04-17-2013, 06:37 PM | #1 |
47
Rep 101
Coding out "ERROR FREE" drl and parking lights!!!
So I have been researching for months now, and finally decided to do my first coding yesterday and it went successful. I went online and surprising found nothing on how to code these errors out so after I did some trial and error, I got them to no longer throw a code!!! This is what you need to code.
Daytime Running Lamps Fembody 3061 TFL_L and TFL_R KALT (Set to nicht_aktiv) WARM (Set to nicht_aktiv) LED (Set to aktiv) Parking Lamps Fembody 3061 POL_L and POL_R KALT (Set to nicht_aktiv) WARM (Set to nicht_aktiv) LED (Set to aktiv) |
04-17-2013, 10:33 PM | #2 | |
BimmerPost Supporting Vendor
171
Rep 1,397
http://www.f30post.com/forums/showth...0&post13208390 |
04-17-2013, 11:08 PM | #3 | |
47
Rep 101
04-18-2013, 06:57 AM | #4 |
263
Rep 1,130
Drives: '16 340i AW MSport
What do these do exactly DXL XLR8?
04-18-2013, 08:44 AM | #5 |
47
Rep 101
If you put in aftermarket LEDs like I did in a halogen headlight, it will throw an error even tho it's supposed to be error free. Coding these will code out the errors whether its parking light or drl
05-01-2015, 04:41 PM | #8 |
39
Rep 183
Parking light brightness
Guys, I read some cheat sheet to find how to adjust parking light brightness (halogen), but when I go to Esys and try to find it, there is no such code. Is it because of my psdzdata? I have v54.1
05-02-2015, 07:57 PM | #9 | |
28
Rep 54
I had a look at the cheat sheet and the parameters you're looking for might be a little bit different. For the left parking light, the parameter should be under Fembody 3062, and be called: MAPPING_PARKL_V_L_PWM_1_LEFT For the right parking light, also in Fembody 3062, it should be: MAPPING_PARKL_V_R_PWM_2_RIGHT You should see in their respective ausglesen folders, the voltages assigned to each of the bulbs (i think its 12.2V or something). Try altering the voltage/percentage output to your desired value. Unfortunately there isn't much potential for fine tuning the brightness here, but better than nothing i suppose. Last edited by re4ryu; 05-02-2015 at 08:08 PM.. |
05-04-2015, 12:09 AM | #11 |
28
Rep 54
For the front foglamp checks, in Fembody 3061, look for:
Left light NSW_L_KALTUEBERWACHUNG - change to nicht_aktiv NSW_L_WARMUEBERWACHUNG - change to nicht_aktiv NSW_L_IS_LED - change to aktiv Right light NSW_R_KALTUEBERWACHUNG - change to nicht_aktiv NSW_R_WARMUEBERWACHUNG - change to nicht_aktiv NSW_R_IS_LED - change to aktiv |
pcwong3250.00 |
05-04-2015, 12:57 AM | #12 | |
93
Rep 307
also was wondering about the fogs as cornering lights, but they seem to be in 3 stages? anybody know why they are? |
05-04-2015, 07:35 PM | #13 | |
28
Rep 54
Of course, your headlights won't begin to move like the adaptive ones after coding this. It just makes the car think it has them, which is why the cornering lamps work. If the first four parameters aren't coded, i don't think it works. |
05-05-2015, 01:16 AM | #14 | |
93
Rep 307
Also coded out the light checks for side/drl/fogs & enabled LED, turned on fog lights with welcome lights, the tyre temp/pressure monitor in the idrive (no values showing in there yet (HU_entry)) and 3 indicator flashes when locking.... ah & auto start/stop disabled by default. 1 thing I did want was the volume on the display when I change it, but couldn't find this, is it for HU_NBT only? Last edited by Jus71n; 05-05-2015 at 01:28 AM.. |
05-05-2015, 06:32 AM | #15 | |
28
Rep 54
In Fembody: 3073 C_CLC_ENA > F030enable 3073 C_BLC_ENA > aktiv 3066 KL_ENABLE_LI > KL_Ein 3073 KL_ENABLE_RE > KL_Ein 3062 MAPPING_abbiegel_L_output > nsw_l 3062 MAPPING_abbiegel_R_output > nsw_r Keep in mind that your headlight switch should be set to "auto", and that your low beams should be on, so you'll have to give it a try at night. It doesn't work in the day with DRL's on (not really any reason it should anyway). As for the volume display, i don't think that works for the original HU_ENTRY/CIC. Probably NBT only. I have HU_Entry as well by the way and the TPMS doesn't show values for me either, so must be part of another package too. Good to see the other codes worked! |
05-06-2015, 01:05 AM | #16 | |
93
Rep 307
06-14-2017, 04:30 PM | #18 | |
11
Rep 42
Does anyone know where to code those? I did some Trial and error with the other various xxx_L And xxx_R settings that mimicked what I've done for the fogs, drls, turn signal, and parking... none of them seek to be for the low beams though. Thanks in advance! |
04-13-2018, 03:55 AM | #19 | |
Rep 2
I have done the application successfully. The fog lamps are blowing when the ignition is first turned on. How can I solve this problem? : confused2: confused2 |
05-10-2018, 04:35 PM | #20 | |
Rep 10
Anybody please has the answer to this? coding to take care of low beam LED error message? Please... |
05-10-2018, 09:49 PM | #21 |
8243
Rep 16,079
FEM Body > 3061 > AL_L_KALTUEBERWACHUNG > Nicht_Active
FEM Body > 3061 > AL_L_WARMUEBERWACHUNG > Nicht_Active FEM Body > 3061 > AL_R_KALTUEBERWACHUNG > Nicht_Active FEM Body > 3061 > AL_R_WARMUEBERWACHUNG > Nicht_Active |
05-14-2018, 07:26 PM | #22 |
Rep 10
Thanks Billfitz. But sorry I forgot to mention I have a 2017 F25 car and it seems not to be the same as F30 (FRM instead of FEM Body) and in there I do not see 3061 > AL etc., I guess I'll keep looking but so far no luck. Thanks again.
