F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > M Performance Brakes Question (another one)
Extreme Powerhouse
      04-02-2013, 07:02 PM   #1
mikew2069
mikew2069's Avatar
413
Drives: F30 335i MSport
So it appears that the MPB kit has the same size rotors on the front and back as the M Sport brakes. So all you're really getting is better looking calipers and the rear caliper is an actual upgrade. I think the front caliper is identical.
For all my brake buffs out there - here's the question. Could you put the FRONT MPB rotor/caliper on the front and move the FRONT MSport rotor/caliper to the rear? This way you'd have 370mm rotors in the front and back but you would obvoiosly have to get the rear caliper painted....
2013 F30 335i ///M-Sport
Forgestar/Challenge/BMS JB4
Wagner/Evo Race/M-Performance
2016 F15 50i ///M-Sport
BM3/H&R/Borla
      04-02-2013, 07:09 PM   #2
Eric@NRP
174
Drives: F80
I thought the same thing when I saw pictures and prices. Doesn't seem reasonable. In for answers
      04-02-2013, 10:12 PM   #3
shivaswrath
shivaswrath's Avatar
649
Drives: 2012 335i
4 -pot calipers up front.
Stock is 2.
CURRENT: 2017 RS3 (miss you guys)
SOLD: 2012 335i Mineral Gray
M Performance Exhaust/Brakes/Suspension/LSD|Bav Stage 1/AMP||ER CP/IC/DP/OC | Dinan CAI/N55 PWG BIG TURBO|BMWF30.com
      04-03-2013, 07:34 AM   #4
mikew2069
mikew2069's Avatar
413
Stock is 2.
Oh I didn't realize that. From what I've seen, I assumed they were the exact same calipers up front.... So do you think you can put the Larger Front MSport Calipers on the rear?
That would look a lot beefier and better than the rear MPerf Calipers in the rear.
BM3/H&R/Borla
      04-03-2013, 09:18 AM   #5
Jamesons Viggen
193
Drives: '98 M Roadster stg 2+ S/C
MSport in the US has no unique hardware to any other model line, just the pads.
People keep seeing MSport and thinking the brakes are bigger in some way, largely because other countries get that. But we do not.
'98 Dinan/RMS stage 2+(VAC cams, CES Cutring etc)
'15 Buick Regal "T"(wife)
'06 Saab 9-5 Combi 5mt (full suspension, LSD, clipped turbo etc)
      04-03-2013, 11:13 AM   #6
mikew2069
mikew2069's Avatar
413
Well we know for sure that the FRONT MSport calipers/rotors are larger than the REAR MPerf calipers/rotors. So back to my question, would the MSport fronts be able to be moved to the rear?
BM3/H&R/Borla
      04-03-2013, 11:24 AM   #7
Jamesons Viggen
193
Correct...
But you a messing with brake proportioning and balance.
The car needs to be coded just when adding MP brakes which they know how to code as it was engineered in house.
Now you are kind of making your own recipe. So good luck on coding and setting up the car for proper balance.
      04-03-2013, 12:32 PM   #8
mikew2069
mikew2069's Avatar
413
Originally Posted by Jamesons Viggen View Post
Correct...
Yea that's kind of what I was afraid of. But people put Rotora or Brembo 6/4 on the car and how can that be coded?
I was wishfully thinking I could put the front MSport on the rear, MPerf on front, code for MPerf and have the beefier look of the MSport caliper on the rear.
BM3/H&R/Borla
      04-03-2013, 12:39 PM   #9
Jamesons Viggen
193
Those brake kits are engineered and tested front to rear. My concern is you are mixing and matching. So even without the coding complication, you have no foundation for properly modulated braking.
No one is going to be able to definitively say it will work or F up your car, not even BMW.
But my gut says it will be a gamble and could cause poor braking.
      04-03-2013, 01:10 PM   #10
mikew2069
mikew2069's Avatar
413
Cool, thanks for your input. That's why I opened this thread b/c I don't know too much about brake systems. Guess I'll stick w/ the regular MPerformance.
Do you know what the stock MSport rear calipers are?
BM3/H&R/Borla
      04-03-2013, 01:16 PM   #11
shivaswrath
649
Drives: 2012 335i
I wouldn't do it. At all.
Brake balance is a delicate matter, and like Jameson said, the aftermarket tests this out extensively...the only other "beefy" option is through Stoptech directly, and that's still a 6/4 design (but costs $6-7k!)
also requires some trimming, so kiss warranty items good bye:
I honestly think the MBP looks plenty nice on the rear...
      04-03-2013, 03:06 PM   #12
Jamesons Viggen
193
Off the top of my head I think stock rears are single caliper.
      04-03-2013, 03:57 PM   #13
shivaswrath
649
Drives: 2012 335i
yup, stock are 2/1
M Perf are 4/2
Stoptech are 6/4
      04-07-2013, 09:45 PM   #14
RPM90
890
Drives: 340i M-sport AT
yup, stock are 2/1
M Perf are 4/2
Stoptech are 6/4
Are you sure?
From my reading the stock 335i calipers are 4 pot front and 2 pot rear.
Some picts have confirmed this.
On the 328i they are 2 pot front and 1 pot rear.
The brakes on my 135i were great and had much better pedal feel compared to my 335i Msport. Brake travel was shorter and modulation was more force based with less travel.
The front calipers were Brembo 6 pot and the rear 2 pot.
And they looked better too.
      04-07-2013, 09:54 PM   #15
shivaswrath
649
Drives: 2012 335i
Originally Posted by RPM90 View Post
Are you sure?
Yes, meant to clarify, after driving a 328i loaner and my 335i.
328i line is 2/1
335i ENTIRE line is 4/2.
Only differences are the M Performance Rotors/pads are much larger/wider with the 4/2.
      04-07-2013, 10:09 PM   #16
clarence
53
Drives: F30 328i M-Sport
Are you sure?
The rears are single pot sliding calipers.
http://www.f30post.com/forums/showpo...54&postcount=1
      04-07-2013, 10:19 PM   #17
shivaswrath
649
Drives: 2012 335i
I can go down into the garage and look again....
I'm seeing so much variation from different countries, I'm no longer confident in what BMW standardizes for brakes across the different continents...
      04-14-2013, 07:04 PM   #18
RPM90
890
HI Clarence.
I've seen that thread.
Also, in another thread you say that the stock 335i rears are single pot, but looking at those pics it looks like the rears are 2 pot, as there appears to be a cylinder on both sides. Do you have a pic of the stock 328i calipers?
But as I said, I'm not positive as I haven't seen them in the raw.
Thanks for the info and please share any more info you have on the stock rears.
      04-14-2013, 08:37 PM   #19
clarence
53
HI Clarence.
The stock 335i rear brakes have single pot sliding calipers, they're made by Bosch (as shown on the pic on that quoted thread)
http://www.realoem.com/bmw/showparts...69&hg=34&fg=10
The 2-pot rear caliper is only fitted to either M-sport brake (option 2NH) or M-performance brake. 2NH is currently not available in the US (as u well know).
http://www.realoem.com/bmw/showparts...33&hg=34&fg=10
Stock 328i front & rear are also single-pot sliding calipers
http://www.realoem.com/bmw/showparts...68&hg=34&fg=05
Btw, I think the US-spec 328i M-sport comes not only with Euro pads, but also with standard EU-spec front discs (i.e. 330mm vs 300mm) and caliper brackets.
PS.
From an earlier post
http://www.f30post.com/forums/showpo...&postcount=120
      04-15-2013, 12:04 AM   #20
clarence
53
U already got M-performance fitted? Then no need to look as the rears are 2pot fixed.
      04-15-2013, 08:25 AM   #21
shivaswrath
649
Drives: 2012 335i
yup, I put them on...
      04-15-2013, 08:34 AM   #22
Balzz
96
Drives: F97 X3M
2019 M4  [0.00]
2021 X3M  [0.00]
Correct...
Install dual master and bias bar?
Search this Thread:
Advanced Search
f30post
