Any recommendations for a turbo specialist to fix wastegate rattle?
04-24-2013, 04:50 AM | #1 |
28
Rep 258
I have a 335i that suffers from the dreaded wastegate rattle. My car is a 2007 so is well of warranty - I asked BMW for a goodwill gesture but they told me go away. So my options at the moment are fairly limited.
Instead of forking out £2000+ for replacement stock turbos that will eventually develop the same problem, I've heard of a few turbo specialists that can rebuild the actuator arm on your existing turbos which will eliminate the rattle and in theory it shouldn't return. Has anyone had this done and if so by what company? Many thanks. |
04-24-2013, 05:50 AM | #2 |
112
Rep 2,621
Turbo Dynamics are the company famous for this. Not cheap though.
Are you sure it's not vacuum related, can you do Rattle fix via JB/procede... I replaced with new OEM turbos 6months ago. If in the same position today I would go for Vargas stage 2s from the USA...
Car: e91 330d with Viezu map
Gone but not forgotten: 2010 Jaguar XFR (Cat-back exhaust, pulley, intake mods and map), Highly Modified E90 335i LCI M Sport Manual (circa 480BHP/500lb ft) |
04-24-2013, 06:03 AM | #3 | |
28
Rep 258
Funnily enough I purchased the 335i with a JB4, I have yet to try the rattle fix. |
04-24-2013, 06:18 AM | #5 |
170
Rep 3,828
Drives: AzuriteBlack 335i E92
I have brand new turbos and they have a rattle... This rattle is going to stay I guess, until I upgrade to a g5 and have the ability to adjust the wastegates
04-24-2013, 06:50 AM | #6 |
112
Rep 2,621
Try JB4 rattle fix first - future use d if I remember rightly..
Upgrading to G5 ISO would be a lot cheaper than replacing the turbos.
04-24-2013, 07:39 AM | #7 | ||
28
Rep 258
Could go for hybrid turbos too Work out cheaper than OEM turbos. |
04-24-2013, 10:09 AM | #11 |
32
Rep 1,271
Drives: 335i (sadly gone)
I have rebuilt turbos. They were done twice within the space of a month as the rattle was still there... It is still there!!
In hindsight I would never have bothered getting them rebuilt. Maybe got a JB4 and tried that fix first. I have the evolve stage2. Is there any other way to adjust the wastgates using the mapping rather than buying a JB4? Maybe I will give them an email and ask. |
04-24-2013, 11:48 AM | #12 | |
Senior Troll
224
Rep 3,378
So jealous!!
Gone:
N54 335i is the Legend! N55 435i Now: 718 Cayman GTS / F83 M4 |
04-24-2013, 02:42 PM | #13 |
1685
Rep 3,286
Just out of interest, have you had to add/upgrade the oil cooler given the RBs will mean higher engine output....only asking for interest sake, I've already spent far too much on the car, the turbos are about the only thing left I can fiddle/replace
04-24-2013, 02:57 PM | #14 | ||
1545
Rep 8,970
It must be finger trouble? When do they rattle? Start up (cold or hot)? Idle? Overun? |
04-24-2013, 03:08 PM | #15 |
76
Rep 1,518
Oil temps are fine for hard road use, never had it on a track so can't comment there. A few companies have bought out an oil cooler thermostat bypass for about $60 which seems to work better than most of the aftermarket oil coolers as far as temps are concerned. So I might use that in the summer if the weather is decent.
04-24-2013, 03:39 PM | #16 |
1545
Rep 8,970
+1 on oil temps.
The standard car will overheat the oil on a track on a hot day. Done that. 140 degc. But with FBO and max road hooning never had any problem, not more than 125 deg. You just can't use sustained high power on the road for the time needed to overheat the oil. More like 10 or 20 second blasts on the road intermixed with overrun and coasting. |
04-25-2013, 01:46 AM | #17 |
28
Rep 258
I guess the rattle is here to stay! Crazy that new turbos still rattle. Apart from the rattle is there anything that this can cause? Loss in performance or potentially can the actuator finally loosen itself to the point where is breaks?
Last week I enquired to Turbo Developments, their prices were £250 per turbo for an actuator fix, or £550 per turbo for refurbished turbos with the actuator fix on an exchange basis. Last edited by Dirty Tool; 04-25-2013 at 02:49 AM.. |
04-25-2013, 03:33 AM | #18 | ||
32
Rep 1,271
What do you mean by finger trouble? Quote:
£550 per turbo seems like a good price, does it include VAT? |
04-25-2013, 03:45 AM | #19 |
112
Rep 2,621
G4 board has the fix too.
Use the laptop to set Future Use D = 99.
04-25-2013, 03:50 AM | #20 |
112
Rep 2,621
The wastegate are controlled under vacuum.
If you have a bad vacuum leak you will get WG Rattle. It doesnt matter how many new turbos you buy... Check the vacuum system thoroughly before making any decisions.
04-25-2013, 04:02 AM | #21 |
32
Rep 1,271
Would there be any codes thrown or other symptoms if it was vacuum leak?
I think in my case they checked that first before agreeing to pull them off and rebuild the second time but got to be the best/cheapest starting point. |
04-25-2013, 04:08 AM | #22 |
684
Rep 4,261
possibly a 30FF
OG M2 7sp DCT Masata FMIC - Masata Boost Pipe - Cobra Catless DP - Powervalve Exhaust - Devilsown Methanol Injection BM3 Stage 2
