      03-09-2017, 04:49 PM   #22
doru
doru's Avatar
126
Drives: e92, f25, e46, e83
In order to avoid having "cooked" rubber seals around windshield, windows etc, one would use Next Zett Gummipflege. In the early days, it was called Eins Zett and BMW actually was recommending it to their clients. Linky of web-page
Personally I used this stick on all my BMW's for years, and I have never experienced cracked or damaged rubber seals. I do it twice/year.
0.02
Stable:
e92is
f25 N52
e83 N52
e46ci M54B25 (e53 N62 - sold, R.I.P. e39 M54B30)
