BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > DIY: Spark Plug Change N55 (2011 335i Sedan) Video
      04-10-2013, 01:08 PM   #1
actionj_99
29
Drives: Ex-BMW Owner
Feedback appreciated. Some advice before you start:
1.) PLEASE USE METRIC TOOLS! This is a European car and guess what measuring system their engineers use? I see other DIY's saying to use SAE or English size sockets and such... It MIGHT work, but you run a big risk of rounding off the nuts/bolts! If you do that, you will need special tools to extract.
2.) Be patient and take your time (2-3 hours). Its tempting to do things right before a run or such, but trying to do a repair under time pressure is not ideal. You run a big risk of doing something wrong and then having to redo it.
3.) Try to do this on a level surface as you are removing a strut brace. And for your own safety should parking brake fail, etc...
Here's Part 1 of the video. Takes you all the way through removing the first spark plug.
And here is Part 2. Takes you all the way through starting the engine back up!
Appreciate 2
      04-11-2013, 08:48 PM   #2
shamu2789
shamu2789's Avatar
15
Drives: BMW E92 '07
That was a great DIY video sir. I'm sure plenty of us on the forum will use it!
Afe Stage 2 Magnum Intake - Custom SS Exhaust - AG M359 Staggered - CF spoiler
      05-09-2013, 11:20 AM   #3
chuy5819
Drives: 2011 355i E90
one of the best made DIY's ive seen great job
      03-02-2014, 07:06 PM   #4
dcaron9999
dcaron9999's Avatar
157
Drives: 2011 135i M package
Excellent DIY. Congrats! Really helpful as Im lining up to do this soon.
2011 X3 35i with M pack + 2011 135i w/6SPMT | 255 square tire setup | Quaife 3.46 LSD | Diff lock down bracket | Bilstein B8+Swift SpecR springs+H&R FSB | CDV delete | BMS Oil Tstat bypass | ER FMIC & CP | N54Tuning DP | GC Street Camber Plates | M3 FCA +guide rods+RSFB's+Tranny mounts | Manzo toe arms | Cobb Stg2 agressive tune | Hawk DTC70 brake pads | RB SS brake pistons | Goodridge SS brake lines | Custom brake cooling ducts
      03-04-2014, 11:46 AM   #5
ze_german
Autobahn Addict
ze_german's Avatar
22
Drives: '11 E92 N55 6MT Msport
Excellent video!
I want to add that I always cover the pipe going down to the turbo after you removed the air intake at 3:10. If anything falls down there you are screwed. I use a plastic bag and a tie wrap.
defi boost gauge in custom 3d printed pod, jb4, bms cdv/cs, er cp, vrsf 7" ic, m3/poly diff/tranny mounts, st coilovers, cyba 3.8 tips
      11-10-2016, 02:35 PM   #6
Arby1028
Drives: 2011 BMW 335i Sedan (e90)
Excellent DIY - many many thanks.
One hiccup - I thought I could use my existing 14mm spark plug socket. WRONG! You need the thin walled 14mm socket. AutoZone Part No. 72-376.
      11-11-2016, 03:42 AM   #7
Phil325i
Phil325i's Avatar
616
Drives: E92 325i MSport Coupe
Also worth bearing in mind that if your cylinder head spark plug access passage has the 'kink' shown in this video, you may like to think about using an articulated socket:
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
      01-14-2017, 08:17 PM   #8
Brettb1234
Brettb1234's Avatar
55
Drives: 2011 E90 6MT 335i
2011 BMW 335i  [0.00]
Old post but deserves appreciation since I used these vids today to change my plugs. First time I've done it to any car and this made it extremely easy.
      01-15-2017, 05:26 AM   #9
Arby1028
This DIY Post is definitely not getting the the love and respect it deserves.
      04-29-2017, 03:11 PM   #10
csween86
DSC OFF
csween86's Avatar
23
Drives: 2011 135i, N55, 6MT, MPK
Thanks for the video, attempting later this afternoon on my 135i! Does anyone know what the exact etorx socket sizes are for the strut brace bolts?
      05-31-2017, 08:32 PM   #11
mjack
mjack's Avatar
23
Drives: X3 M Competition
Thank you for this DIY, just changed the spark plugs in my 135is using this. Was pretty easy, just take your time people!
2020 F97 X3 M Competition Donington Grey
Retired: 2018 G01 X3 M40i Carbon Black
Retired: 2018 F80 M3 Individual Blue
Retired: 2013 E82 135is Carbon Black
Retired: 2007 E90 335i Silver
      06-03-2017, 05:18 AM   #12
juld0zer
Australia
480
Drives: Prev 135i 7DCT, Now 130i 6sp
Definitely use a wobble extension. I prefer the skinny Ko-ken ones. The risk of cracking plugs using straight extensions is too great.
Strut brace bolts are supposed to be disposable items. ie they are a torque plus angle bolt. Usually i just put a 2ft breaker bar on them
      07-12-2017, 10:35 AM   #13
cjdzombie
cjdzombie's Avatar
76
Drives: 2011 E92 335i xDrive, M Sport
Doing this soon. This will be a great help!
2011 E92 335i xDrive M-Sport
MHD 93 Stage 2+ | xHP Stage 3 | xDelete | Catless Downpipe | Phoenix Racing Intercooler | ARM CP | AFE Drop In Filter
      01-26-2018, 01:07 PM   #14
lwgrenier
117
Drives: 2011 e92 335i XDrive
If I'm doing my valve cover gasket will this add much more time? would be nice to kill two birds with one stone.
      03-17-2018, 09:55 AM   #15
delmarco
delmarco's Avatar
494
Drives: 2011 335xi Deep Sea Blue
Dealership just told me $480 to $500 for this job.
I showed him this DIY and laughed at him in decline.
Thanks
VISIT MY GARAGE TO SEE MY BMW E90 MODS:
http://directory.e46fanatics.com/use...Mod&UcId=20832
      11-06-2019, 05:43 AM   #16
Arby1028
I used this DIY again this past weekend to replace my spark plugs. Heads-up: be sure not to pinch the windshield wiper wiring harness when reinstalling the right strut brace and bolt. I pinched it when tightening the bolt and severed one of the wires. Didn't know this until I tried to use my wipers. Soldered-in a splice wire and all is good now - easy fix but frustrating.
