Anyone with O.S. Giken LSD? Need some feedback please
04-25-2013, 05:54 PM | #1 |
Mad Linux Guru On The Loose
1121
Rep 5,397
Drives: 2008 335i Sedan, 2023 M3
All,
I just got my car back from getting an O.S. Giken installed along with M3 subframe bushings and Delrin differential bushings. The LSD was built by VAC since I had welded ring gear. So I received the whole housing, aka "the pumpkin" already built and assembled from VAC. Therefore, I trust their build. I took a longer drive around the city today and I noticed the following: 1. There is a faint whining noise definitely coming from the differential. Its not there when cruizing. If I accelerate OR decelerate the frequency and the sound level increase or decrease. However, if I cruise at constant rate regardless of the speed, there is no sound. 2. Sometimes when I engage and disengage the clutch, there is a faint "thud" or "thump" sound coming out of the back. Are these symptoms normal? Thanks in advance. Vasil
04-25-2013, 07:23 PM | #2 |
34
Rep 1,381
do you have a manual car? I get that same thud with my wavetrac
you may be getting some trans whine Honestly I don't think anything is wrong with your diff but I would call mike at VAC just to verify. Last edited by tres; 04-25-2013 at 07:28 PM.. |
04-25-2013, 07:28 PM | #3 |
1121
Rep 5,397
You are the second person who said the "thud" is inherent to Wavetrac. I am desperately hoping that VAC did not mix up the housings and sent me one with a Wavetrac instead of O.S. Giken.
M3 subframe bushings and Delrin (not solid) diff bushings were installed.
04-25-2013, 07:35 PM | #4 |
104
Rep 1,529
Just wait a bit longer it does have to break in a little as it is a clutch. .. plus your delrin mounts do not help as that will transmit every sound into the cabin
Space Gray l 6MT l OSG LSD w/ VAC Race Diff Cover l Cobb e30 l Morr vs8.2 l UUC SSK w/ DSSR l VSRF Catless Dps l RPI Intercooler l CDV Removed l HID AE 8000k l ETS Catback l AST 5200 w/ Vorshlag Camber Plates l ER Dual Oil Coolers l Rear Camber and Toe Arms l K&N Drop In l Solid Tranny/Diff/Subframe Bushings l Bridgestone RE-11
04-25-2013, 07:37 PM | #5 |
34
Rep 1,381
you have the set up as mine in the rear bushing wise. I don't think they did and if they did im sure they would correct it. I think its normal considering your mods. If you're really paranoid drain the diff and remove the cover and check to see if its what you paid for.
04-25-2013, 07:42 PM | #6 | |
1121
Rep 5,397
04-25-2013, 07:45 PM | #7 |
34
Rep 1,381
04-25-2013, 08:45 PM | #8 |
125
Rep 3,004
I get a thud as well with my 6MT Wavetrac, I think it might be inherent in all aftermarket LSD's.
I know Sikh335i has an OSG diff, you should PM him
2007 E92 6MT SGM: MusicarNW Level 2, Procede Rev 2.5, FFTEC/Vishnu LPFP with Flexfuel Sensor and Flash, M3 Offset V701's, WaveTrac LSD, Michelin PSS, Downpipes, M3 Control Arms, TCKline D/A Suspension, LCI Tail lights, Lux AE's, ER Charge Pipe, DCI's, Mtech Front and Rear, M3 Sideskirts, HPF Stage 1 Clutch
04-25-2013, 09:16 PM | #9 |
1121
Rep 5,397
Thanks. I will ask him as well. I know AlpinaB3Lux has the exact same lsd as me: the TCD version from OS Giken. I will talk to him too
04-25-2013, 09:58 PM | #10 | |
38
Rep 864
Drives: '08 E92 335i
04-25-2013, 10:18 PM | #12 |
1121
Rep 5,397
Crap!
EDIT: ...and thank you for the feedback!
04-25-2013, 10:19 PM | #13 | |
1121
Rep 5,397
04-26-2013, 12:10 AM | #14 |
DIYER
614
Rep 5,521
I have solid bushings, no whine at all...this is what caused my blank sound if this helps:
http://www.e90post.com/forums/showthread.php?t=816053 I believe in MT cars clunk happens more.
JB4 G5, Stage 3 LPFP, Stage 2 MOTIV PI, VM 6466 ST, Custom OCC W/ SS lines, ER FMIC, ER CP W/HKS BOV, M3 control arms, M3 guide rods, M3 upper links, M3 front & rear sway-bars, HPA rear toe arms, Wavetrac LSD, HPF Gen 2, DEFIV kit, KW clubsport, Delrin solid SF bushings, stoptech rotors, Rogue Tranny Mounts, 1M bumper, M3 CF hood, M3 fenders, M3 OEM sideskirts, Mtech rear bumper, CSL trunk, MORR VS8.2 rims 245/295
04-26-2013, 03:00 AM | #15 |
OPN DIFF
478
Rep 1,909
Drives: 10' E90 M3 6MT LB
You sure the bolt through the bushing is tight? Might wanna check.
'10 LB E90 slicktop/speed cloth/6MT ex. '06 330i 6MT & '10 n54 6MT Msport Autocross vids https://www.youtube.com/user/tigermack https://www.instagram.com/tigermack |
04-26-2013, 07:03 AM | #16 |
1121
Rep 5,397
Guys, you are making me very nervous... I will check over the weekend to see what's the story with the bolts.
04-26-2013, 10:00 AM | #17 |
Sees the world the way it could be
49
Rep 761
Welcome to owning a LSD with delrin bushings. And welcome to owning a clutched LSD. You'll get used to it.
04-26-2013, 11:54 AM | #20 |
38
Rep 864
I have the powerflex subframe and diff bushings, its possible that your delrin diff bushings are transmitting the gear whine.
Does it do the thunk thing every time you put it in gear with the clutch in, or does it do it when you start to drive away? |
04-26-2013, 01:58 PM | #21 |
E92
17
Rep 130
I have a VAC-built Quaife on an E92 with stock diff bushings and I have a small clunk just from standstill into 1st. Normal.
I would imagine there is more NVH transmission with the stiffer bushings or lockdown kit. (Which is why I didn't put it on my DD) |
04-26-2013, 03:19 PM | #22 |
DIYER
614
Rep 5,521
there is no NVH with my lock down kit in the least.
