F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > N20 328i JB4 Dyno Testing -- 91 octane (Stage1/Stage2 Comparison)
ARMA SPEED
      03-19-2013, 08:05 PM   #1
Mike@N54Tuning.com
BimmerPost Supporting Vendor
4907
Drives: 2007 335i, 2015 M3
Finally, BMS got the N20 on the dyno with crappy 91 pump gas.
A few observations:
1) Boost is as much as 7psi over factory down low and as little as 3psi over factory up top. Compared to the Stage1 which runs 3psi over factory down low and tapers up top to as little as 1-2psi over factory.
2) These Stage2 boost levels are aggressive enough to feel the difference over Stage1 but not so aggressive that reliability becomes compromised.
3) We'll explore higher pump gas boost levels for use with bolt on parts like downpipe & intercooler down the road.
4) This is using map 1 on the JB4.
5) The factory tuning and Stage1 runs were done on a different day, but with the same vehicle, dyno, and fuel, with similar weather.
6) I expect good 93 octane with no other changes will boost the Stage2 numbers 5-8hp.
      03-19-2013, 08:22 PM   #2
krnnerdboy
krnnerdboy's Avatar
190
Drives: v10 m6
Just in time when its time to pick up my 328! Ill be running it on e85 on track though!
F80 m3, 997 gt3, 14 ram ctd, f15 x5, drz400sm
Gone:z4m, boss 302, c6 z06, m6,z3m
      03-19-2013, 08:41 PM   #3
Turboedv6
Drives: '13 Apline White Sportline 328
I can't wait for the N26 release. C16, sprayed intercooler, max boost, 11s here I come.
2019 Ibis White/Red S4
1997 Nissan Skyline GTR V-SPEC
      03-19-2013, 08:54 PM   #4
M3takesNYC
19
Drives: m3
So looks like a tuned 328 matches a stock 335. Not bad for a 400 dollar tune. If you truly were happy with 300 crank hp and definetly did not want anymore than the 328 with a tune is the way to go.
However it is very unlikely anyone who would be buying a tune would be someone who would not want more and more power vs someone who buys a stock car and is content with it and does not get it tuned.
Therefore the guy that buys the 328 and tunes it would probably tune the 335 if they could afford it and therefore the difference in hp between tuned 328 and tuned 335 remains large.
Still nice if you have a 328 to match stock 335 performance!
      03-19-2013, 09:15 PM   #5
Casualvic
26
Drives: 328i xdrive
Would not consider 91 crappy! Are these bms tunes based only on the grade of fuel? Truly BS if you base the hp/TQ highly on the fuel...... then call it a fuel enhancement performance... not a performance tune.
      03-19-2013, 09:36 PM   #6
David328M-Sport
Australia
101
Drives: F30 M-Sport 328i Estoril Blue
I totally agree about the low grade fuel.
We are very fortunate to have an abundance of your equivalent of 93-94AKI here in Australia. Non Ethanol 98RON.
To me it looks as though the tune works both ways. It's a performance tune AND works better with higher quality fuel.
Looking at the S2 figures with 91AKI, the car still perfumed considerably better than stock, Stage 1 & 91, so there's your performance enhancement. Although it has yet to be proven (a formality) the same S2 with 93/94AKI (98RON) should (read will) perform with improved results, based on S1 figures.
So the BMS N20 piggyback tune is both a performance and fuel grade enhancement tune. The best of both worlds!!
Then we have even better results with the ER cat free down pipe - albeit pretty much illegal on the street. So we need yet another tune classification for replacement parts.
I look forward to S2.
328i M-Sport, Estoril Blue, Carbon XP 35 Tint, front heated seats, black Dakota, Sports Suspension, Anthracite Headliner, HUD, Pro Nav, Sunroof, hk 600w, Bi-Xenon, 19" 403M wheels, Reversing Camera, DAB+, Xenon, BT Ext Connect, MST turbo intake pipe, MST Cold Air Intake, JB4 on Map 2 with Catless DP produces awesome performance in Sport.
      03-20-2013, 04:18 AM   #7
VANOS
NFS
VANOS's Avatar
120
Drives: N/A
Honestly, shit I am happy with those results! Not bad at all using 91 fuel, because I personally still am not lowering my fuel grade down to 85 man. The car wasn't designed to take that kind of fuel. Minimum 89. Plus, very hard to find 85 in CA. Almost impossible. But anyways the BMS stage 2 with 91 fuel still kicks ass in my books! I am happy with that!
Mike, when does this tune come out? And do you have an estimate of how much it will cost?
      03-20-2013, 04:44 AM   #8
Turboedv6
85 is not the octane rating, just means it has up to 85% ethanol.
      03-20-2013, 04:54 AM   #9
Turboedv6
ohhhh ok, I hate e85...I would rather spend $15 a gallon on C16 then to have another injector clog and melt a piston from running lean.
      03-20-2013, 06:05 AM   #10
Mike@N54Tuning.com
4907
91 octane is the lowest grade supported and its not suggested unless you happen to be stuck with it in the West coast states. They suggest using 93 octane for all their performance tunes. Higher octane allows a boosted motor to operate more efficiently with a greater margin of safety against engine knock.
Mike
      03-20-2013, 09:21 AM   #11
ScarecrowBoat
Zooombie attaaack!!
ScarecrowBoat's Avatar
136
Drives: 328
It actually is quite an upgrade on stock 335i performance, as the 335i is a couple hundred pounds heavier and the 328i tune gives you a slight edge on 335i numbers.
      03-20-2013, 04:03 PM   #12
tricksterr24
26
Drives: 2012 328i
2009 328 sulev  [0.00]
Mike
What happens if you use e85 with a tune? And how many gallons are you supposed to use?
      03-20-2013, 04:37 PM   #13
metrathon
79
Drives: 2012 328i Sport Line
Ok, that's it. I'm in. Once it's up on the website, I'll buy it.
It's a no-brainer for me. Same numbers as a 335i but 150 pounds lighter.
Enjoying: 2014 Yamaha FZ-09 | 2015 Lexus GS 350 | 2015 Lexus RX 350
Past affairs: 2014 Lexus RX 350 | 2012 BMW 328i Sport | 2009 Audi A4 2.0T | 2007 BMW 750Li | 2006 Kawaki Ninja 650R | 2004 BMW 530i | 2004 BMW 520i | 2001 BMW 530i | 2003 Opel Vectra | 2002 Citroen Xsara
      03-20-2013, 05:33 PM   #14
Jamesons Viggen
193
Drives: '98 M Roadster stg 2+ S/C
It has been shown to make 300whp/350tq. Instructions for what to mix is on the N54 site.
'98 Dinan/RMS stage 2+(VAC cams, CES Cutring etc)
'15 Buick Regal "T"(wife)
'06 Saab 9-5 Combi 5mt (full suspension, LSD, clipped turbo etc)
      03-20-2013, 07:40 PM   #15
tiltmode43
I plead the 5th.
tiltmode43's Avatar
523
Drives: '18 Frontier Pro-4X, '06 Z4MR
Excellent news! Cannot wait to see a dyno w/downpipe + catback
-Matt
| Z4M Build Thread | @violetnites | flickr |
      03-20-2013, 08:18 PM   #16
Casualvic
26
Drives: 328i xdrive
Selling my stage 1 so you can be ready for stage 2.... Posted on classifieds
      03-20-2013, 08:25 PM   #17
ixse
238
Drives: 2015 boxster s
Obviously coming from someone with zero understanding of e85 fuel.. who says e85 cause injector clog n piston to melt?
      03-20-2013, 08:30 PM   #18
Turboedv6
Kidding right?
      03-20-2013, 09:14 PM   #19
tricksterr24
26
Drives: 2012 328i
Thanks
      03-21-2013, 02:11 PM   #20
ixse
238
Kidding right?
I've been running e85 on my evo for past 2 yrs with almost maxed 1000cc injectors running 27~8 psi. Summer day willow springs 100+ degrees all day wo a single problem. So no I'm not kidding.
C16 may be safer racing fuel, but dont think e85 will blow stuff up either when the car is tuned properly
      03-22-2013, 12:37 AM   #21
momo3605
208
Drives: M340i LCI, 718 GTS 4.0
Soo, now can we get a test on the N26
      03-22-2013, 07:00 AM   #22
Turboedv6
I had one of my FIC 2150s junk up after running E85 for 6 months and one day at the track the cylinder with the junked up injector went so lean at 37psi it melted the piston and lost compression. FIC flow tested the injectors and told me the E85 caused the junk up. This has happened to many people on the EvoM forums.
Search this Thread:
Advanced Search
f30post
