how to install bm 2 step?
03-28-2013, 03:44 PM | #1 |
76
Rep 1,071
so i just got in the mail my relay with wires from Burger Motorsports to install the 2 step in my 07 335i m/t. but i can't seem to find the instructions on how to do it. they dont have a dyi in their website for the 2 step. can someone help me?
03-28-2013, 05:40 PM | #2 |
3441
Rep 79,211
Just do 1 step at a time
Basic directions for connecting 2STEP/CLUTCH wire: 1) Locate green power connector, open bottom flap, and remove #8 orange wire. Place 2STEP relay red wire in its place. Connect #8 orange wire you removed to the 2STEP relay blue/white wire using preinstalled connector. 2) Put green power connector back in its location with relay hanging below or next to it. 3) Connect 2STEP black, which will have a wire nut connecting to an extension wire, in to the USB cable position #7. 4) For the NLS to work you must also install a clutch wire. Connect this to USB cable position #8. 5) Connect the male/female end of the clutch wire in to the gray DME connector position #18 as read from the female end. Either by removing the PNP connector and extracting that jumper wire, or simply removing the wire, sticking the female end in, connecting the OEM female wire in the new male pin, and folding a piece of tape in half over it. The wire needs to read the clutch signal. 6) To enable NLS you must set FutureUseE (previously bogfix) set to 0. NLS will cut engine power when pressing the clutch while gas is fully pressed and restore it when you let the clutch back out again. Practice doing full throttle runs at lower RPM to get the hang of it. When you press the clutch in while the gas is 100% down the RPM should drop like a rock. If they don't, you've botched the install. 7) Note if the car cranks without starting after installing the relay something is likely wired wrong. If you are unable to sort it out just email in install photos for support. |
03-28-2013, 06:08 PM | #3 | |
76
Rep 1,071
03-28-2013, 06:20 PM | #4 |
70
Rep 2,626
should be pretty simple once you follow above... have fun
'18 F80 M3 Comp 6MT - Stock
'07 E92 335i 6MT- HP650, inlets/outlets, ER FMIC, VRSF CP, LPFP stg2, CSF rad, 'is Aux rad, ER OC, Ohlins, M control arms, eibach front sway bar. '05 C55 AMG SOLD - '22 Tesla M3P | '10 E92 335i M, 6MT | '07 E90 335i, PTF COBB E50, FBO, HFS4 |
03-28-2013, 10:58 PM | #5 |
82
Rep 725
cant tell you how many people I have walked through this .prob 10 by now .
almost made a complete diy w pic and all but lost the pic's with my old computer lol . last guy I drew a diagram took a picture from my phone and sent to him lol since I no longer run jb .not sure why so many have trouble with this. |
03-28-2013, 11:56 PM | #6 | |
70
Rep 2,626
I need to drop by soon for a ride. I'm thinking about an intercooler lol
03-30-2013, 09:05 AM | #8 |
76
Rep 1,071
im pretty much lost between step 3 n 6
5) Connect the male/female end of the clutch wire in to the gray DME connector position #18 as read from the female end. Either by removing the PNP connector and extracting that jumper wire, or simply removing the wire, sticking the female end in, connecting the OEM female wire in the new male pin, and folding a piece of tape in half over it. The wire needs to read the clutch signal. 6) To enable NLS you must set FutureUseE (previously bogfix) set to 0. which one is the clutch signal wire? is it located by the pedal? if so im sure there is at least two wires there for that sensor, which one do i tap??? |
09-22-2013, 05:40 PM | #10 |
Rep 60
I came across this post after google-ing for the answer as well. There's a write-up here: http://www.e90post.com/forums/showthread.php?t=874651
Note, follow the diagram, not the instructions. At the time of writing this, the wires on the USB cable were backwards. |
09-22-2013, 07:28 PM | #11 |
82
Rep 725
lmao that's the diagram I drew up glad this helped out some people..
ptf MHD E85 /Hexon rr550 turbo's/PRE custom intakes/CP / bms dp's/hfs4 / er fmic/PSS/spec stage 2+/kwv2/steveAZ stage 3 lpfp /m3 control arms/powerflex black/MF LSD /fuel it port injection
09-22-2013, 09:35 PM | #12 |
76
Rep 1,071
It did, I even passed it along to a few people after you helped me out!!!
FFTEC 6466 Gen2, MHD Flash Tuned by Wedge, BMS PI Kit, FUEL-IT Stg 3 pump, HALTECH PS-1000, MFactory LSD w/lock down brace, ECS Trailing Arms, M3 control arms, M3 brace, DGR Coilovers, N20 tmap sensor, BMS OCC, VRSF exhaust w/4" tips, VRSF CP, Tial BOV. BigTom FMIC, Msport front & rear, m3 sides skirts.
09-23-2013, 09:13 AM | #13 |
82
Rep 725
that right didn't you send me a clip of the car shooting flames out the exhaust !
03-03-2014, 09:03 AM | #14 | |
76
Rep 1,071
04-24-2014, 09:07 PM | #15 |
Rep 65
