oil level too high - really?
04-01-2013, 07:35 AM | #1 |
45
Rep 217
I just happened to check my IDrive settings today and noticed an 'oil level too high' message. However, when I check the dipstick after 10 minutes, the level is about 3mm down from the max mark. Which do I believe? Do I need to drain some?
04-01-2013, 08:27 AM | #2 |
114
Rep 1,326
I would trust the stick.
Didn't know they still had them, thought it was all electronics now?
Please consider checking out my YouTube Channel for car and tech videos.
04-01-2013, 02:53 PM | #4 |
141
Rep 736
Are you sure it's an oil dipstick? My previous 335 diesel and current petrol didn't/don't have one and they were both older than yours.
But if you're right, then I'd always go for a good old stick. Nothing to go wrong there with faulty sensors etc. |
04-02-2013, 12:18 PM | #6 |
Beemer Heaven
462
Rep 2,941
Drives: BMW M4 Competition
Garage List 2018 BMW F82 M4 Comp [0.00]
2017 BMW F30 330d M ... [0.00] 2014 BMW F30 330d M ... [0.00] 2009 BMW E90 330d M ... [0.00] 2006 BMW E90 330d M ... [0.00] 2002 BMW E46 325i S ... [0.00] |
Post LCI 330d's do not have oil dipsticks under the bonnet. They do however have a transmission dipstick....
04-03-2013, 03:09 AM | #7 |
45
Rep 217
04-03-2013, 08:41 AM | #9 |
1545
Rep 8,970
It seems to vary wildy between engines and ages of the same engines.
For sure my N54 doesn't and the N52 330i I had before that didn't either but who knows for sure? |
04-03-2013, 08:44 AM | #10 |
224
Rep 3,016
I had a sensor failure (over-reading) on my F10 535d. It was replaced under warranty, but I always used the dipstick and never relied on the electronic level.
I've recently traded in for an F12 640i; lovely car, but I miss the dipstick. Beats me why diesels, which hardly use a drop of oil have one, whereas the petrol engines, which do burn a bit, only have the electronic system. |
04-03-2013, 09:18 AM | #11 |
28
Rep 901
My pre-lci e90 has a dip stick
Pre LCI Monaco Blue e90, iDrive, 18" 220M reps, M3 Front Bumper, LCI headlights, Darklines, Eibach Pro Kit [Build Thread]
ICE: DLS R4s, Gladen HG-201BMW-3, Alpine PDX 4.100 |
04-03-2013, 09:35 AM | #12 | |
1545
Rep 8,970
I've never owned a BMW diesel though, but asking a few of the masses of 320d owners at work they all seem to use top ups. Nice new motor BTW |
04-04-2013, 12:36 AM | #14 |
Zummerzet Zyder Drinker!
112
Rep 5,541
Drives: '06 330D Le Mans Blue
The white dipstick in that picture the OP has posted is the transmission fluid dipstick.
04-04-2013, 12:46 AM | #15 |
The Tarmac Terrorist
949
Rep 29,345
Drives: 997.2 GT3
My 335d had a dipstick.
04-04-2013, 02:37 AM | #16 | |
1545
Rep 8,970
The realoem pic associates it with the engine, but it does seem quite rearward in its location. The picture seems to show a locating hole for the dipstick tube in the sump end of the engine oil pan. The transmissions are classed as 'sealed for life' so that would normally preclude any measuring point. What does the car manual identify it as??? |
04-04-2013, 03:58 AM | #17 |
45
Rep 217
Here's the relevant page from my manual. The car is in the stealers today for its 'security update'. I've asked them for their opinion on the oil level.
04-04-2013, 04:28 AM | #18 |
33
Rep 650
The auto box has no dipstick I'm sure. Is it not done with engine running at a certain temp, with a bung on the rear of the gearbox casing? My 330d has a dipstick in the same place as the pictures above.
04-04-2013, 05:05 AM | #19 |
28
Rep 901
This is definitely the oil dipstick on mine...
04-04-2013, 05:32 AM | #21 |
Rep 127
I was disappointed when I discovered that my '07 320D didn't have an electronic oil level indicator - although interestingly an 'oil can' warning lamp came on fleetingly yesterday. Have to get oily fingers instead.
All those electronics on the car and no temperature gauge and no oil level indicator...... |
