Welp! Think I just blew a turbo...
04-02-2013, 08:23 PM | #1 |
22
Rep 363
So just got done with a soccer game tonight. On my way home, driving like a grandpa since it's late and I'm tired.
I give it a little gas, revs up to maybe 2800rpm and suddenly I hear a poof sound, then a short whirl sound followed by deceleration and "Engine malfunction! Reduced Power!" Gave it a little gas again and sure enough, I have less horses! No smoke from engine or tail pipes, no harsh idle or engine stutter. Only noticeable thing is the car is quite a bit louder and has reduced power. Only thing I can think of is I blew a Turbo! Any other thing it could be that I might be missing? Checked the engine bay and nothing is leaking. Going straight to the dealer tomorrow morning.
(SOLD)2010 Alpine White 335i - Sports Package, Premium Package, Navigation, Comfort Access
2016 Infiniti 3.0t Q50S |
04-02-2013, 08:28 PM | #3 |
Foodie and Gearhead
102
Rep 733
Drives: 2011 335i xDrive Sedan
No smoke? I'd think a blown turbo would have more smoke, but I could be wrong.
Does it get noisier the more you apply the throttle? Does the noise increase with the RPMs?
2011 335i xDrive Sedan, Deep Sea Blue w/Oyster Interior
04-02-2013, 08:28 PM | #4 |
22
Rep 363
Yup several times with the same result. Once I hit the gas the warning came right back up.
04-02-2013, 08:29 PM | #5 |
22
Rep 363
No smoke but yes, it gets pretty darn loud when the RPM's increase. Way louder than before.
04-02-2013, 08:48 PM | #8 |
Rep 2
it might be the low pressure fuel pump! it happen to me a couple of times. when it happen i just turn off my car and restart it and it goes away while the car is cool!.the piece is about $125 but i got it for a great discount on it, only paid $65
04-02-2013, 08:48 PM | #9 |
22
Rep 363
Good call on that one.
Just checked it and sure enough it LITTERALLY blew right off. Top connecting part looks like it exploded and half of it is missing!! I even found a random cap sitting under the hood. No clue where it goes. That's actually pretty bad. What in the hell could have caused that?
04-02-2013, 08:50 PM | #10 | |
34
Rep 645
2007 BMW 335I- JB4 G5,DCI,VRSF DPs,NT555r Drag Radials Daily Driver
04-02-2013, 08:57 PM | #11 |
22
Rep 363
100% stock. I haven't ever put a tune on it. No mods what-so-ever save for some external cosmetic ones.
That's why I'm so baffled. I took another look I'm just at a loss to explain how the top connector piece literally exploded. The whole back half of it is no where to be found.
04-02-2013, 09:02 PM | #12 |
158
Rep 3,158
Bet oil contamination softening the pipe rubber, leading to a rupture under pressure.
Oil comes from the PCV system on our 335s.
Always do right. This will gratify some people and astonish the rest.
--Mark Twain |
04-02-2013, 09:02 PM | #13 |
MurderedOut
15
Rep 339
dealer should cover that no prob. It's a piece of plastic anyway. Changing it to an after market one would help but since your probably under warranty seeing you have a 2010, just call them asap!
2013 C63 AMG COUPE
04-02-2013, 09:11 PM | #14 |
22
Rep 363
Yea. Thanks for the help. It's still under the 4yr / 50k manufacturers warranty but still didn't think a pipe would explode.
I took some pics - tried to get the best angle I could. The screw holding the plastic mounting lip is just totally missing and the actual mount is broken. You can't see it in the other picture but the back half of the pipe is broken off. I could feel it with my hand when reaching back. Crazy....
04-02-2013, 09:23 PM | #16 |
75
Rep 590
04-02-2013, 10:10 PM | #18 |
456
Rep 6,478
N55 chargepipes suck a little more than N54 chargepipes. OP's broke under stock boost, some people have theirs holding up to 19psi no problem. It's a flip of the coin if you're boosting much over stock (8-9psi), and even at stock boost levels it can happen as we just saw. Replace it.
E88 N54 Alpinweiss/Coral Red/Motiv HTA 3586r Tial .82AR/Other stuff...652WHP
F30 N55 XDrive EBII |
04-03-2013, 07:08 AM | #19 |
131
Rep 1,086
Drives: '11 335i M-Sport [LeMans Blue]
'11 335i M-Sport xDrive Coupe [LMB] COBB V3 & PTF Tune | E45 |4in BERK DP | VRSF 5in FMIC | BMS Intake | ER CP | Exotics Tuning CF Lip | CF Diffuser | Eibach Springs | Bilstein Shocks '07 BMW 335i Coupe & BMW Z4 3.0i - Gone |
04-03-2013, 07:30 AM | #20 |
BMWCCA 149159
38
Rep 847
Most likely a defect not detectable by visual inspection. Anything made using plastic can have an occassional void, same with rubber which will eventually fail. Pretty rare and yes your dealer will take care of this and most likely send the part back to Germany for analysis...
