F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > 2012 BMW 320i Review
Studio RSR
      04-15-2013, 11:45 AM   #1
aspang86
aspang86's Avatar
Drives: 2012 BMW 320i
Hey guys I am new to this forum site and I have just recently bought my first BMW. I previously owned a 2006 Dodge Charger RT. It was modified down up so I have a lot of experience to engine modifications. Please Check out my 6 part review on the 320i. This car has been released here in Canada and soon to be in the U.S.A. Also in the part 6 video review I talk about the BMS tune. I probably sound a little aggressive in my video to not use piggy back systems but if there is some more feedback on these tunes I would be happy to purchase the BMS and do a complete youtube review. I've posted in the "BMS vs. AFE tune" feed my questions. If someone can help me out here that would be great. Anyways guys enjoy the vids.
I have repeated myself several times in these vids. Bare with me guys my first video posts on the net!
      05-06-2013, 05:13 AM   #2
Zeeshan
Drives: 320i MSport Tanzanite Blue
Smile Excellent review
You have done an excellent review
I also ordered myself a 320i and love to hear that it performs well ..
      05-06-2013, 12:40 PM   #3
aspang86
aspang86's Avatar
Thanks. I will be posting another video once i get the bms tune installed. I am still waiting for it in the mail. In the vid i'll explain why i have changed my mind from using a piggy back system. Ill also see if i can get something to record my launch times a bit more accurate to show everyone the performance increase. I am thinking that it will be a lot more noticeable on this car than the 328.
      05-06-2013, 08:09 PM   #4
BAMxi
BAMxi's Avatar
30
Drives: E90 328xi
2007 328xi  [10.00]
I will be interested to see your opinion on the BMS tune. I stumbled upon n54tech.com the other day (I started a thread on here just wondering about the mod potential of the 320i a while back, so I did a little googling) and was reading an old post by Terry (the guy who develops these tunes) that made me wonder if there is a lot more potential with tuning the 320i than yet realized. The post I read was a couple months old, but seemed like he was hesitant to add too much boost, since there has been varying information flying around regarding whether or not the 328i and 320i both have the same compression ratio. As of that posting, it sounded like he was thinking the 320i had 11:1 ratio, so he was worried about knocking. I believe it has since been confirmed that both the 328 and 320 are running 10:1. I'm interested to see how much power will reliably come out of one of these detuned engines.
Eibach Pro Kit | 19" Avant Garde M341 | BMS PBX
      05-06-2013, 11:39 PM   #5
clarence
54
Drives: F30 328i M-Sport
Nearly all 20i's have 11:1 compression. The pistons are different. Currently the only 20i with 10:1 compression is found on the X3/X1.
      05-07-2013, 12:15 AM   #6
aspang86
aspang86's Avatar
Yes thats right. My car as 11:1 ratio. Its harder to squeeze performance out of higher compression engines. All i want is the torque! These cars are so quick off the line with the ZF trannys. I can already beat my buddy in his 2012 GLI off the line. Cruising at a 100 km/h and going WOT is where this car needs a little help. Hopefully this tune will improve this problem.
      05-07-2013, 12:19 AM   #7
aspang86
aspang86's Avatar
Just got the tune today. I am going to email terry and ask him how to setup the stage 1 for the 320i. I bought the usb cable so it should be fairly easy. I also need to use up the rest of my gas! I swear the gas mileage with 89 octane is amazing driven 598km....still 140km to go.
      05-07-2013, 09:43 AM   #8
BAMxi
BAMxi's Avatar
30
Drives: E90 328xi
2007 328xi  [10.00]
Weird, do you think your Canada-spec 320i would be different from the US model in terms of compression ratio? I just checked bmwusa, and they list it as 10:1 on the spec sheet. Here's the link where I read it on BMW's site: http://www.bmwusa.com/Standard/Conte...fications.aspx
      05-07-2013, 10:24 PM   #9
clarence
54
The specs are probably wrong cos from the latest ETK the US-spec pistons are identical to the high compression EU-spec pistons.
      05-08-2013, 01:22 AM   #10
tony20009
tony20009's Avatar
1045
Drives: BMW 335i - Coupe
Oh, now that's interesting. First BMW I've encountered that didn't require premium fuel.
Cheers,
Tony
'07, e92 335i, Sparkling Graphite, Coral Leather, Aluminum, 6-speed
      05-08-2013, 11:37 AM   #11
aspang86
aspang86's Avatar
Ok guys i've installed the bms stage 1 on my car...unbelievably better. If you had any fears of not seeing a drastic change in performance from buying this tune than worry no more. The power band is insane! For $400, you get a $hit load of more power; plus its a plug and play system. I have never seen such a power increase from any other mod i have wasted my money on in the past!
I'll do a run down for everyone...
The only mod i have done prior to installing the bms tuner is replace the stock air filter with a K&N. i did that because i knew i was going to buy this tuner and i wanted to ensure that there was minimal restriction for the air intake.
Next i filled my tank with 94 octane. The bms presets can run on 91 octane however i wasn't sure if i was going to notice a difference in power with the +3 psi preset and wanted to be able to add the extra pound of boost. If you decide to run +4psi then its suggested that you use 93 octane.
The install was fairly easy. I came to realize that i have the n20 engine with the pneumatic solenoid...
I took the car for a spin and i noticed it right away in comfort mode. The boost stays on much longer and it makes such a difference! Sport mode now feels like the car is on steroids!! The revs and shifts points are much faster! I can't believe how satisfied i am. I am not even considering to crank up the boost. Thats how amazing this tune is.
I took it on the highway aswell and it drives great. When you want to pass someone, you have way more power on the top end to do so and it requires less effort.
Guys i'll make a youtube video review within the next few days and you will easily see what Iam talking about. The 5 vids i made with the stock settings are only going to support my claims of how good the bms tune is. I honestly believe that my 0-60 times are somewhere in the low 6 second range!
      08-18-2013, 12:40 AM   #12
Wrinckled
14
Drives: 1990 325i
Hurts that these videos are dead links.
      08-21-2013, 12:55 PM   #13
aspang86
aspang86's Avatar
iam making a new video...I made way too many videos and I wanted to condense the info now that our cars have been out for a bit. I will post the new link once I upload it into YouTube. I also now have the bms stage 1 installed so my review will change.
      08-21-2013, 01:01 PM   #14
Wrinckled
14
Drives: 1990 325i
That's PERFECT! Can you still send me the original videos. I'm trying to make my decision asap, it doesn't matter if they're long (in fact, that is better!)!
Message me if you can privately upload them or something.
Thanks!
      08-21-2013, 02:17 PM   #15
F30 Epal
19
Drives: F30 320i
Also looking forward to the new and updated video/review!
My Instagram
Alpine White '14 BMW 320i 6-Speed MT: GSR Tuned, H&R Sport Springs, Injen CAI, Borla catback exhaust, ER FMIC/Chargepipe/Downpipe, VMR V810 wheels
      08-21-2013, 02:45 PM   #16
Wrinckled
14
Drives: 1990 325i
I see in your sig that you too have a 320i, how do you like it?
      08-21-2013, 03:51 PM   #17
F30 Epal
19
Drives: F30 320i
Don't have the car yet. I still have to wait 2-3 weeks....
My Instagram
      10-05-2013, 05:12 PM   #18
AgentCircus
Aviator
35
Drives: X3
Let's see these videos!
      11-11-2013, 06:51 PM   #19
Hamza7
Drives: Honda Accord
Also subbed for the video.
f30post
