Instrument functions are not working
04-22-2013, 09:14 PM | #1 |
28
Rep 132
Today, I turned on my car and none of my instrument functions are responding (gas gauge, speedometer, etc). Also, my clock is displaying dashes.
It does not appear to be a battery issue, because everything else works (radio, power windows, etc). After doing a bit of research, it appears that this may be a coding problem? I have not made any coding changes. Will BMW charge me to fix this? |
04-22-2013, 10:54 PM | #2 |
SYTFU Crew
36
Rep 1,179
Drives: 2010 Toyota FJ
Only a coding problem if you had your car coded by someone using old data files and it would have happened right away.
The issue may be just a loose connector behind the cluster.
04-22-2013, 11:30 PM | #3 |
1911
Rep 13,104
Did you check fuses?
There is one fuse that runs the instrument cluster not sure which. If you haven't done any coding is more likely a hardware failure. |
04-23-2013, 11:24 AM | #4 | |
49
Rep 347
04-23-2013, 04:37 PM | #5 |
28
Rep 132
Nope, I don't.
Do you think it perhaps has anything to do with this: http://www.e90post.com/forums/showthread.php?t=804545 I have my appointment on Friday to get that fixed. |
04-24-2013, 09:23 AM | #6 | |
49
Rep 347
