New ETS Intercooler installed - Should I be worried?
03-20-2013, 11:57 AM | #1 |
Rep 17
I installed the 5" ETS Intercooler in my car last night. Aside from a little fighting with the piping, it was a straightforward installation. After everything was put together, I took it for a test drive and noticed a very loud whistling noise. I pulled it back in the garage and re-tightened the clamps and checked all connections, etc.
I took it for another test drive and the whistling sound had decreased considerably. However, when I give it a little more gas I can hear a whistling sound that gets louder as I hit higher RPMs. Would that more than likely be the turbo spooling? I read that with a bigger intercooler, turbo spooling sounds get more noticelable. I don't notice much degradation in power so I'm thinking I should be OK? Thoughts anyone? Should I test/check anything else to comfort my worries? I have the Dinan Stage 2 tune on my car and that is it. This is my first BMW so I am not familiar with typical sounds and "nature" of the beast. |
03-20-2013, 01:26 PM | #2 |
98
Rep 1,647
do you have a tune?
I'm pretty sure its a tiny boost leak somewhere.. With more boost you will notice the loss of power.
Current: 2021 X3MC
Past: 2013 bmw 335i, 2011 bmw 335i coupe, 2016 bmw m3 |
03-20-2013, 01:49 PM | #3 |
1561
Rep 4,109
Drives: BMW M3
I have the ETS 5" intercooler and there's no extra whistling. Re-check the install, agreed it's probably a leak somewhere.
Might be worth it to check the charge pipe too ... those are known to crack in the N55.
2024 BMW M3 Sedan Frozen Pure Grey II/Fjord Blue, 6MT
Past: 2021 Z4 M40i Frozen Grey II/Black Alcantara | 2017 F30 340i Mineral Gray/Coral Red, 6MT | 2011 E92 335i Le Mans Blue/Black, 6MT |
03-20-2013, 07:11 PM | #6 | |
Rep 17
Jeff, Thanks for the hookup and great service on the intercooler! |
03-22-2013, 12:36 PM | #8 | |
3441
Rep 79,211
If you over tighten them it's possible to break the clamp or bend the pipe. No problem! |
