Coding help- CD87,4,PT-Can Communication Failure
04-02-2013, 07:31 AM | #1 |
Rep 28
Hi all,
Today while I was trying to code my e90 prelci Ncsexpert came back with an error. The error resulted in many codes but I think they are all stemed off CD87: PT-Can Communication failure. I have not seen these codes before until i tried coding nfrm. I updated the updaten files prior to all of this to v48. "Error Codes Present On Monday, April 01, 2013 5:46:59 PM Code,Type,Description DME,DME Number: -------- 2A82,8,VANOS intake 3100,8,Unknown CD87,4,PT-Can Communication Failure 2F80,8,Unknown 2CFB,1,Throttle-valve adaptation value 2D09,4,Throttle valve" First off, I found the Vanos Intake code could be caused from a clogged solenoid. I cleaned both intake and exhaust solenoids and swapped them.I cleared the codes but it came back. Next, I did a throttle reset and cleared the codes. But the codes came back. I went on a short ride and the car drives fine but the check engine light is still on. Does anyone have any advice for my next steps to getting these codes figured out? |
