ZPOST
Go Back   ZPOST > BMW Z4 Technical Talk > Wheels and Tires
  TireRack
      09-11-2007, 03:28 PM   #1
nyczyang27
nyczyang27's Avatar
30
Drives: z4 3.0si / 328xi
TIRE GURUS - m6 wheels on 3.0si non-sport?
Hey. I'm interested in slapping on some replica 19" m6 wheels on my 2007 white 3.0si non sport. I got some questions about fitment.
The wheels are
19x8.5 (f) & 19x9.5 (r)
Offset 35 (f) & Offset 40 (r)
I'm planning on wrapping these wheels with
Bridgestone Potenza RE960AS
235/35ZR19 (f) & 245/35ZR19 (r)
Does this look ok? Do I have to worry about fitment/rubbing issues? Thanks.
      09-11-2007, 03:55 PM   #2
jmontello
JaBaby!
jmontello's Avatar
Drives: 2004 z4 2.5i
That setup should be fine the rear offset might be a little aggressive but you shouldn't have any rubbing issues.
      09-11-2007, 05:40 PM   #3
nyczyang27
nyczyang27's Avatar
30
I've heard from someone that the 245 rear will stretch quite a bit on the 9.5 rear rim. Is this a hazard? Will this be fine?
      09-11-2007, 06:38 PM   #4
mister_roger
mister_roger's Avatar
13
Drives: 2003 Maldives Blue 2.5i
The widths and offsets of the rims should be ok. Wheels should sit just about flush with the fender edges at all four corners. I don't think you should encouter any rubbing issues unless you plan on lowering your car too extreme. An offset of 42 or 45 for the rear may have been more ideal.
As far as tires go, 245 for the rear does sound a bit narrow, and will indeed look stretched out a bit on a 9.5" width rim. It won't cause any real harm, but will just look funny. Normally I see 265/30 used this fitment, which is what I think you should go with.
2003 Maldives Blue 2.5i -- 18" M6 wheels, 12mm rear spacer, ///MZ4 front bumper conversion, Eibach lowering springs, Koni shocks, Hotchkis F/R anti-roll bars, Helene Performance air filter.
      09-11-2007, 10:17 PM   #5
nyczyang27
nyczyang27's Avatar
30
I'm looking for a good set of all-season tires. The all season tires that i found only has 245 and then it jumps to 275. I dont think 275 will fit. How funny would the 245 on 19x9.5 look?
      09-12-2007, 02:13 PM   #6
mister_roger
13
275 would most likely rub in your case, so if you had to choose then defninitely go with the 245 to avoid problems.
As for looks, It might look ok, depending on what tires you get. Some tires have more square looking sidewalls, while other cans look more rounded. Hopefully you don't end up with the 'stretched' look as described in this thread:
http://forums.vwvortex.com/zerothread?id=2234638
But most likely it won't be that extreme, and should be fine.
      09-12-2007, 02:53 PM   #7
561design
z4um Hooligan
561design's Avatar
Jamaica
140
Drives: 3.0Si
How can you have a 3.0si non-sport? Don't you mean it's a 3.0i?
Charles
flickr
      09-12-2007, 03:20 PM   #8
jarrow
Drives: 2004 Z4 3.0i
2004 z4 3.0i  [2.00]
I believe that the sport suspension comes with the sport package which is an option so it is possible to have an 3.0si with sport suspension.
      09-17-2007, 02:54 AM   #9
nyczyang27
nyczyang27's Avatar
30
Thanks a lot on the input. One question.. Since my z4 is non-sport, do you think it would look bad with 19s on stock suspension? I'm not planning on lowering my z because its leased (Don't want to deal with the hassle of swapping).
Anyone got a any pics of 19s on non-sport z4s?
      11-17-2007, 07:18 PM   #10
rufus
Drives: Z4 Coupe 3.0L
THis is my z4 3.0l si se coupe, non sport model with origional suspension
      11-17-2007, 07:20 PM   #11
rufus
It either needs 20"s or lowering i think.
Gonna lower it this week with some Koni springs that advertise a 1" all round
zpost
