The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > Alpina D3 software - Remove Cobb?
      03-19-2013, 09:09 PM   #1
Gemballa1980
18
Drives: 335i
Hi guys,
Quick question, and I think the title says it all.
I'm considering doing the Alpina D3 software flash on my 335i and am curious as to whether I'd need to remove (unpair) the Cobb tune prior to flashing or not?
Also, do most put a battery charger / trickle charger on while flashing? And if so - do you connect to the battery itself (boot) or the terminals under the bonnet?
Thanks!
      03-19-2013, 10:01 PM   #2
cn555ic
cn555ic's Avatar
441
Drives: 335i
Originally Posted by Gemballa1980 View Post
Hi guys,
Thanks!
You are doing the Alpina B3 flash right? If you battery is suspect then a battery charger would be necessary and you can use both the front or the back, if not just make sure all accessories are turned off...YOu have no issues coding with Cobb and no need to unmarry it...If your using JB4 and Procede just make sure you put it on Valet mode and you should be fine...
      03-20-2013, 05:52 AM   #3
pweber84
pweber84's Avatar
Germany
49
Drives: BMW 330d e91
I think that is quite dangerous to do it without additional power supply. If voltage will drop down the flashing process will be stopped. It's not worth to take this risk. Every ECU in your car should be flashed using battery charger or second car as a power donor.
      03-20-2013, 07:53 AM   #4
cn555ic
cn555ic's Avatar
441
Drives: 335i
I would agree to disagree but i have flashed over 40 Alpina flashes without battery charger and it went fine...But for added insurance it cant hurt. Other modules like DME, CIC as such I totally agree
      03-20-2013, 08:10 AM   #5
pweber84
pweber84's Avatar
Germany
49
Perhaps you right, but Better safe than sorry.
Once I did flash KOMBI module with no additional power supply and It had stopped on 7% (beautiful Christmas Tree in my cluster, take a look below), from this time I always use the cables from the other car or battery charger and everything is going smoothly
Fortunatelly I did flash it again and everything came back to life
      03-20-2013, 04:03 PM   #6
Elliott@DetailAddict
300
Drives: E90
How long did the KOMBI flash take you? Minutes, hours?
      03-20-2013, 04:21 PM   #7
DESI4life10
DESI4life10's Avatar
201
Drives: Coding: Desi4life10@gmail.com
Kombi flash for me was quick. 5 minutes to update.
      03-20-2013, 04:33 PM   #8
pweber84
pweber84's Avatar
Germany
49
It took me about 8 minutes.
      03-21-2013, 05:54 PM   #9
miguex@ecuprogram
miguex@ecuprogram's Avatar
37
Drives: 2010 X5 M
I didnt know that the kombi can be updated. What are the changes?
      03-23-2013, 08:04 AM   #10
pweber84
pweber84's Avatar
Germany
49
I know about new ICON on a Dash when your DSC is OFF
      03-31-2013, 11:36 PM   #11
Gemballa1980
18
Drives: 335i
Thanks for that! One more quick question: as part of the update, im updating to SP-Daten 49.0. I haven't looked what i'm running at the moment (been a while since it's been in for an update).
My question (again relating to COBB): Do I need to unpair the COBB so it's standard, or can I just update SP-Daten with cobb paired??
Thanks!
