04-10-2013, 11:10 AM | #1 |
16
Rep 49
Enabling Office function in NBT
Hi all,
Last friday I took delivery of my Belgium-spec 316d. Since I ordered the 609 Prof. GPS System, I got the new NBT hardware. Since the salesman told me the only added function of 6NK over 6NH was audio over bluetooth and I don't really need this, I skipped this pricey option. Now it turns out also the Bluetooth Office functions (eg email, sms etc) are also part of this 6NH upgrade - at least for the BE market. Has anyone found this in the coding options for the NBT system? |
04-14-2013, 03:43 AM | #5 |
16
Rep 49
After some research, found out it might be enabled by changing 6NH to 6NK. Think combobox will be necessary (not applicable with NBT nav)
Might need changes to ADRESSBOOK and MACRO_PIM. Needs testing but don't have cable and EST token atm |
04-24-2013, 07:52 PM | #6 |
Rep 17
Hey Kapitein,
did you do any more testing on this? |
04-27-2013, 08:49 AM | #8 |
16
Rep 49
So, as promised, the results.
Change VO from 6NH to 6NK and coded the HU_NBT Enabled some parameters (changed to "true"): 3002 PIM_PARAMETER EMAIL_EIN_AUS SMS_EIN_AUS CONTACTS_EIN_AUS CALENDAR_EIN_AUS TEXT_NOTES_EIN_AUS AUDIO_NOTES_EIN_AUS REMINDER_EIN_AUS TASK_EIN_AUS PIM_BILDER_EIN_AUS REMINDER_TRIGGERS_EIN_AUS MACRO_PIM > this actually show the word OFFICE in idrive menu Office function seems to work for new incoming email and text. Haven't been able to view calendar items, but I don't know if this is supported without the Apps? Last edited by Kapitein Iglo; 04-27-2013 at 08:59 AM.. |
04-28-2013, 04:50 PM | #9 | |
Rep 17
Nice job
07-18-2013, 08:21 PM | #11 |
Rep 7
Changing the 6NH to 6NK can also solve the bluetooth audio issue?
My 328i have 609, 6NH, 6NR. As other post, 609 should include the BT audio, but I can not use it and find the BT audio option in iDrive. |
07-20-2013, 10:58 AM | #13 |
Rep 7
07-20-2013, 11:35 AM | #14 | |
BimmerPost Supporting Vendor
665
Rep 1,976
Drives: 2020 G20 320i M Sport
Yes, if you change 6NH to 6NK on your VO, you will have Bluetooth Audio and Office but you must have 609 in order for this to work. This works for both HU_CIC and HU_NBT. |
07-21-2013, 08:44 AM | #15 | |
Rep 7
And if I add 6NK into the VO list, keep 6NH and 6NK exist together, then I can code HU_NBT successfully, there is no error. And I can also see the bluetooth and office in the menu, but they can not work. Maybe because 6NH still exist in the VO list. So I don't know where is the problem, I can only add 6NK, but can not change 6NH to 6NK....... BTW: I have 609, 6NH, 6NR in my vehicle. |
07-21-2013, 11:02 AM | #16 | |
665
Rep 1,976
07-22-2013, 08:07 AM | #17 |
Rep 7
07-25-2013, 11:05 PM | #18 |
pullin a boat
37
Rep 479
Try coding 6NS instead. 6NK is incompatible with HU_NBT iirc.
2021 X3 M40i, Phytonic/Cognac Past: 2017 330i xDrive Touring M Sport, EBII, Dinan 2014 328d xDrive Touring M Sport, BSM/CR. |
07-26-2013, 06:51 AM | #20 | |
pullin a boat
37
Rep 479
07-26-2013, 10:47 AM | #21 |
Rep 7
07-26-2013, 10:50 AM | #22 |
Rep 7
