Which INPA version for US/CAN 2009 335D?
04-28-2013, 09:12 PM | #1 |
44
Rep 141
I've tried a couple versions of INPA, the latest being 5.0.4 (INPA EA-90x), and I can't find my DDE 7.3 in the engine menu. Same issue with the transmission.
What version are you guys using with your 335D or am I doing something wrong? |
04-28-2013, 10:06 PM | #2 |
157
Rep 716
I would like to know the answer. I also tried but without success so far.
04-29-2013, 03:27 AM | #3 |
49
Rep 347
Hi Guys,
Don't worry, you just need to edit the E90.ENG or E90.GER file in INPA\CFGDAT and add this one line in this section: [ROOT_MOTOR] DESCRIPTION=Engine ENTRY= DDE73N57,DDE 7.3 for N57 / N57, After this you will be able to read your engine. Good luck. |
04-29-2013, 06:42 PM | #4 |
44
Rep 141
you're my hero!! thank you
04-30-2013, 07:14 PM | #5 | |
44
Rep 141
" Fehler! Aufruf uber Gruppendatei : G_MOTOR.GRP" "Error! Call about group file" using google translate "IFH-0006: COMMAND NOT ACCEPTED" " Das Programm wird abgebrochen!" "The program is terminated" using google translate Do I also need to add something to the G_MOTOR.GRP file? Thanks for your help! |
05-01-2013, 05:27 AM | #6 | |
49
Rep 347
Do you have the newest SP-daten 49? |
05-01-2013, 08:10 AM | #7 |
44
Rep 141
I'm using Sp-Daten 48.1
I have updated the ECU folder in EDIABAS. It contains two files with DDE73 in the filename, not sure this is relevant 04DDE731.PRG 07DDE73.PRG I will try to obtain Daten 49. Thanks! |
05-01-2013, 08:24 AM | #8 | |
49
Rep 347
ENTRY= DDE72N57,DDE 7.2 for N57 / N57 Check whether your C:\EC-APPS\INPA\SGDAT contains these two files DDE73N57.ipo DDE72N57.ipo |
05-02-2013, 08:27 PM | #9 |
44
Rep 141
I removed and re-installed EDIABAS 6.4.7 and INPA 5.0.4 and I upgraded to SP-Daten 49.
I added both of the lines you suggested and confirmed I have the IPO files you have listed. INPA now can't find the G_MOTOR.GRP file and that's because it isn't in the EDIABAS/ECU directory. There is a D_MOTOR.GRP file in the directory however that's not the file it's looking for. I will now try to find newer versions of EDIABAS and INPA...perhaps what I'm using isn't fully compatible with SP-Daten 49. Thanks for your help! |
05-03-2013, 02:51 AM | #10 | |
49
Rep 347
08-22-2013, 11:10 AM | #11 | |
Rep 43
Bumping this up as i'm facing the same problem. I'm running SP-daten V49 and still cannot access the ecu.
Did you finally solve the problem? Quote:
10-18-2014, 05:14 AM | #12 |
886
Rep 9,097
Bump for this as it did not work for me.
Planning to move on to N57 or N47 and both of them are not in my inpa. I have edited 1- E90.ENG or E90.GER file in INPA\CFGDAT 2- Made sure that I have N47 and N57. ipo files in my ECU folder. Also, my SP Daten files are from V52. But I still get the error " Fehler! Aufruf uber Gruppendatei : G_MOTOR.GRP" "Error! Call about group file" using google translate "IFH-0006: COMMAND NOT ACCEPTED" " Das Programm wird abgebrochen!" PS: Running inpa 5 and ediabas 7.3.
F36 Xdrive for her - HUD, park assist, heated steering wheel, rear camera, Apple car play
F36 RWD for him - HK, M sports pack, GTS tail light, Apple car play |
10-18-2014, 07:25 AM | #13 | |
93
Rep 713
Do you have this file dde73kwp.ipo in your SGDAT folder in INPA? |
10-18-2014, 07:56 AM | #14 | |
886
Rep 9,097
I have edited files to this (highlighted the changes). [ROOT_MOTOR] DESCRIPTION=Engine ENTRY= D50M47,DDE 5.0 for M47 TU, ENTRY= DDE6M47,DDE 6.0 for M47 TU2, ENTRY= DDE7N47,DDE 7.0 für N47, ENTRY=,, ENTRY= D50M57,DDE 5.0 for M57 TU, ENTRY= DDE6M57,DDE 6 for M57TOP / M57TU2, ENTRY= DDE72N57,DDE 7.2 for N57 / N57, ENTRY=,, ENTRY=ME9NG4TU,ME9.2 / MEV9 for N45 / N46, ENTRY= MS450,MS 45.0 for M54, ENTRY= MSV70,MSV 70.0 for N52 (NG6), ENTRY= MSV80,MSV 80.0 for N52KP (NG6), ENTRY= MSD80,MSD 80.0 for N43 N53 & N54 with EWS4/CAS, ENTRY=,, ENTRY= MSS60,MSS60 for S65 (M3), ENTRY=,, ENTRY=EKPM60_2,Fuel Pump EKP, [ROOT_GETRIEBE] Thanks.
10-18-2014, 03:13 PM | #16 |
Rep 10
Same problem here. I got 50.2 daten files, but cannot find dde70kwp.ipo and dde7uds.ipo file anywhere. I got E70, however I believe the reason for the error is the same as for E90 here.
10-19-2014, 05:08 AM | #18 | |
886
Rep 9,097
What inpa version are you running? Thanks.
12-11-2014, 02:49 AM | #21 | |
522
Rep 1,527
