04-15-2013, 08:12 PM | #1 |
Rep 17
Indicator (Lane Change) Signal Duration
Does anyone know what setting controls the duration of the indicator (lane change) signal (before it clicks). I searched through several cheats and even CAF files but haven't found it.
Any help appreciated |
04-15-2013, 08:27 PM | #2 |
712
Rep 924
Not quite sure what you mean by "before it clicks". If you mean single turn signal vs triple turn signal setting, that is under Settings>Lighting. This controls how many times the signal will flash when you tap the lever (without engaging it).
04-15-2013, 10:05 PM | #5 |
21
Rep 490
04-15-2013, 11:08 PM | #6 | |
288
Rep 1,892
I've always changed both setting to change the number of blinks. |
04-15-2013, 11:25 PM | #7 |
21
Rep 490
Nope didn't change the second one, PIA_DEFAULT_TIPPBLINKEN is to alter the flashing behaviour, i believe one is 'normal' while the other one has a more rapid flash (not sure which is which actually)... so I kept mine default to Einfachblinken
04-16-2013, 01:23 AM | #8 | |
288
Rep 1,892
Einfach is simple/plain and Mehrfach is multiple/repeated (according to Google translate), so I don't think the setting has anything to do with the speed of the flashing. I'll restore this value on my car and see if I notice any difference. Thanks! |
04-16-2013, 01:26 AM | #9 | |
21
Rep 490
05-28-2019, 03:01 AM | #12 | |
Rep 30
Thanks |
05-28-2019, 07:45 PM | #13 | ||
4488
Rep 10,473
07-28-2019, 09:46 PM | #14 |
57
Rep 299
just tried coding this in my 340i and couldnt find the Blinkzyklen_anzahl_tipp option.
is there no way to change? my car is a my18
2018 F30 BMW 340i M Sport
Injen EVO intake, OEM 437m rims, Catted VRSF dp, Magnaflow catback, Activ8 piggyback, Pedalbox. |
10-26-2019, 10:09 PM | #15 |
E36fiend
285
Rep 637
Drives: 2014 435i xDrive
Starting in 2017 this coding does not work, I suppose it *may* be possible to flash your FEM_BODY to an earlier firmware version but it has so many dependencies it does not seem likely to work.
10-27-2019, 06:39 AM | #16 |
238
Rep 878
Tried doing this in my 2015 and as pointed out above the setting no longer exists.
10-27-2019, 08:44 AM | #17 |
8243
Rep 16,079
I just did it a few weeks ago on my 2015. It's a common enough change that Bimmercode has it in the main FEM coding menu without having to go to expert mode.
10-27-2019, 01:10 PM | #18 |
99
Rep 332
That's partly true. The problem is that BMW has at some time disabled the option (at least for more than 3 flashes) while leaving the parameter in the system. My 2014 F30 was OK set to 4 flashes until I had the whole car reprogrammed, then it wouldn't work. The I-Step change was F020-14-03-503 => F020-19-03-530
10-27-2019, 07:18 PM | #19 |
8243
Rep 16,079
I haven't had my car at the dealer since the end of my second year of ownership, partly because I didn't want to drive an hour and a half to get a $40 oil change, partly because I'd seen reports that they might 'upgrade' my software, wiping out all my coding, even eliminating some coding options. My I-Step isn't broken, so I'm not going to fix it.
11-01-2019, 04:13 AM | #20 | |
Great Teacher
1085
Rep 1,305
Drives: 06 e91 325ix
Went in expecting it not to work, but from what I can tell mine has NEVER been updated on software Since it was made. |
