FS: [San Antonio] E82/E9x (non-M3) Vorshlag Camber Plates
03-26-2013, 08:00 PM | #1 |
18
Rep 193
Used E82 (non-M) 135i Vorshlag Camber Plates. Setup for stock/OEM-style springs, and Konis http://www.vorshlag.com/product_info...roducts_id=199 I was able to get a little over -2* of camber with this setup on factory springs. I believe it was -2.1 or -2.2, I lost the paperwork. $300 shipped. edit: yes only one rubber coil spring gasket is available (as pictured), i had to re-use the other one. |
03-31-2013, 10:46 PM | #3 |
11
Rep 58
Did the overall combination lower you vehicle a little bit more? I'm local and trying to get a similar set-up put together.
The overall stack height seems like it'd be shorter but I'm not sure.
LAST 24 MONTHS = E90 328i LCI xdrive *SOLD* / E36 328is Because Race car / 11-Volvo S40 T5 *SOLD* / 96-Japanese Evo 4 *SOLD* / 04-Saturn Ion Redline *SOLD*/ 10-V6 Camaro *SOLD* / E90 LCI 335XI aaaand I think I found a winner
...do it right or do it twice(or more) |
04-07-2013, 11:15 PM | #6 |
California-bound
385
Rep 1,480
Is the spring rubber that you're talking about the OE parts already on the car, that you pull off of the factory top hats? Basically, if I buy these, what will I need to run them. Also, I notice that you have all of the piece zip tied together, is the hardware not included? How much added NVH was there when you used these?
Streets of Willow: 1:27.7 CW 11/15/15; 1:29.5 CCW 8/15/15 |||| Autoclub Speedway ROVAL (CCW): 1.52.6 - 12/2/17
Willow Springs - Big Willow (CW): 1:35.8 - 3/31/18 |||| Buttonwillow #13 (CW): 1:59.3 1/27/18 https://www.facebook.com/JakeStumphRacing |||| http://www.youtube.com/user/RaceMeMZ3 |
04-08-2013, 08:05 AM | #7 |
18
Rep 193
The spring rubber is the factory piece, yes. I planned on replacing them both but the dealer only had one new one in stock, so I re-used one of the old pieces. That's why one has the spring rubber, and one doesn't. You won't need anything else to install these. These are complete as-is, as I took them off.
There is no additional hardware. Your Koni shock shaft slips through the center hole and the top nut that is already on your Koni goes on top and holds it all together. I have them zip tied to hold the pieces together, and to make sure I don't lose the little metal insert at the top that the nut will sit against. I don't know what 'NVH' means? |
04-08-2013, 12:37 PM | #8 |
California-bound
385
Rep 1,480
Oh, I didn't see that these were built for the Koni shocks. I need to see if they will work with my (for the time being) OE shocks..
