Centre speaker for MS-8 setup
04-06-2013, 05:53 PM | #1 |
Rep 4
Drives: E91 325iAT M-sport Individual
Hi all,
I have a BMW e91 with originally the hifi sound systen (code 676) and have already started to upgrade this system. First step was to replace the OEM front speakers + underseats subs with the Gladen X-ION 200 speakers connected to the Mosconi One 4 amplifier. I was not satisfied with this set-up, mids and tweeters had a bit sharp sound in my ears, and replaced these with the Focal 100 krs, which I like a lot. Now, its a clear and crisp sound but a bit 2D. So now, my plan is to replace the OEM amplifier with the JBL MS-8. The MS-8 will power rears (mids and tweets) and a centre speaker, and will give output to the Mosconi One 4 which powers the Focals and underseats subs. Now for my question, what centre speaker should I choose? I really love the crisp sound of the Focal tweeters and do not want to ruin this sound. Any idea about this one? http://www.bavariansoundwerks.com/product/686/323/BSW-Front-Center-Channel-Midrange-Speaker-Upgrade-for-Logic7--HK-Equipped-BMWs/ |
04-07-2013, 02:42 AM | #2 |
300
Rep 3,969
I would not recommend the BSW one as it has no tweeter. Focal does make 4" coaxials, but not from the K2 Power line. If you're worried about timbre matching, then you could go with 1/2 of another 100KRS set. The tweeter you can put in the air vent next to the mid.
Mobridge DA2 > JBL MS-8 > ARC XDi 600/4 > JBL Gti 408 Mids & Vifa OT19 Tweeters; PG Ti2 1600.5 > Morel HCW-10 & IDMax 15
04-07-2013, 07:22 AM | #3 | |
888
Rep 9,097
I had fitted Focal co-axial in a car with Morels and that does a decent job. I'd suggest you to fit co-axial with Focals to keep the matching front.
F36 Xdrive for her - HUD, park assist, heated steering wheel, rear camera, Apple car play
F36 RWD for him - HK, M sports pack, GTS tail light, Apple car play |
04-08-2013, 04:23 PM | #4 |
Rep 4
Thanks for quick answers.
Agree that the BSW with no tweeter is not a great option. How did you fit the Focal coaxial speaker in the dash? As I see from the options I have at Focal.com (http://www.focal.com/en/65-pour-bien..._speakers_kits) the tweeter is "lifted" above the speaker, and I can not see how that will easily fit. If I go for a 100krs as centre, any good suggestion on how to fit the mid and the tweeter? I will prefer not do ant major modifications to make it fit.... How is the sound quality of the OEM hifi prof or individual centre speaker? Any other plug and play speaker options with tweeters? Do you think I will have problems with the low powered MS-8 to power the centre in this system? |
04-08-2013, 05:14 PM | #5 |
300
Rep 3,969
The center is the most important speaker of the Logic 7 system. Therefore, you do not want to a) go cheap and b) choke it with too little power.
If you do not want to add another amp for the center, then I would recommend getting the most efficient decent coaxial you can find. Taibanl did some efficiency comparisons on coaxials, I'll have to dig it up, but from memory it was either JBL or Pioneer. So you want to be able to get as much SPL from the MS-8's built-in amp as possible. An efficient 2ohm coax should do it. In this case it is more important to get the volume level up than matching the timbre of the Focals. If you are willing to ad another amp and give it at least the same power as the Focals are getting, I would recommend using 1/2 of another KRS set to get the best results possible.
04-08-2013, 05:21 PM | #6 |
300
Rep 3,969
Here's the post I was referring to:
http://www.e90post.com/forums/showpo...8&postcount=17 Infinity 42.9i
04-09-2013, 01:54 PM | #7 | |
888
Rep 9,097
