How Do You Know If Ball Joints Are Bad?? Bad Bad Roads... >.<
04-05-2013, 07:19 PM | #1 |
Ricebanger
24
Rep 260
Hi I moved to Regina.
WORST ROADS I HAVE EVER SEEN.. where I park, it is really snowy/icy, and people driving thru it left a track in the ice my car gets stuck, but yesterday I was trying to park, and my front end dipped into the track, and it felt like my front right tire took a beating when I drive the car is perfectly fine.. but I am concerned I damaged a ball joint (OCD) how hard is it to damage one? the roads here are also really really bad lots of potholes which i try to avoid but you cant avoid them all also is it bad to park on an uneven surface? thanks |
04-05-2013, 07:24 PM | #2 |
1086
Rep 1,912
Well it's not THAT hard to damage one but they are pretty robust. If nothing is different in the steering or ride then I personally wouldn't worry about it. Usually a toasted ball joint makes a clunking, popping or rattle noise.
04-05-2013, 07:30 PM | #3 | |
Ricebanger
24
Rep 260
when would it make that noise? when I hit a bump correct? because I think my mom's 3 series (2004) had that problem.. also is it true that if the ball joint is bad, under braking, the steering wheel would turn slightly towards that direction? |
04-05-2013, 07:53 PM | #4 |
BMWCCA 149159
38
Rep 847
To answer your question you take a pair of channel locks and squeeze the ball joint with the jaws on top and botton. Any movement, repeat any movement indicates they are bad...
04-05-2013, 08:21 PM | #5 | |
Ricebanger
24
Rep 260
i can't even wash my car because regina is a dump theres fkin mad snow out there n its april i sure miss southside ontario anyways back to point do u guys reckon them balljoints are pretty sturdy? fk i can't afford to fix it rite now i just got a job.. i mean the care drives perfectly fine but the roads out here r a minefield |
04-05-2013, 08:49 PM | #6 |
1086
Rep 1,912
Yeah bumps will bring out ball joint sounds, as will turning full lock sometimes. But if the car is driving perfectly fine then I really wouldn't worry about them.
