7" VRSF Intercooler, front number remove??
04-28-2013, 03:43 PM | #1 |
43
Rep 1,071
Do we need to remove the front bumper for the 7" VRSF?? I know we need to trim the back of the bumper but do we need to remove?? Want enough info before I get this install.
04-28-2013, 04:18 PM | #2 |
71
Rep 510
Yes I did when I installed on friends 335i. and we cut some plastic. its really not difficult.
'2018 F87 M2 LCI | LBB | GC Camber Plates | Ohlins R&T 90/190N/mm | 18x10 et33 square 275/35 | MPe | Poly Transmission Mounts | Recaro Sportster CS
04-28-2013, 05:48 PM | #3 |
32
Rep 644
It's much easier with the bumper off. You're not trimming the bumper at all just the shrouding around the intercooler. After you remove the stock IC just put the VRSF IC up to where it would fit and you'll see what needs to be trimmed. You can literally use a butter knife to trim the shroud it's very flimsy.
Good luck
BSM 2008 135i
-VRSF 7" IC -VRSF DP's -n55 mids -BERK race -ER CP -TIAL BOV -BMS DCI -JB4 G5 ISO -ST coils -STOPTECH slotted rotors & pads -SLeK lip Follow me on instagram: wescuddles |
04-28-2013, 07:07 PM | #5 |
48
Rep 1,290
wellll..... maybe a warm butter knife
- Proven Power Tampa Built 6466 ST N54 6AT WR 711whp 637wtq -
04-28-2013, 07:09 PM | #6 |
19
Rep 259
I did it without removing the bumper. I didn't think to do it at the time but pulling the radiator fan would have made it a lot easier and it only takes a couple minutes to do.
You can also watch these two videos that HPF made showing the whole process. .
2007 335xi 6AT | Cobb Stage1+ | BMS DCI | VRSF 7" IC | FA 500 400#F/600#R | ARC8 17x9 et30 | RE-11a 255/40/17
Parting out car. For sale thread here: http://www.e90post.com/forums/showthread.php?t=1167583 |
04-28-2013, 08:51 PM | #8 |
Just to sweet
20
Rep 249
I know it can be done without removing the bumper,but to make your life easier that day i would recomend removing the bumper thats only exta 15 min off work that will save you atleast an hour in the long run. If we were talking about a 5inch then its a diffrent story but the 7inch is harder to wiggle around with.
04-28-2013, 10:24 PM | #9 | |
32
Rep 644
BSM 2008 135i
04-29-2013, 12:12 AM | #11 |
43
Rep 1,071
Thanks you everyone for the tips, my research said that the passenger clamp is hard to remove , any tips or specific tools to make it easier??
04-29-2013, 08:11 AM | #13 |
19
Rep 259
04-29-2013, 09:49 AM | #14 |
15
Rep 380
I did the trimming with a sawzall lol. took like 20 seconds but i also had a lift which made this job a hell of alot easier
09 tasman 335 6mt cpe, jb4 g5, bms dci, bms 3" catless dp's, 7"vrsf fmic, e85+93
