BMW 1-Series Forum (F20) 135i - 1Addicts.com > Second Generation 1 Series Forum > 2012 BMW 1-Series Sporthatch (F20) Discussion > Anyone driftied stock M135i?
      04-18-2013, 04:25 AM   #1
westphone
westphone's Avatar
Taiwan
65
Drives: M135i MT
Friends I am in shame. I couldn't drift the M135i in the rain. I used Scandinavian flick + power, but the car just snaps away quickly instead being well predictable like a GO KART (ok not really a fair comparison.) I tried in the rain because I thought I could achieve the same thing as in the dry with lower speed and less destruction to the tires.
I've seen the YouTube clip Test It and found it is possible. The driver is awesome, and I was hoping to do something similar.
I am just wondering has anyone drifted successfully drifted the M135i?
Thanks and cheers,
Charles
      04-18-2013, 05:42 AM   #2
ovekvam
Norway
266
Drives: 2021 Galvanic Gold i3S
Did you remember to switch off DSC completely?
A Scandinavian flick is enough to start a slide if you do it correctly, and you can also start it by applying too much power while cornering. Both at the same time is not really applicable, as the Scandinavian flick involves braking.
It is possible (but very difficult) to do drifting in the wet with a 116i, so it should be rather easy with an M135i.
      04-18-2013, 07:10 AM   #3
westphone
westphone's Avatar
Taiwan
65
Drives: M135i MT
Thanks ovekvam, yes DSC is off. I'll try without the flick next time it rains
      04-18-2013, 09:29 AM   #4
WAY
Australia
458
Drives: Fast ones
It's easy to do, although I have to say that the e-diff makes it less progressive compared to say a M3. It comes on more suddenly IMO and harder to catch as a result. Best way to do it is go slow in the wet, select 2nd gear, then give it a boot full. Now the boot full is where you need some practice as too much would cause it to spin around too quick and you will need good skills and abilit to catch it. Once the car starts turning in the other direction, don't forget to counter steer!
      04-18-2013, 09:53 AM   #5
ovekvam
Norway
266
For controlling a power slide, you can play with the throttle and steering like this:
- To go more sideways: Steer into the corner, more throttle.
- To go less sideways: Counter steer, less throttle.
- To tighten the line: Steer into the corner, less throttle.
- To widen the line: Counter steer, more throttle.
You need to continously regulate between these four modes to keep it going where you want to go.
      04-18-2013, 09:53 AM   #6
Dawko
Belgium
194
Drives: :
  [0.00]
Rain + 118D + 'sport+' = good powerslide
So it should be possible with the M135i!
      04-18-2013, 10:08 AM   #7
ovekvam
Norway
266
But you can't really do drifting in Sport+. The stability control keeps interfering, and bogs down the engine too much. Some short time powersliding is possible, but the system will resist you and wants to straighten the car.
Here is some footage of me driving on ice with DTC off:
      04-18-2013, 12:00 PM   #8
Dawko
Belgium
194
Drives: :
  [0.00]
True, I wasn't refering to continiously drifting. DTC kicks the car back on track quickly.
      04-18-2013, 03:57 PM   #9
iBeech
iBeech's Avatar
England
112
Drives: BMW 520D F11 2015
i can vouch for that, drifting in the 116i with DSC off is possible, even without wet conditions
      04-18-2013, 04:09 PM   #10
ovekvam
Norway
266
I tried with my non run flats in dry conditions, but I could not keep it going. When I made corrections by lifting the throttle, I had lost turbo pressure when going back on the pedal, and my tires stopped spinning. If it had been possible to run Sport throttle respons with DSC Off, it would have been easier.
      04-18-2013, 04:30 PM   #11
iBeech
iBeech's Avatar
England
112
Sort press of dsc, or long press?
      04-18-2013, 04:40 PM   #12
ovekvam
Norway
266
Long press to get DSC Off. A short press gives you DTC mode, where stability control is still active. Not good for drifting.
      04-18-2013, 07:47 PM   #13
westphone
westphone's Avatar
Taiwan
65
Drives: M135i MT
Thanks guys the DSC button was given a good long press until the "DSC OFF" showed up in the dash. Looks like I've just gotta try it some more. Nice footage ovekvam
      04-20-2013, 09:20 AM   #14
donaldt
Drives: M135i
I tried the same in the rain, didnt work for me as well
just couldnt get the car to stay sideways
might take some getting used to but there isnt any large open space to practice here
      01-17-2018, 02:04 PM   #15
PSG James
PSG James's Avatar
Belgium
Drives: F20 2013
1er is harder to drift as it has shorter wheel base especially drifting without LSD makes it more difficult to predict the car's behavior. Learning curve takes longer as well. But it is entirely possible to drift.
I started to learn drifting with a 116d, it is also easy to drift in the wet. Keep practicing (in a right way though).
      01-17-2018, 02:18 PM   #16
ovekvam
Norway
266
If you want to do a lot of drifting, a real LSD is a good investment.
The wheelbase of the F20 is 2690 mm, which is not really short.
Some popular drift cars:
Nissan 200SX S14: 2525 mm.
Toyota GT86: 2570 mm.
Toyota Supra A80: 2550 mm.
      01-26-2018, 01:24 PM   #17
PSG James
PSG James's Avatar
Belgium
Drives: F20 2013
Probably did not express my thought in the right way. But I guess people who drifts will get what I really meant. I agree with the cars you mentioned as a popular drift car, but they all have one thing in common. You know it if you do drifting.
Cheers
      01-31-2018, 01:06 AM   #18
harkes
harkes's Avatar
China
1083
Drives: M135i, E39 M5, NSX and AE86
The e-diff is surprisingly good in the dry for drifting but work very poorly in the wet. I think it is due to the big difference in traction between the wheels in the wet resulting in the power being thrown around like it does. Holding a slide in say 3rd gear is NOT easy.
M135i 8AT PWG, MHD, Pure Stage2, WMI via Torqbyte CM5-LT, Custom tuned by PureBoost
(A Dane in China)
      01-31-2018, 01:21 AM   #19
ovekvam
Norway
266
It is not as quick and smooth as a real limited slip differential. The turbo lag from the engine adds to the complexity, making it more difficult. A Quaife differential is a nice upgrade for those who do drifting regularly. The e-diff is more suited to driving fast on the limit, with unintentional slides. It makes it possible to put the foot down quite early in corners, and it takes care of the power on understeer by braking only the inside wheel. It could be sold as torque vectoring.
      01-31-2018, 07:22 PM   #20
harkes
harkes's Avatar
China
1083
I would be all over a torque style diff if I had more use for it. No doubt its way more effective than the e-diff. "Had more use" haha With 500hp/650nm I have plenty of use - the price is just rather steep.
(A Dane in China)
1addicts
