03-25-2013, 01:11 PM | #1 |
Rep 17
Noisy brakes
I have done 600 miles in my 13 reg F31 Msport and notice two separate issues with the brakes. The pedal itself makes a creaking noise when depressed and the brakes squeak loudly when braking at low speeds (typically under 20mph) which is noisy in slow traffic. Am waiting for the dealer to call me back but wondered if anyone else had experienced the same. I have the standard F30/31 braking system.
UPDATE: Been to dealer and mostly resolved - see my last post Last edited by badger76; 03-28-2013 at 09:52 AM.. Reason: Have had work done on car |
03-25-2013, 02:04 PM | #2 |
1588
Rep 4,553
MSport brakes squeal. Mine does a bit at low speeds too. Some say the squealing decreases after some mileage. I have under 2K and haven't seen much change. Do some searching here, you'll find plenty on squealing MSport brakes.
BTW, some have had luck after dealer chamfers the edge of the pads. I decided against this temporary fix. No way this can be a permanent fix b/c as pads wear so will the chamfered edge. As far the creaky pedal, I had a similar issue with my 2010 E90. Dealer resolved it by trimming away a small amount of the foam surrounding it. I think it was where the pedal went through the under dash panel, however it could have been where it went through the firewall. Don't recall exactly. In my case the shop foreman knew exactly what to do when he heard the noise. Maybe its same on F30?
2023 840GC | 2021 740i | 2019 X3
03-25-2013, 03:10 PM | #3 |
has left the building
90
Rep 3,359
No noisy pedal but my brakes have squealed/squeaked since day one. The dealer was supposed to have fixed it when it went in a few weeks ago but 1200 miles and they're still squeaking.
03-25-2013, 04:23 PM | #4 |
443
Rep 1,963
Drives: I20 IX M60 Oxide Grey
My E61 brakes started squealing about 2 years ago. The dealer said there might be a stone chip or something foreign in there somewhere (I know - lie detector was going nuts in my head), but wouldn't investigate unless they charged me for it (even under warranty!) I've had the front and rear discs and pads changed now but still squeals.... Good news is that with a tad bit of radio on and windows up, I can't hear it at all
Sounds like good preparation for the F31...
Running: G30 530d M Sport (B57) Mediterranean Blue
Running: I20 IX M60 Oxide Grey Gone: F15 X5 40d M Sport (N57) Glacier Silver, E61 520d SE Auto (N47D20) Titanium Silver, F31 330d M Sport (N57D30A) Estoril Blue, E87 120d SE Auto (M47TU2D20) Sparkling Graphite |
03-25-2013, 05:27 PM | #5 | |
541
Rep 1,894
03-26-2013, 12:25 PM | #7 |
Rep 35
Yep same here, I have the auto in the F30 and the brakes definately do sweal at lower speeds, more when the car is coming towards a standing halt. I thought it might be the fact its an auto and that the brake pedal is used constantly whilst travelling.
03-26-2013, 03:28 PM | #8 |
36
Rep 398
I had the squeal for the first few k,it takes a few miles to bed them in,no noise after 4k
f31 330d mineral grey/black interior with extra stuff fitted
03-26-2013, 04:29 PM | #9 |
121
Rep 1,089
You would have thought they would have bedded in before 4K
I haven't even got mine yet, Thursday by the way Not happy if i have to live with noisy brakes for a few thousand miles. I can handle the brake dust, not the noise though. Hopefully mine are ok, but not holding much hope. |
03-26-2013, 05:02 PM | #10 | |
3489
Rep 9,709
For anyone suffering with squeal, might be worth trying the pad bed in procedure. Doesn't always work on already glazed pads, but worth a try???? I have M Sport brakes and not a squeal ever. I did bed the pads in when new. |
03-26-2013, 05:16 PM | #11 | |
121
Rep 1,089
Can you enlighten me on the glazed pads & bed in procedure ? |
03-26-2013, 05:23 PM | #12 |
3489
Rep 9,709
03-26-2013, 05:28 PM | #13 | |
36
Rep 398
03-26-2013, 05:35 PM | #14 |
443
Rep 1,963
Nice video NISFAN - I found it also linked from here: http://www.f30post.com/forums/showthread.php?t=766693 when I googled 'bedding in'. Does bedding it in like they say reduce the lifespan of the brake pads/discs? I'd like to try it if it's not too detrimental to lifespan...
03-26-2013, 05:49 PM | #15 | |
3489
Rep 9,709
4-5 stops from 60ish in a short period of time. They won't be smoking like the video, although you should get that burnt resin smell. Regarding reduced life.....well, perhaps it will shorten the life by a minimal amount, but surely worth it to have brakes with lots of bite and no squeal??? IMO if you are getting squeal, you are not using the brakes correctly in the first place, to the point you will get less life out of them. |
03-26-2013, 06:20 PM | #16 |
443
Rep 1,963
Also - once you do it, do you need to do it again? Does the burn-on then wear down after a while?
03-26-2013, 06:43 PM | #17 |
3489
Rep 9,709
03-27-2013, 06:18 AM | #18 | |
Rep 35
03-27-2013, 08:37 AM | #19 |
706
Rep 5,021
No squeaky brakes
No suspension noises No steering noises No rattles No wind noise Car practically perfect Thank the Lord
Previous: Superman 330d sDrive M Sport + Toys
Present: Red Tornado Golf 7R 5 Dr, DSG + Toys |
03-27-2013, 08:56 AM | #20 |
3533
Rep 11,292
03-27-2013, 02:33 PM | #21 |
706
Rep 5,021
Too true. Yes, those baggy Hippo Hide Seats which I had to pay for to get sorted as BMW showed no customer care by being too mean to contribute and provide a fix under warranty.
03-27-2013, 02:57 PM | #22 | |
121
Rep 1,089
I used to try that after getting new brake pads, but not as many times as described in the video. Don't think i ever had squeeling brakes before on any of my cars. |
