E90 Engine Problem
04-07-2013, 10:56 PM | #1 |
Young Owner
Rep 58
E90 Engine Problem
Hi everyone.
I got a E90 330i with 131k miles on it. Today when I start my car I smelled a burning smell from my engine. When I open the hood I saw a little white smoke came out of under the cover. But after little bit it stopped. Is this engine oil leaking? I checked my system it shows oil level still good. I went online and they said it needs to replace the valve cover. Here's some pics to give you guys a better look. Sorry English is not my first language can't get a better description. But what should I do? Thanks a lot! |
04-07-2013, 11:04 PM | #2 |
38
Rep 823
Ya that might be valve cover gasket. Pretty surprising @ 131k I think cause im close and have no leaks. Heads up take all that off and also look into spark plug holes you may have leaks there too and have to get those plugs out to clean them with coils. Hopefully it didnt leak in there.
/// OEM /// |
04-07-2013, 11:19 PM | #3 |
Where'd my VTEC go?
481
Rep 6,067
valve cover leaking most likely due to broken bolts. known issue on early N52
AW/Terra | ZSP | ZPP | ZCW | iDrive | CA
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear |
04-07-2013, 11:25 PM | #4 | |
Young Owner
Rep 58
04-07-2013, 11:27 PM | #5 |
Young Owner
Rep 58
04-07-2013, 11:48 PM | #6 | |
38
Rep 823
Should be really easy fix for DIY just gotta take everything off top, I havent done it myself on E90 but I have on E46 I used to have. Gasket is right under valve cover btw, Shouldnt have to replace cover itself specially on N52 motor on old E46 it was plastic so sometimes you did have to on those.
/// OEM /// |
04-08-2013, 12:05 AM | #7 | |
Young Owner
Rep 58
Another thing I worry about is if it stop leaking how can I clean up all the oil it leaked, if I just leave it there is the oil gonna damage the engine? |
04-08-2013, 12:14 AM | #8 |
38
Rep 823
No it wont do any damage but I would (with engine cold) Use degreaser like Simple green and spray everything that got oil on it and spray it off with water maybe use cloth too. And if that much leaked on just starting it in morning one time I probably wouldnt drive it. But thats up to you.
Just make sure you do some research on DIY section here if there is valve cover gasket replacement DIY, Cause it sounds like you havent done it before so you have little guide.
/// OEM /// |
04-08-2013, 12:26 AM | #9 | |
Young Owner
Rep 58
I will do more research on it and I really never done it before. And thanks so much for the support! |
04-08-2013, 12:31 AM | #10 | |
38
Rep 823
/// OEM /// |
04-08-2013, 12:37 AM | #11 | |
Young Owner
Rep 58
Thanks again man and I have to go sleep now, got school tomorow |
04-08-2013, 11:17 AM | #12 |
165
Rep 7,433
Mine was doing the same thing until I noticed sheared-off bolts. Replaced most of the bolts, with a lot of pain due to having to coax the broken bolts out of their holes without a head, and the leak stopped.
-Brian
2X 2006 BMW 325i [Electric Red & Mystic Blue] | ZPP | V1 | Rear Fogs | M3 Lip Spoiler | EAS RemoteKey | BMS Powerbox | Projector90 Headlights w/ LED AE | LED plate lights | OEM Blacklines http://www.tech-shine.com |
04-08-2013, 12:33 PM | #13 |
Rep 177
I have only seen a car with sheared bolts once, and that was because I think someone was trying to do the valve cover themselves and didn't know what they were doing so they brought it in to our shop. The bolts are aluminum and should be replaced for proper torque whenever the valve cover gasket is replaced.
This has been a routine job for any e90 with around 60-70k or more miles at our local service shop, on average once a month or so.
04-08-2013, 12:46 PM | #14 |
971
Rep 3,863
Drives: 330i, 135i
Yeap need VCG. I also need to get this replaced but mine is not that bad just yet. No smells or anything but bottom plastic cover its got some oil and eventually drips down to floor, not much just few drops here and there. Keep us posted.
04-09-2013, 12:35 AM | #16 | |
38
Rep 823
/// OEM /// |
